Results 1 to 28 of 28
    Established Member Three Rings Madbusy168's Avatar
    Mar 25 2013
    Philadelphia
    DSG barely downshifts to 1st, even at stop signs
    I have a 2013 with 2900 miles on it now, recently I did the vagcom for the gear selector and realized that my car doesnt like to downshift to 1st. Even when I do a complete stop at the stop sign it accelerates back in D2 or S2. I have to have the car completely completely stopped for a good 2-3 sec before it goes back into D1 or S1. I really dont think that is normal at all, the other day I was on 95 during rush hour, basically crawling at 3-5mph and saw an open spot in the lane next to me, I cut over and again, the car stayed in D2 and bogged! It wouldnt downshift to 1st but rather bogged on me!! I was like wtf? and almost got rear ended.. Has anyone experienced this also? I realized that my car doesnt want to accelerate hard anymore either, I had the car in S1 one night and mashed the gas after the light turned green, tires chirped and car took off, but it doesnt do that anymore, it actually hesitates for a sec. or two before it finally decides to jump up and go. I emailed my Audi SA and gonna see what he has to say..
    Established Member Two Rings AndrewSuliteanu's Avatar
    May 15 2013
    United States
    I wouldn't say my S4 won't shift into 1st at all, but it definitely prefers not to be in 1st, especially when downshifting. You have to be at like 2-3k(?) revs in 2nd gear to be able to downshift to 1st, which brings you to like 4500/5k revs in 1st. My A4 would downshift into 1st more willingly, bringing revs to 5500/6k. When accelerating though, I would say it is not normal for the car not to want to shift into 1st if you're going 3-5mph. Something sounds off there.
    2013 Monsoon Gray S4
    2013 Ferrari 458 Gunmetal
    2013 Phantom Black S6
    2011 Porsche GT3
    Veteran Member Four Rings thedollardoctor's Avatar
    Oct 28 2012
    Dayton, OH
    This is exactly what my car does as well, I believe it's Audi's efforts to save gas mileage. As I have posted in another thread. The DSG transmission has certain nuances that you have to adapt to. If I am in stop and go or slow traffic, I ALWAYS have my car in dynamic mode so that throttle response is more sensitive and immediate.
    You could always use the paddles if you want to be sure it will downshift. This is not something that bothers me at all, as I have learned how to work with it. I suspect over time you will as well. I do not think anything is wrong with your car.
    I am hopeful a TCU tune from GIAC will tighten these nuances up....time will tell
    2013 Audi S4 | Ice Silver | DSG | GIAC/AWE Stage II with DSG Tune | Roc Euro Intake | AWE Full Exhaust w/ Resonated DPs | VMR V713 19x9.5 et45 Matte Black | H&R OE Sport Springs | USS Sway Bars and End Links | Alu Kreuz | Color Coded Custom Painted Headlights and Emblems by ONEighty Customs | RS4 Style Honeycomb Grille by ECS
    Feb 25 2013
    MI
    I think the 2-1 shift is pretty jerky, so my guess is the TCU tries to avoid this at all costs (i.e. unless you punch WOT while sitting slowly in 2nd). When I drive in M mode, it will only automatically downshift to 1 after coming to a complete stop for 1-2 seconds. Try driving in Sport mode, this should always keep your gears low. I've never felt like the car was "bogged down" unless trying to accelerate hard on the freeway in 7th or something. My best advice is always run in dynamic mode - annoyingly, you have to cycle through all the modes to get the engine in S after keying on (I need to switch this with vagcom).
    Established Member Two Rings Vandalrg's Avatar
    May 29 2012
    Boston, MA
    Re: DSG barely downshifts to 1st, even at stop signs
    Same here, except for the bogging. I actually prefer this behavior over having the car downshift into first all the time.
    2013 Audi S4 - S-tronic - Glacier White - Black/Silver Nappa - Sport Differential - 19x9.5 BBS-CHR's - H&R OE springs - Alu Kreuz - Front/Rear sways
    Veteran Member Four Rings Toecutter's Avatar
    Dec 31 2007
    Oregon
    I've never noticed that behavior with my DSG, but even in my manual tranny car I'm rarely in 1st. I just use it to start from a stop but even when I slow to a roll I'm in 2nd at the lowest. To get it into 1st I have to almost stop.
