Results 1 to 13 of 13
    Registered User Four Rings GMP Performance's Avatar
    May 11 2009
    Charlotte, NC
    P3 Cars Digital Gauges for the Audi B6 S4 and B7 S4 and RS4 from GMP Performance
    Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
    Each gauge is specifically designed to support each car's individual details, so there is never an weak point in the data being sent to you. This awesome little gauge is for the Audi B6 S4 and the B7 S4 and RS4 models
    Plug and Play install
    Quick plug and play install with zero cutting required. All power, ground, and data points come directly from the diagnostics port connector
    Boost/Vacuum Display
    High resolution boost/vacuum via diag port for FAST install. Optionally read boost via boost tap (not included).
    Multiple Gauge Displays
    Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
    Peak Recall & Run Record
    Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
    Universal Aux Inputs
    Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
    On the Fly Configuration Menu
    Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
    To see more, click here! B6 S4 and the B7 S4 and RS4
    About P3 Cars
    P3 Cars exists to manufacture and provide enthusiasts with ultra high quality custom integrated gauges that have been tried, tested, and are found to out shine and out perform the competition. P3cars has grown to become the #1 most popular resource for integrated Volkswagen, Audi and BMW gauges! We make the best custom integrated gauges you will find, period.
    P3=Precision, Passion, Performance
    Oct 11 2007
    Suburbia
    this looks really cool!
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Veteran Member Three Rings Apat's Avatar
    Jul 04 2011
    B7 S4 , 97 A8, 99 A4 Avant
    Minneapolis, MN
    Does it display oil temps? The B7 S4 has a factory sensor but no display for it. If you want to sell these to this market this is the feature the majority of us are concerned with.
    2005.5 S4 MT - Apikol snub mount // Apikol rear diff mount // Stern tranny mount // JHM Tune // JHM Intake Manifold and Spacers // JHM "Solid" SS // JHM Stage III Clutch and LWFW // Trex DPs // Fast Intentions 2.5" X-Pipe Cat Back w/ 14" Resonators // PSS9 Coilovers // 034 Rear Sway // 40% 3M tint // Lamin-X "tint" headlights and "gunsmoke" taillights // 19" Neuspeed RS10 summers // 18" VMR V710 winters
    May 11 2009
    Charlotte, NC
    Quote Originally Posted by Apat View Post
    I am not sure. Let me message them and see what I can find out for you.
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Don't think it does yet. It didn't when they came out with it and I know they were considering putting it in but I'm pretty sure STE is still the only one with oil.
    May 11 2009
    Charlotte, NC
    The way that this gauge works is it picks up on any sensors that are rapidly updating. This feature has been seen to work on some vehicles, yet not on others. There are several factors that go in to play when this gauge scans for its data. However after speaking to the manufacturer on the phone, they are planning on releasing a free frimware update (currently in development) for this feature to display on ALL B7's.
    So basically to answer your question, it may show oil temps right now, or it may not, but it will in the future.
    Sep 13 2008
    Western Chicago Burbs
    It's basically an Aeroforce gauge.
    Veteran Member Four Rings 0000 V8's Avatar
    Feb 19 2010
    Porsche Cayenne Turbo, B6 S4, C5 Allroad, B5 A4, Prius C
    Sacramento, CA
    Are these modular? As in do you have one for or will these fit the C5 Allroad? I need transmission temp at the ready. It would be perfect if I could get a boost gauge and tranny temp gauge in one.
    May 11 2009
    Charlotte, NC
    Don't hesitate to PM us for more info!
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by 'GMP Performance"
    Can you show pictures?
    May 11 2009
    Charlotte, NC
    Quote Originally Posted by JimmyBones View Post
    Here it is installed in our A4
    I don't have a picture of the plug when installed, but here is a picture that shows the plug itself.
    May 11 2009
    Charlotte, NC
    Be sure to message us for any additional information!
    Junior Member Two Rings
    May 19 2019
    Uk
    Hm are they? Interested
