Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 170
  1. #41
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by GU_Audi View Post
    I swapped a set of S4 seats into my 15 Allroad. Having some trouble with getting the rear seat backs out. Seems like the pin on the outsides of each side has some sort of clip or something because they won't come out. Also, the airbag connector is different on the front seats, at least between whatever year the seats I got were out of and the 2015s. I got the correct connectors, just need to figure out how to crimp the wires into them.
    I'm not sure that the rear seats will be a direct fit. For the A4 there's a plastic cover and then a metal retainer bracket with a torx bolt in it. After you remove that you just need some elbow grease to get it off the outside bracket. I just wiggled it back and forth up and down and it released. I think there's a groove that it fits in.
    That seems odd (airbag connector) as the seats should be a direct fit, I got my seats out of a newer model S4.
    My 2009 A4 Prem+ Build thread
  2. #42
    Jul 07 2012
    Boston, MA
    Side note. I can't figure out how to swap over my seat recognition sensor. Any ideas as to why I can't find the module on my S4 seats so that I can swap them over? I don't think my passenger airbag is functioning which is somewhat of a safety concern.
  3. #43
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Quote Originally Posted by Lambda13 View Post
    I'd say so.
    What exactly is the error code you're throwing?
    And what's the part number on the A4 seat for the passenger occupancy sensor?
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
  4. #44
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by ryanhmusic View Post
    I'd say so.
    I'll have to scan it when I get home. It doesn't seem to recognize that there is a passenger.
    Good information to have AFTER coming back from MTL no? lol
  5. #45
    Aug 05 2014
    If I remember correctly, there was one moment where it would have been comforting to know the passenger airbag was working...
    How about part number on the occupancy sensor?
  6. #46
    Jul 07 2012
    Boston, MA
    I may know when you are referring to... The sensor is in my trunk. I can usually see my trunk from where I'm sitting but due to it snowing UP and SIDEWAYS (yes it is literally going up due to the laws of physics ceasing to exist outside of my building) my view is currently blocked.
  7. #47
    Account Terminated Two Rings
    Jan 23 2016
    Hong Kong
    Amazing Post
  8. #48
    May 24 2007
    PA
    How do you actually remove the side plastic piece on the seat where the electronic controls are? Just tug on it? I don't want to break it.
    Also, what size triple square bit is needed for the bolts?
  9. #49
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by s4baby View Post
    Not sure bolt size (it should be in the first post) but there is a screw under the plastic piece. Then you can carefully pry it apart.
  10. #50
    May 24 2007
    PA
    Thanks.
    Anyone know if seats from a 2014 Allroad would fit into a 2009 A4? I have the measurement of the bolt holes that I need to confirm but wondering if someone knows this off the top of their head.
  11. #51
    Jul 07 2012
    Boston, MA
    Thanks.
    Yes, should fit. Although I think they are the same as the ones you currently have, so not sure why?
  12. #52
    May 24 2007
    PA
    I have standard seats, these are sport seats.
  13. #53
    Jul 07 2012
    Boston, MA
    Ah, didn't realize they had the sport seats. S4 seats or bust! lol
  14. #54
    May 24 2007
    PA
    The S4 seats are nice, but hard to find and pricey. I also wanted something a little different with a chestnut brown color to replace the standard black.
  15. #55
    Jul 07 2012
    Boston, MA
    Should look good. I got a set from Canada. There was another set kicking around those parts as well.
  16. #56
    Junior Member Two Rings
    Nov 16 2015
    Netherlands
    Does this set have seat warming?
  17. #57
    Active Member Two Rings risu's Avatar
    Mar 24 2013
    Charlotte, NC
    I used this diy to swap my A5 stock seats for S5 seats, worked out great!
    The triple square tool is 10mm XZN and on a another notice, don't be scared when only one is plugged in, the electric controls don't work. They both need to be plugged in to function :)
    Picked up my seats on ebay, just two weeks ago for $1500.
    2010 A5 TFSIq Stage2+ with some other mods...
  18. #58
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    sorry to bring it back from the dead but will S5 seats work with a A4
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
  19. #59
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    Selling my S-Line sport seats in the classified section if anyone is interested.