    Apr 04 2012
    MSP
    Quote Originally Posted by Toecutter View Post
    +1
    May 21 2010
    Quote Originally Posted by Madbusy168 View Post
    Manual tranny ftw!
    Jul 11 2011
    2021 Ford F-150 Lariat PowerBoost
    I've noticed my car does the same thing, but it will slip the clutch quite a bit in 2nd, which is nice and keeps it from really bogging. I've found that if you really want 1st gear you have to mat the accelerator and engage the kickdown switch - this usually works for a 1st gear downshift - but you will need to wait as the DSG requires something like 1100 ms for unexpected downshifts in auto mode. In 2nd gear the other clutch already has 3rd preselected, so it has to reselect 1st. For maximum control, drive with Throttle/DSG in dynamic or manual mode.
    Manual snobs ftl!
    2022 /SQ7 P+ | Daytona Grey Metallic | Executive Pack | Carbon Inlays | Driver Assistance | EA825 4.0T (IYKYK)
    APR Stage 1 685+ HP (Planned)
    Gone But Not Forgotten
    C7.5 S6 - Moonlight Blue
    8V S3 - Nogaro Blue
    B8 S4 - Ibis White
    2008 V10 TDI Touareg II - Floret Silver
    2006 V10 TDI Touareg - Reed Green
    Established Member Two Rings TuanTime's Avatar
    Apr 02 2013
    Nw PA
    Quote Originally Posted by drob23 View Post
    Your car should stay in dynamic mode even when you power off. All you have to do is pull down on the shift knob to get into s mode. No need to touch the drive select anymore.
    May 21 2010
    Quote Originally Posted by CJ_S4 View Post
    Manual snobs ftl!
    I'm no manual snob but definitely prefer it-opinion . Just traded back to manual from 335 AT for same reason you guys are discussing. If you want first you have to kick down then accel is too violent/too late.
    Feb 25 2013
    MI
    Quote Originally Posted by TuanTime View Post
    I turn it off in dynamic, come back and key in and everything is in dynamic except for the engine/trans (can tell cause it's in D mode). I usually go around in M mode, so not even sure it matters. But I don't see S mode until after cycling through ADS back to dynamic. I should just vagcom it permanently to start in dynamic, hopefully that keeps it set.
    Aug 21 2012
    Santa Clara
    I can't believe everyone drives the car in D or S so much! I drive mine in manual mode with my DSG 99% of the time so I am well aware of the gear the car is in. . . Yes, the transmission does not like to go into 1st gear very easily-even in manual mode. However, you get used to it and you just need to come to a complete stock or force it into 1st gear.
    I don't know about the Dynamic mode settings as I got the diff and suspension and no MMI- so my mode is ALWAYS in Dynamic and it never changes unless I change it.
    Sep 05 2012
    Yes, you can pull down on the shifter to go to S
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Sep 05 2012
    Quote Originally Posted by virsipe View Post
    If you just want to know what gear you are in, there's a vagcom tweak for that. It will show S3, S4, S5 etc (or D3...) I find with S it's almost always the gear I'd want to be in anyway.
    Established Member Two Rings webvictim's Avatar
    Jan 07 2013
    San Jose, CA
    I've found that the car is sometimes very reluctant to downshift for acceleration (onto freeways, for example) unless you absolutely punch it. I compensate for this now by manually pulling down on the shifter to go to S when I'm coming onto the freeway.
    Veteran Member Four Rings CreoSTi's Avatar
    Feb 22 2004
    West L.A.
    Quote Originally Posted by webvictim View Post
    Yeah, I drive with the engine in dynamic most of the time, but If I know I need a quick(er) downshift I'll just tap the steering wheel paddle down a couple gears beforehand...
    -Mike-
    2022 Tesla Model 3 Performance & 2023 SQ5
    Past: 2001 S4, 2011 S4, 2014 S6, 2018 S4, & 2021 TT
    CrossCountry Mortgage
    Instagram: creoucla
    Mar 25 2013
    Philadelphia
    Even if I have my car in dynamic and full stop at the stop sign, it accelerates back in S2, I basically have to be completely stopped for 2 seconds at least and then the car goes back into S1. and the car can't "take off" anymore, in dynamic and S1 the car just seems to have a 1-2 sec delay when I wot at the light.
