Results 1 to 13 of 13
    Oct 15 2014
    Northeast OHio
    Wife's A4 issues....
    Before you say "oh, god not another vibration post" here me out. I have owned several german cars in the past and maintained them all myself. I've generally been able to tackle everything without issue, but this one has me frustrated. I've tried to be methodical in troubleshooting this.
    Here we go:
    1. Wife's '07 A4 quattro 2.0T sedan with 89k miles.
    2. In the last 3 weeks there has been a vibration present when braking. Either lightly touching the pedal all the way through full application from what sounds like the front right wheel only. The vibration is not present in the pedal but in the steering.
    3. At first i lifted the car up and tugged on the wheel at 1/3 & 12/6 and was sure I felt a little play on the inner tie-rod. I took it to the dealer and they said "you need all new pads and rotors" and it's not the tie rods. I don't buy it, but.....
    4. I went home and took off the front right ate rotor (ate rotors and akebono pads were replaced 35k ago) and replaced the rotor with a new Freemax. Vibration was still there exactly as before the rotor change.
    5. Wondering if the pads were part of the issue i swapped the front left pads with the font right pads and experienced the same vibration.
    6. I did notice the right hand caliper boots seemed looser than the other side, so I installed new boots and guide pins in the caliper. Vibration is still present, exactly as before.
    I drove around with the car for about 30 minutes today and payed very close attention to what I was experiencing. Here's what I have confirmed.
    - The vibration is present at all speeds when braking, light touch on the pedal or heavy pressure. Braking vibration frequency at 60 mph feels similar to bad wheel bearings (in other cars when turning). About 15 pulses per second id guess.
    - The vibration/pulsing slows down in frequency and intensity as speed slows and when dropping below 10mph i feel a grind or hesitation (like an abs pulse in bad weather).
    I'm not terribly familiar with the suspension components in the car but i've heard that worn suspension components can contribute to this vibration. Any thoughts?
    Part of me wonders if I have an ABS or wheel sensor issue even though there are no lights on.
    Any thoughts are welcomed.
    - Jonathon
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    Have you had your tires rotated recently? When was the last time they were balanced?
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    Check the caliper assembly. New rotors and pads won't fix anything if the caliper is cracked or loose. Something to check anyway.
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    1. Did you properly seat your pads?
    2. Have you ever heard of Brake judder?
    Read this it's probably your problem. http://www.powerbrake.co.za/download..._01_judder.pdf
    -Chadwick
    FULLY BUILT ENGINE!
    Oct 15 2014
    Northeast OHio
    New tires were installed and road force balanced in June of this year.
    Quote Originally Posted by AKO View Post
    Oct 15 2014
    Northeast OHio
    Yes, the pads were properly bedded.
    I have never heard of brake judder, but wouldn't that go away when I replaced the rotor? I take the air wire wheel to the hub every time and coat the hub with anti-sieze as well.
    Based on this article, perhaps I should re-install the rotors and put new pads in too...thoughts?
    Quote Originally Posted by FraggyA4 View Post
    Mar 03 2012
    Jeep Comanche
    Quote Originally Posted by jonohio View Post
    If you had it on the old rotor then your pads wore accordingly to that. So on the no rotors it would cause weird braking. Also you can get deposits on the pads after braking on bad rotor. So typically you would want to start with a clean slate.
    -Chadwick
    FULLY BUILT ENGINE!
    Oct 15 2014
    Northeast OHio
    So do you think I'm I safe to assume the suspension components are a zero factor?
    Mar 03 2012
    Jeep Comanche
    The biggest issue our cars have with suspension is usually the control arm, and that makes a clunk that will drive you nuts.
    -Chadwick
    FULLY BUILT ENGINE!
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    The car has 90k on it. More than likely it needs a front end refresh. When you raise the front end, look at the upper control arm bushings. If you should see a nice split in the rubber bushing, plan on replacing those soon. Remove the tie rod from the steering knuckle. If the inner tie rod cannot support the weight of the outer tie rod, consider replacing.
    From the way you've described it, I would look at the tie rods. Just outta curiosity, do you have to make corrections in the steering to keep the car tracking straight?
    Aug 30 2013
    Our cars have clunks that a front end refresh won't fix, either. I put all new control arms, tie rods, you name it, all in the hopes of ridding myself of clunks, to no avail. Don't forget the stupid loose calipers that wear out around the caliper guide pins - that causes clunks, too.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    According to your explanations, it sounded like the culprit lies within the brake system, and correct me if I'm wrong but this is 'brake pulsation' transferring in to your steering wheel. I think your issue should be resolved with ORIGINAL OEM AUDI BRAKE PADS and ROTORS. Uneven or the slightest warped discs will completely throw off your new pads and generates unwanted pulse/vibrations.
    For the meantime, you can try doing this but I doubt it will hold...
    http://www.instructables.com/id/Get-...-when-braking/
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Mar 03 2012
    Jeep Comanche
    Quote Originally Posted by JayDog747 View Post
    I'm at 130k and my front end is fine, it's not uncommon to go 150k on front end except for the case of the control arms and shocks & struts.
    -Chadwick
    FULLY BUILT ENGINE!
