Page 1284 of 1284 FirstFirst ... 284784118412341274128212831284
Results 51,321 to 51,328 of 51328
  1. #51321
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    thanks guys, im thinking about doing one last bbq for the season.
    Eurosport Tuning at it's Finest
  2. #51322
    Veteran Member Four Rings EnigmaS5's Avatar
    Oct 29 2012
    Bethesda, MD
    Looks great Rich!
    Sent from.....where am I?
    Your DC/MD/VA Realtor
  3. #51323
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Quote Originally Posted by Cgoon009 View Post
    I'm in
    /// 2012 S4
    RocEuro (44.5k mi) | AWE/GIAC Stage 2 (49k) | 19" Titanium Rotor Wheels 10mm H&R spacers (58k) | RS5 BBK & ECS 2pc front/rear wave rotors (59.5k) | Renn RS-51 19x8.5 20.5lbs (65k) | JHM LW/HD Pulley (67k) | MMI 3G+ rev. G and B8.5 MMI controls retrofit (81k) | vagcom stuff
    Mid-Atlantic Forum (MD/DC/VA)
  4. #51324
    Veteran Member Four Rings Avant4me's Avatar
    Aug 09 2011
    NOVA
    dang what are you doing?
    Started with I need to replace a front CV Boot.
    Which lead to replace front struts, which turned into well lets finally install that new oil filter housing and new gasket Ive had for a year, which led to replace the turbo coolant feed line that Ive had sitting around for a year which lead to....hey lets do a carbon cleaning...
    Who knows where this will lead or if my car will ever run again
    ~2007 DTM A4 S-Line Avant, 6MT, Stasis cat back, RAI downpipe, JHM Stage2 93, JHM HPFP, HFC, APR snub mount, 034M SD Motor mounts, RS4 RSB, VMR 708 19x8.5 ET35 245/35/19, B5 perches, NEUSPEED sport springs ~
  5. #51325
    Senior Member Four Rings q5 dave's Avatar
    Dec 15 2014
    driving
    Do eetttt! I got an awesome new bbq so happy to bring foods.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    IG @q5ds
  6. #51326
    Aug 09 2011
    NOVA
    Valve cleaning via gun gear lol
  7. #51327
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by Avant4me View Post
    Cool, I forget what brand that a tech used but gun cleaning solution does work. Try filling the port, put a bunch of zip-ties into an electric drill, and then run the drill to spin the zip-ties in the port. It works for a quickie carbon clean.
  8. #51328
    Aug 09 2011
    NOVA
    Thanks for the tip! Ill give it.....a whirl
