Results 1 to 15 of 15
Hybrid View
    Senior Member Two Rings blackmage's Avatar
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    Which size should i get
    Alright guys, long story short I am getting a set of Nitto NT421Q's. These are the ONLY sizes i can choose from, which ones should i go with? I have the stock 17" double spokes on my 03 allroad.
    http://www.nittotire.com/Tire/nt421q#size
    DRIVE A HYBRID MY MUSTANG NEEDS YOUR GAS
    -95 Mustang GTS - Sold :(
    -96 Mustang GT - 4v swap
    -03 Audi Allroad 6MT swapped, stuklr tuned
    Senior Member Three Rings redge2.7t's Avatar
    Jun 24 2010
    VW Atlas
    Folsom
    Can't see what sizes those are, keeps just going to the mobile site. But I would go for like a 235/45 or a 225/45 if they are available.
    Current- Vesuvius Grey C8 S6 Prestige- APR Carbon Intake, APR Tune, ECS Spacers
    Former- Quartz Grey B8 A4 Avant_Prestige_S-line_(1 of 7) REVO Tune, aFe, ECS TIP, RS4 Grill
    Former- Stage 3- C5 A6_too many mods to list.
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    235/60 or 225/60 are the closest to stock.. 255/60 also :p
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    225/60R17 is the only size of the group I would even consider.
    I think the other 2 sizes you listed would be too tall.
    Jun 24 2010
    VW Atlas
    Folsom
    ^ isn't 60 the highth? The 225,235, etc is the width if I'm not mistaken.
    May 30 2008
    Honda HRX
    Penna.
    no. its a ratio, called the "aspect ratio" it basically means one sidewall is 60% of the first number (which is the width in millimeters) so as you go wider, the tire gets proportionally taller too. so to run a 255, he would probably want a 255/50 if it were an option.
    even the smallest option which is the 225/60R17 is already about 1" taller than stock.
    Jun 24 2010
    VW Atlas
    Folsom
    Nice! I learn something new every day! Thanks for the info!
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    this is a 215/70/16...
    May 30 2008
    Honda HRX
    Penna.
    Which would be roughly equivalent to a 215/65R17 which will actually be similar in height to a 225/60R17
    Whats your point?
    Since we are posting random pictures... This is a 245/40R19:
    Sep 11 2009
    NE
    Quote Originally Posted by EErie B6 View Post
    Whats your point?
    More random, 285/35R19 on 11" rim in the back, 255/40R19 front:
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    wow just showing an example of a taller tire. sheesh lol
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    no need to be a dick. This guy is running a 225/60/17 so i may go with that option.
    http://www.audizine.com/forum/showth...oes-for-the-ar
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by blackmage View Post
    yea that was me . . .
    the 225/60 was a good size, dont see why a 235/60 shouldnt fit, might have rubbing issues on the hub assembly
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Sep 11 2009
    NE
    Go to this site, enter stock size tire and it will show you all available sizes wit proper rolling diameter... and remember, so long you have all four wheels the same, don't be shy going up to 3% more or even more below it if you really want/have to.
    http://www.alloywheels.com/Tyre_Calculator
    Dec 24 2012
    96 Mustang GT - 4V
    Northern Wisco
    went with the 225/60/17.
    level 1 with stock tires
    level 4 with stockers
    level 1 with new tires
    level 4 with new
    They seem to fit the wheel wells pretty nicely and don't rub at all. the 235 would have probably cleared, but it would have been close.
