Results 1 to 26 of 26
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Reverse Parking Sensors
    Has anyone ever had an issue with their sensor? When I put the car in reverse now I get a solid beep even when nothing is behind me, and it goes away after about 3-5 secs, but I don't think its detecting when I get close to things anymore.. It used to work great, but I think its malfunctioning now.
    Mar 11 2008
    B7RS4 & e46Ms
    That's the system telling you that one of the rear sensors is failing. If you go in via vag-com, it will tell you exactly which sensor is faulty.
    FRRG AZ Ring
    Oct 27 2011
    Atlanta, GA
    Thank you! Warranty to the rescue!!
    Senior Member Two Rings RS4forfrank's Avatar
    Apr 27 2012
    2008 OEM+ RS4
    santa barbara california
    Hi,
    Is there a way to adjust the beep volume?
    RS44Frank/ 2007 Pearl Black RS4/ 2008 OEM+ Pearl Black RS4
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by RS4forfrank View Post
    Hi,
    I believe so via adaption values, but I'm not sure what channel (It's not documented), I just recall coming across it when I was looking into my sensors.
    FRRG AZ Ring
    Oct 27 2011
    Atlanta, GA
    Reviving this thread. My shop was able to order the back-up sensor and it came in today. My question is, does the sensor need to be painted before install? He said it was black. Thanks!!!
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Yes it needs to be painted.
    Sep 27 2011
    Tomatoes
    Eastern PA
    Quote Originally Posted by badbluers4 View Post
    well... if you like black park sensors, then no.
    Suzuka Gray 2015 S3 Thread
    Misano Red 2003 RS6 Thread
    IG: @Flying_Tomatoes
    Oct 27 2011
    Atlanta, GA
    Quote Originally Posted by Flying Tomatoes View Post
    Lmao the question was painting it first or after smart a$$ lol my car is going in the body shop soon for reflector delete and a few touch ups so I wanted to just get the sensor painted then.
    Apr 03 2012
    Raleigh, NC
    those black back up sensors are a hawt mod.
    Sep 27 2011
    Tomatoes
    Eastern PA
    leave them out, have the body shop paint and install while its there.
    Oct 27 2011
    Atlanta, GA
    That's what I'm thinking too. I read on QW that some of the sensors don't require you to remove the bumper to swap out, so hopefully that is the sensor on my car that needs to be replaced.
    May 20 2013
    I'm not seeing many threads about parking sensor issues but I have an issue that I have not seen mentioned.
    In the last few days putting the car in R has not made the system ping noise like it should when the gear is engaged. The car also started beeping while driving forward. My guess is a loose connection somewhere as the beeping seems to be more frequent over bumps.
    Does anyone know where the likely fail points are? Car is a MT if that makes my difference.
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    I had an issue with mine. Came to find out it was just dirty. i cleaned it by washing the car and it was fixed. not saying this is your issue but might be a good place to start.
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by Lor2435 View Post
    Do your reverse lights work?
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    May 20 2013
    I just cleaned each sensor with rubbing ancho and see no difference.
    Confirmed reverse/brake/turn signals all work.
    While waiting for the street cleaner this morning (after cleaning) the system was beeping with the car idling in neutral. After about 2 mins it stopped. The sensors still seems to work when parking.
    Senior Member Three Rings Striddy's Avatar
    Jul 15 2011
    nothing but memories
    Mine started doing the same thing after washing. Under hard acceleration, the sensors would beep or driving by anything close to the shoulder of the road. After it sat for a night it went away. Not sure but it's going in to be checked. I'll keep you posted.
    Ghost
    May 20 2013
    Quote Originally Posted by Striddy View Post
    Please do let me know, mine also started right after a wash but it's been a few days and about 100 miles since and it's still beeping.
    Jul 15 2011
    I had that happen as well. This was after a second wash, thinking I sprayed under the car on th first wash, it then lasted two days. The passenger mirror also would not come back to level after switching out of reverse. Day 3 I turned the passenger side mirror switch back to center and the mirror came back up and the beeping stopped. I'm still traveling on business so the car won't go in until next week. But I'll keep you posted when I find out.
    Ghost
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    reviving this thread from the ashes like a phoenix.
    My rear sensor beeps about 3-5 secs solid (like badblue was saying), and the short beep when Reverse is engaged, does not sound sometimes. I'll try cleaning the sensors from the out side, but if they are faulty, do I need to get them at the stealership? How hard was it to install new sensors?
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Oct 07 2013
    Bellevue WA
    Reviving this thread. I'm getting the 3-5 second long beep when engaging reverse the first time after switching on the engine (no beep on reverse usage thereafter as long as engine hasn't been switched off). Vag-com shows the following fault:
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
    Component: Parkhilfe 4-Kan H06 0010
    Revision: 00H06000 Serial number: 00067802030632
    Coding: 0000304
    Shop #: WSC 06335 000 00000
    VCID: 316923C8AB6863CA11-515E
    1 Fault Found:
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 153
    Time Indication: 0
    Anyone can tell me what "Open or Short to Ground" means? Car was washed recently and the problem started showing up soon after. Water in the sensor?
    Jan 23 2014
    '13 Touareg TDI - '08 RS4 Mug/Ti
    Derby City
    That means you have a bad sensor. Easy.
    Active Member One Ring DottoRS4's Avatar
    Mar 07 2018
    2007 Audi RS4
    Toronto Ontario
    You can tell which sensor is faulty by turning the key but not turning on the car, put the car into reverse. Put your ear up to each sensor. The sensors that are working will be making a small clicking noise. The ones that arent working wont be making any noise.
    Oct 07 2013
    Bellevue WA
    Thanks for the responses. Dealer quoted me $190 for EACH sensor (OEM, unpainted, not installed)!!!! They are willing to install third party sensors for me if I get them painted first. Anyone have a recommendation on what to buy?
    Oct 07 2013
    Bellevue WA
    Quote Originally Posted by DottoRS4 View Post
    If I follow the above directions, it seems like I have two sensors failing (left outer and right inner). The other two appear to be making the expected clicking noise. Its kind of interesting what I have found searching online for replacement parts. As best as I can tell the OEM part number is either 7H0919275A or 7H0919275D. Genuine OEM (Audi branded) replacements are available on Ebay and various other parts websites for anywhere between $130 to $180, roughly the range the dealer quoted me. But then there also appear to be exact looking parts from China on Amazon and Ebay for $10 to $20. Visually these look identical to the OEM ones other than missing the Audi logo. The dealer wants to take off the rear bumper to install new sensors, approx $450 in labor. Add in the spray and parts cost then this is looking close to a $1000 fix for just replacing two sensors if I go the OEM route. So my questions are:
    Can someone confirm the part number for a 2007 RS4.
    Does the bumper really need to come off to replace the sensors?
    Has anyone tried using the $20 versions instead of the OEM ones?
    Jan 23 2014
    Derby City
    7H0919275DGRU
    Your p/n is correct. You need to pull the bumper to replace some, but not necessarily all of them. I just went through this.. Replaced the right center one... Bumper came off.
    You want to put cheap chinese crap on there? Go for it. It's your car.
