Results 1 to 17 of 17
    Established Member Three Rings BillyT's Avatar
    Apr 09 2013
    San Francisco
    What's everyone's take on the JHM 4:1 Center Diff? Is that a popular mod at all?
    Or more of a rare personal preference kind of thing?
    Seems cool to cut down understeer but I didn't really dump my Mustang for an AWD car only to go back to peeling out at lights or fishtailing in the rain.
    2005 S4 Cabriolet 6MT - Corsa Catback, Stasis Ohlins Suspension, VMR v710 19x8.5" Wheels, JHM Shifter Trio, JHM Intake Manifold, Throttle Body & Spacers, JHM "piggie" Downpipes, JHM Lightweight Crank Pulley, JHM Lightweight Front Rotors, JHM 91 Octane Tune, 034 Snub Mount, K&N Filter with Airbox Mod, 15lb Odyssey Battery, OEM Clutch - 1/4 mile: 13.6 @ 100 mph.
    Veteran Member Four Rings lunamarA4's Avatar
    Feb 25 2004
    lots of tools and spare parts
    San Diego, CA
    JHMs 4:1 center diff is far from a RWD!
    love mine
    4 SALE B6/B7 parts
    RafE |2004 BT White A4 Avant|
    |2002 S8 6spd - fully overhauled + 6 spd|
    |1988 E30 S52 Pandem Kit|
    |1991 E30 M20 Touring|
    Veteran Member Three Rings auxnbus's Avatar
    Feb 13 2010
    '15 BMW i3 REx, '11 Toyota Prius
    Carmel, IN
    Hands down one of the best mods you can do to a B6 S4 IMHO. The car remains very stable in even snowy/icey conditions with a careful foot (actually a bloody blast if you're feeling brave). You won't even feel it until you are pushing the car past say 7/10ths in the dry.....maybe 6/10ths in the rain. That's when you really feel the difference - the car tends to pivot more than push. Prior to the mod I had a tough time kicking the rear end out, but now a generous stab of the accelerator mid-corner will - very predictably- send me into a tailslide.
    You're not going to completely eliminate understeer, but the mod allows you to steer with your foot a whole lot better.
    That said... if you aren't one to either; attack corners aggressively on the street or track/auto-x your car, there is no point in getting the modification done.
    2015 BMW i3 REx
    2005 Audi S4 Cab - Gone but not forgotten
    Apr 09 2013
    San Francisco
    Quote Originally Posted by auxnbus View Post
    It's cheap too at $350.
    http://jhmotorsports.com/shop/catalo...only-p-46.html
    I find taking the same corners and freeway ramps at the same speeds I did with my Mustang a bit unnerving. I assume that's the understeer everyone talks about.
    Mustang was also 700lbs lighter though too. But it was also a death trap in the rain.
    The part that sticks out the most to me is this: "This is the same bias ratio that Audi has provided in the stock RS4 driveline."
    Seems like that says a lot.
    Feb 13 2010
    Carmel, IN
    Quote Originally Posted by BillyT View Post
    I got mine during JHM's holiday sale for a decent amount off - then they offered an additional discount for sending in my core to be worked on (short supply of Tiptronic diff cores). Ended up getting the mod done for like $375 total including labor @ my Indy shop. Best bang for buck mod I've done thus far.
    2015 BMW i3 REx
    Veteran Member Four Rings SurferD's Avatar
    Apr 30 2007
    18Forester XT touring, 03-F150 XLT, 71-240Z
    Orange, CT
    Even though the later B7's T3 already came with a 4:1, I have a pre-prod modified unit installed that JHM will be releasing.
    It's shimmed to provide even more rear bias.
    I haven't gotten the chance to autocross it yet but I can tell you when accelerating hard around a corner I can get the rear to oversteer like a RWD car.
    It's a really good and fairly easy to install upgrade.
    But as JHM says if you're darg racing the car it's not for that.
    Currently: 2017 Q7 Prestige 3.0 with APR tune.
    Formerly: 2007 S4 Avant 6MT; 2002 S4
    Senior Member Three Rings yObOyGeo's Avatar
    Mar 13 2012
    Prius
    Boston, MA
    Sorry for my ignorance but I've never heard of this 4:1 rear dif.. What is it ?!? RWD ish ??!!
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Quote Originally Posted by yObOyGeo View Post
    Center, not rear, diff; gives a more rearward bias.
    Old Geezer, formerly known as Stud Muffin
    Mar 13 2012
    Prius
    Boston, MA
    I'm guessing 4to1 instead of 2 to1 ? This sounds interesting ..
    Apr 09 2013
    San Francisco
    "The factory torsen center differential in the S4 and A4 provides a 2:1 torque distribution between front and rear. What does this mean? This enables the end of the car that still has traction (most of the time the rear) to deliver double the torque to the tires with traction. JHM's experience has found that this closer to even distribution is best for drag racing. So this modification is not for you if you are into drag racing primarily. However for Auto Crossers, Road racers and others who prefer the twisties JHM recommends a bias ratio of 4:1. This is the same bias ratio that Audi has provided in the stock RS4 driveline.
    So if you are tired of going through corners while using a lot of throttle and still getting "understeer" then this product is for you and will help you get a little more "oversteer" and allow you to drive the car a little more like a RWD car but still have the superior control of AWD."
    I posted the link above.
    Feb 13 2010
    Carmel, IN
    The stock diff is capable of delivering up to 66.67% of available torque to the either axle (whichever has the most available traction) in any given scenario. With the modification, that number changes to 80%. I know it doesn't sound like much of a difference, but you sure can feel it!
    2015 BMW i3 REx
    Apr 09 2013
    San Francisco
    How many hours labor?
    Feb 13 2010
    Carmel, IN
    My shop charged 1.5 hours. They removed it, shipped it to JHM, kept my car in their shop for a few days, and reinstalled it.
    2015 BMW i3 REx
    Mar 13 2012
    Prius
    Boston, MA
    So .. what youre saying is .. sideways
    Veteran Member Three Rings ProgMetalHead's Avatar
    Apr 25 2009
    2007 Brilliant Red S4, 6MT
    Toronto, Ontario, Canada.
    It is stock in the RS4, yes, but also stock in 2007+ Manual S4s.
    Your car will have a 40/60 power split, front to back, in regular conditions.
    '07 Brilliant Red S4, 6MT
    | FI DPs w/cats | FI CB w/18" Vibrant Res'| JHM Tune w/94 Octane | JHM LWCP | Optima Redtop (31.7lbs) |
    | JHM LW Front Rotors | Hawk HPS Pads |
    | Koni Yellows w/H&R Sports | 034 Adj. Upper Control Arms | 034 Strut Mounts | Hotchkis Adj. RSB (29mm) w/034 Adj. End Links |
    | 19" VMR V708s (Silver) w/Potenza PPs | JHM SS w/Stainless Knob | Apikol Snub Mount | 034 Engine Mounts | Apikol Rear Diff. Mount | 034 Trans. Mount | RS4 Pedals | 30% Tint |
    Mar 05 2013
    2005 4Runner V8
    Island County, WA
    Quote Originally Posted by ProgMetalHead View Post
    ... also stock in 2007+ Manual S4s.
    Is it any 2007+ 6sp or is it a VIN range?
    Veteran Member Four Rings Jdsb6s4's Avatar
    Aug 27 2016
    GL450, GLA250
    I always thought the better route would be the rear LSD first... that stuff is still uncharted waters for me
    AM Tuned Supercharged Audi S4 Avant track car. Under Construction
    Tuned by Jackal Motorsports
    Time Attack driver
    jasons__s4 IG