    Feb 25 2013
    MI
    Quote Originally Posted by moose_head View Post
    Haha...wow I'm an idiot, never realized that could be done, thank you sir
    Another dumb question: do you think it matters what mode you're in when switching to M mode? Throttle feels pretty responsive, so I'm assuming it uses the same throttle map as dynamic mode, maybe there's a way to test other than butt dyno?
    Feb 25 2013
    MI
    What happens if you go into M mode?
    May 15 2013
    United States
    If you tap the shifter down to go into S mode, does this essentially put you into dynamic (steering, suspension, exhaust note) or is it only throttle response?
    Aug 18 2011
    Quote Originally Posted by AndrewSuliteanu View Post
    It only puts shift points and throttle response (engine & transmission) in dynamic.
    Veteran Member Three Rings offthewall's Avatar
    Oct 22 2011
    2004 VW R32, 1972 VW Super Beetle Covertible
    West Caldwell, NJ USA
    I have a 2013 S4. I leave it in Dynamic all the time. It stays that way through a turn off/on cycle. I always tap the shifter down to go from D to S when I first get in the car. I always tap the traction control once to turn off braking guard. I NEVER have an issue with the car bogging or starting from a stop in 2 rather than 1.
    IMHO the car shouldn't downshift to 1 until you stop. If I were driving a real manual, I would never downshift to 1st coming to a stop.
    2013 Audi S4
    Phantom Black - Black/Maga Red Fine Nappa Leather - Prestige - IDCore Apple CarPlay - S tronic - Driver Assist - Sports Differential - Supercharged Badges - BBS CH-R 19”x9.5" ET45 Wheels w 255/35/ZR19 96Y Michelin Pilot Super Sport tires (Summer) - OEM Peeler 19"x8.5" ET43 Wheels w 255/35/R19 96V Michelin Pilot Alpin PA4 tires (Winter)
    Veteran Member Three Rings stingray84's Avatar
    May 04 2011
    SF Bay Area
    Sounds like expected behavior. Downshift from 2 to 1 is pretty harsh on DSG and it makes sense that the car is programmed to avoid it as much as possible. I drive in manual mode most of the time and I rarely use 1 either. 2nd gear is punchy enough for me most of the time.
    2016 Carrera White Porsche GT4
    2013 Estoril Blue S5 DSG Sports Diff (SOLD)
    2011 Ibis White A5 (SOLD)
    Senior Member Three Rings Creatre's Avatar
    Mar 18 2012
    Summerville, SC
    Quote Originally Posted by offthewall View Post
    This.
    Also, you have to drive the DSG like you drive a manual car. When you realize this and begin to do so, it drives very sanely and quite nice.
    Feb 22 2004
    West L.A.
    Quote Originally Posted by Creatre View Post
    I think this point can't be stressed enough... I had extensive time driving my father's B8 S5 cabriolet prior to acquiring the S4, so I knew about its inherent quirkiness beforehand. You can't expect the DSG gearbox to act like a conventional automatic, so you definitely have to adapt your driving style to it (in between a MT/AT).
    -Mike-
    Instagram: creoucla
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    This is my first Audi and first DSG car. I noticed what you described as well with my car. In heavier traffic I may coast up to the light and sometimes I would notice exactly what you are describing. I notice it even more at the metered onramps that we have here in Phoenix. I will roll up to the light and the car will kind of jurk like its trying to figure out what gear it wants, especially if I give it a little heavier throttle.
    I have just learned to drive around this or I may just pull the left paddle and go down a gear if that is what I want. Seems normal and like others said the DSG is trying to behave like a MT would.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Mar 25 2013
    Philadelphia
    I usually drive manual cars myself and I know that its kinda hard to get the car in first gear when its still moving in a manual car. I also understand that our Dsg trans are basically an automated Manual and behaves and has the same characteristics of a manual, thus the "harder to get in 1st gear scenario" My main concern is I dont mind it re-accelerating back in 2nd gear at a stop sign or whatever, but what if im in a pretty emergency situation? just like another member has mentioned,, metered expressway onramp.. I can't afford to let the car take its good old time to accelerate from D2 or S2!! This isnt why I bought a 333hp supercharged v6 for and to make it worst, I have a Stasis Tune in my car, which means im getting a slow accelerating 400hp car now.. lol I've been driving it a bit more kinda getting use to the accelerating "characteristics" but it just bothers me to know that I dont have that instant on demand power that I expected from a 400hp car. I got to experiment a bit more, maybe I need to really pedal to the medal it which I rarely do.
