Results 1 to 6 of 6
    Established Member Two Rings darecy's Avatar
    Jan 10 2012
    poland
    Climate Controll 3 zone retrofit
    For the last 2 days I was retrofitting 3 zone climate control to my A4 B8 (1zone previously) - newer again, so much staff out.
    All components and dashboard had to go. I managed to dismounted half components from the old climatronik, and add all missing motors, tubes and sensors.
    3 zone climate control was working nearly with no errors but:
    I haven't got the quality sensor installed and only one error in module 08 HAVC
    only one error - 01592 - Air Quality Sensor (G238) 004 - No Signal/Communication
    I have to read HAVC module adaptation list and I hope I find out how to uninstall this sensor.
    This is more important:
    Some how I lost outside temperature connection or info. No display on fis or in climatronic measurement blocks?! I didn't touch the outside sensor and after retrofit I plug all the connection back to the dash components- (I hope i did it)
    And I have this errors:
    Address 01: Engine Labels: 03L-906-019-CAG.clb
    Control Module Part Number: 03L 906 019 AL HW: 03L 906 019 AL
    Component and/or Version: R4 2,0L EDC H21 9097
    Software Coding: 12194012232403080000
    Work Shop Code: WSC 10513 000 16456576
    ASAM Dataset: EV_ECM20TDI03L906019AL A02008 (AU48)
    VCID: 75E5E5E76701
    1 Fault Found:
    4923 - Please Check Fault Codes in Instrument Cluster
    U1024 00 [039] - Open Circuit
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 71419 km
    Date: 2013.06.25
    Time: 16:23:10
    Readiness: 0 0 0 0 1
    When I check in module 17 (instruments) - no errors :/
    I have done in basic settings in HAVC channel 1 and 3.
    There is no temperature display, no cold air from climatronik , all internal sensors and motors and valves works OK.
    Any suggestions?
    photo from my work
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Sorry, can't help, but holy shit. I can't believe you did all that just to get 3 zone climate control.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Jan 10 2012
    poland
    I had to done it because I retrofitted ventilated seats before. Therefore climate control has to be changed to 3 zone ones to control the fans in seats.
    When I did that it produced 12 errors because 4 motors and 2 sensors missing.
    It not difficult job and cheap, but time consuming :(
    Jan 10 2012
    poland
    OK, I have done it. The ambient sensor was off in MCE 09
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Congrats. You're a braver man than me.
    '11 S-Line A4 Avant
    Jan 10 2012
    poland
    Thanks,
    Does anyone know how to switch off air quality sensor in module 08 hvac?
