kind of both, I had some other issues going on as well. We changed the cvt fluid thinking that was it, and it drove great, then it started acting up again around the same time we changed the valve cover gasket and cct gasket. Got progressively worse after that. I thought we had messed something up when getting the chain to tdc, but now I'm throwing this code. So i don't know. It's been off and on. It is possible I had a leak and something finally broke. We should look around and make sure something didn't indeed break or come loose. I had to work tonight otherwise we would have done that first thing. (we, being my father and I). I need to figure out what to do though, so i can try to get the parts by this weekend. It's driving, just really rough. It started not wanting to reverse out of my driveway about 2 weeks ago. You seriously have to mash the gas, because its up hill to get out. But it takes revving it really hard to get it to move.
it makes me wonder though, because we heard something break when we were fixing everything but we couldn't find what it was. Sounded like plastic so we figured it was probably a clip, because we couldn't see any obvious leaks. We may just need to take everything out and inspect it. Car idles so rough I highly doubt any other test is going to make a difference. I also just ordered a maf, because when I went to clean it it looked corroded. Would a bad maf throw this code? Obviously it can cause your fuel mixture to ruin it...but hey i've seen weirder things.