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
  20. #60
    Feb 08 2013
    2019 Cayman GTS, 2016 Forester XT, 2013 S5, 2011 A4 avanti, 2004 TSX
    May I ask if B8.5 seat able to fit B8 avant?
    2019 718 Cayman GTS 6MT
    2016 Subaru Dark Grey Forester XT touring
    2013 Audi Phantom Black S5 6MT Sport Diff, 20" BBS CH-R, Navi, B&O, PSS10, AK, EC sway, Alcon BBK, RS grille & Ecode
    2011 Audi Deep Sea Blue A4 Avant prestige, 19" OEM Ti rotors, PSS10, AK, sway, RS style grille + rear spoiler, Votrex diffusor
    2004 Acura Premium White TSX 6MT
  21. #61
    Saint Cloud, Fl
    Quote Originally Posted by Demringstho864 View Post
    Yes they will work, the rear seats will require a little tweaking.
    instagram ------------> low_enforcement
  22. #62
    Nov 05 2009
    '09 B8 A4 2.0t quattro '15 Q5 3.0T
    Chicago, IL
    Complete functioning solution to get rid of the airbag light/POD fault for anyone who forgot to retain their original POD module after a seat swap:
    http://www.audizine.com/forum/showth...1#post12125461
    Only works if you get the "not configured" fault. not the "electrical failure" fault on the POD submodule in the airbag module group.
  23. #63
    Jan 15 2017
    Randolph, NJ
    Help with battery disconnect for swap
    HEy guys doing a swap on my a5 with s5 seats, where Qdid you disconnect battery? In trunk or just 1 site that you can access under hood?
    Oscar
    OTE=7speed;8922665]Here is a little of what I learned on my S4 seat swap experience.
    - Tools that are needed
    - Ratchet
    - Extension
    - Torx T27
    - 12 point Tox (Large)
    Start by sliding the seat to the back and remove these covers
    Under the covers are the bolts that need to be remove. Repeat for the rear.
    Remove screws and pull the seats out. Then you should be here, old seat next to new
    Notice the memory module on the drivers seat and the seat recognition module on the passenger
    For those of you wit memory seats you will need to swap this module from your old seat to you new seat
    For those of you without the seat memory option, you will need to remove all of this
    - side of the seat control panel and the attached harness
    - Don't let this scare you it is very simple and east to do
    Once these modules are swapped simply place the seats back into their new homes. No programming needed
    The rear seats are pretty self explanatory.
    - to remove the rear bottom seat, you simply pull up at the center of each passenger seat
    The top halves have a couple steps
    - All that you need to do is pop up the plastic tab pictured below. Unscrew the Torx, and lift the metal cover.
    - You then need to unplug the airbag sensor under the rear passenger seat that is connected to the rear of the seat uppers
    - You then lift the seats up and away to remove them
    - Installation is in reverse
    Hopefully with this help you can go from this
    to this
    I am no expert so if I missed anything let me know and I'll add it to the post.[/QUOTE]
  24. #64
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Very nice work and thanks for the DIY as well!
  25. #65
    Jan 15 2017
    Randolph, NJ
    Hey guys hope everyone is starting new year well. This DIY post is on point. few additions that I made with todays swap for my 2008 A5 with S5 seats upfront. Your need a triplesquare 10mm for front hardware removal. In my area autozone had in stock. I haven't gotten any light but only drove car for 1 mile after install. for my driver side I dont have the memory seat function working and dont know why. .any ideas?
  26. #66
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by munozo1 View Post
    You have to swap the memory seat modules from the old seats to the new ones. Did you already try and do that or not yet? If you're not sure what it is, it's the gray plastic box.
  27. #67
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    I am in the middle of trying to pull the black box and harness from the driver seat on this DIY because i dont have memory seats but i do have power seats and it looks like pulling this whole harness is going to make me loose power to my seats.
    Any help is appreciated.
    Sent from my SM-G935T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
  28. #68
    Jan 16 2011
    Earth
    Edit- can i just unplug the black module and leave all the wiring? No power is going to any of it so i dont see why pulling it matters.
    Pulling the harness to plugs on the side plastic trim would affect all the power controls so i dont see how that makes sense
  29. #69
    Jan 16 2011
    Earth
    Nm i read further into this thread and if i am correct i am suppose to pull all this wiring with the box and panel and replace it with my panel snd remaining harness. I missed where it said to add your harness and side plastic switch peice to the new seat.
    If anyone can confirm that is correct I would appreciate it just to be safe.
  30. #70
    Jul 07 2012
    Boston, MA
    My seats worked fine, but its the passenger seat recognition module that controls the airbags that didn't work as plug and play.
  31. #71
    Jan 16 2011
    Earth
    Quote Originally Posted by SWONER View Post
    UPDATE: I found the problem. It was this sensor. I'm not sure what it is but it must have something to do with the airbag and parking brake system. It's located on the seat rail, driver's side seat, nearest the center console. It's its own wiring harness. If you're getting the air bag, parking brake, and ESC dash lights after a swap, pull this sensor off your base seat and put it on the S4 seat and you should be good to go.
    Sent from my SM-G925V using Tapatalk
    I followed this step exactly and still have parking brake air bag and esp error.
    I also swapped passenger sest modules and unplugged the black module under the driver seat for memory seats cuz i dont have memory but since i do have power seats i just left that whole harness for that box attached because i dont think that would cause issues there is no power going to any of that harness so that shouldnt matter.
    Any help is greatly appreciated im out of ideas.
  32. #72
    Jan 16 2011
    Earth
    Nm i just realized there is one of these sensors on both seats i am going to do the passenger and post back.
  33. #73
    Jan 16 2011
    Earth
    I just wanted to update this thread so that if anyone else is experiencing issues removing the parking brake, esp and air bag light the final solution for this was to swap the entire original harness from the driver seat. This problem only happens if your installing memory seats in a car without memory but with power seats.
    The passenger sensor doesnt require being swapped only the sensor on the driver seat does. The only thing required on the passenger is the grey air bag module shown in thr DIY
  34. #74
    Jun 05 2009
    Scottsdale Arizona
    ^ Thanks much! I am sure this will help others with this type of project.
  35. #75
    Veteran Member Three Rings audiipolak's Avatar
    Feb 05 2011
    Massachusetts
    Just wanted to be clear up any confusion I have with my upcoming swap-
    I have base seats, memory and power and I am swapping to S4 seats that are memory and power as well.
    All that needs to be swapped is the memory seat module from the driver seats and then the passenger seat recognition module plus the normal harnesses.
    Is this correct? Just wanted to avoid any coding issues that may bring me to the stealership for component protection issues I've read about
    Instagram: @dmikucki
  36. #76
    Established Member Two Rings a4efforts's Avatar
    May 15 2017
    '09 A4 B8, '17 PORSCHE MACAN & '08 BMW X5
    Atlanta, GA
    Hey Everyone. Old thread, but I'm sure someone may be able to help!
    I installed my S4 seats in my A4 last year, and weirdly, the heated seat function has never worked correctly-- as in, only the backs of the seats will heat, but the bottoms don't. Swapped everything like the other posters did, but this is the only odd issue.
  37. #77
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Has anyone else encountered an issue with the airbag clips not matching up? I’m in the middle of a seat swap from B8 sport seats to B8.5 S4 seats and the clips look totally different. The S4 clips will not clip into the floor harness under the seat.
    (B8.5 Clip Top, B8 on the bottom)
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
  38. #78
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by a4efforts View Post
    If you still have the heating elements from the A4 seats, try swapping those as well. The S4 ones may be no good?
    Quote Originally Posted by avantagg View Post
    That's weird. I thought they were the same. Is that for an actual airbag in the back of the seat or the sensor?
  39. #79
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    S4 seat swap - D.I.Y.
    This is the clip at the bottom of the harness that runs up to the airbag in the seat. It connects at the base of the car under the seat where all the other connectors plug in. The B8 harness splits in half and the male connection stays attached to wires in the base of the floor pan.
  40. #80
    Jun 05 2009
    Scottsdale Arizona
    Chris, you are going to have to get a wiring diagram and figure out what the differences are in those two vehicles. I ran into a similar issue with my Jetta TDI that I converted over to OEM European Recaros.
    I wound up pulling the airbags out and swapping every item from the old seats to get the harness to connect. However, your issue seems to be a little different.
    Getting a wiring diagram would again be a good first step.
