Results 1 to 27 of 27
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    Tire cracking issue, need insight
    Hey guys,
    I'm having an issue with my tires cracking. Not really sure why, considering they are only about 2 years old and have plenty of tread life left. I checked the pressure in all of them and they are what they should be running at.
    A couple of things that could be an issue:
    I run 20mm spacers in the rear and 15mm in the front.
    These are nokian WR tires and they are a softer compound that is somewhere in between summer tires and snow tires. These tires are meant to be run all year long.
    Also with this kind of damage what can I expect down the road?
    Thanks Guys
    -Chadwick
    FULLY BUILT ENGINE!
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: Tire cracking issue, need insight
    Those need to be replaced, that is a safety hazard.
    Looks like they will come apart sooner rather than later.
    Sent from my DROID4 using Tapatalk 2
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    May 16 2008
    South Texas
    It's likely those tires have met their useful life. Even though they have been on your car for 2 years, they could very well have been warehoused for who knows how long. The cracking will continue and eventually the tread will separate at the most inconvenient moment.
    Mar 24 2013
    Oakdale, CT
    Is your car normally parked outside and exposed to sunlight or is it typically garaged? Also, what types of products do you put on your tires?
    -Adam
    Jul 19 2011
    Northern Minneapolis, MN
    That's a real bummer. If you bring them back to where you bought them, they will sometimes give you a percentage of the price towards new ones based on tread
    Veteran Member Three Rings cheemn's Avatar
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    Quote Originally Posted by CorneliusRox View Post
    X2 and DONT drive with those tires. You can check the manufacturing date of the tire too to make sure the shop didn't sell ya old tires. Either way the shop who sold them BETTER "do something" for ya.
    Jul 17 2011
    Sin City, USA
    The cracking is indicative of Dry Rot. Normally seen on tires that are stored for a long period of time or on a car that is not driven regularly. As the others have said, do not drive on them! Separating a tread at highway speeds will not only cause you to mess your pants, the rubber will damage the body of the car, you may loose control, etc.
    '09 C6.5 A6
    Mar 03 2012
    Jeep Comanche
    Some bitch, well this isn't the most convenient time to replace my tires. Any body have suggestions on a cheap replacement?
    Also do park out side but I drive my car regularly. The only product I put on my tires is the Meguirs tire shine.
    I'm thinking these tires sat for a while before they were put on my car. I'll be going back to the place that I bought the tires from. I'm hoping they don't screw me though because I've never had them rotated.
    -Chadwick
    FULLY BUILT ENGINE!
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    Not rotating them has NO relationship to what has happened to your tires. As others have stated your pics show a tire that just looks old. Check the manufacturing date stamped on the sidewall before you go into the store.
    Mar 03 2012
    Jeep Comanche
    Well this is happening on all 4 tires...So I will check it out. Looks like I'm pedaling to work this week.
    -Chadwick
    FULLY BUILT ENGINE!
    Mar 03 2012
    Jeep Comanche
    They were manufactured in 2008 making them 3 years old when I bought them. Which makes some of them 5 years old now.
    -Chadwick
    FULLY BUILT ENGINE!
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    Hmm odd shouldn't have fallen apart like that so soon but yeah you can make a point of that to your shop. Update us on what they say etc.
    here is some info for ya I guess.
    http://www.safercar.gov/Vehicle+Shop...ing/Tire+Aging
    Mar 03 2012
    Jeep Comanche
    Well Nokians are a different kind of rubber, they use natural compounds so that the tires are greener for the environment. So I guess I could see them prematurely cracking.
    -Chadwick
    FULLY BUILT ENGINE!
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by FraggyA4 View Post
    If the tires sat in a warehouse for 3 years and were not properly stored; Add to that the fact that they are a "greener" rubber..... Dry Rot it is.
    '09 C6.5 A6
    Mar 03 2012
    Jeep Comanche
    yup I think I have a pretty good case to take to the tire place. I would expect to get 50% of my money back towards a new set of tires.
    -Chadwick
    FULLY BUILT ENGINE!
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    informative thread...I've never had to deal with dry rot so this was all new to me.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Jul 19 2011
    Quote Originally Posted by mcpcartier View Post
    Also, if you guys are every goign to havea car sitting, or just for the hell of it because it makes them look new. Spray on this stuff:
    Westley's Bleche Wite
    It doesnt leave your tire shiny, but it makes it look new, and I have used it for sitting trailers before. It really does work great at reconditioning the rubber.
    Mar 03 2012
    Jeep Comanche
    I think I'm going to try and trade out for these
    http://ssl.delti.com/cgi-bin/rshop.p...mpaign=froogle
    -Chadwick
    FULLY BUILT ENGINE!
    Mar 03 2012
    Jeep Comanche
    Good news, I talked to the store and they are going to give me the the money towards my new tires. Looks like I have about 55% left of the tire so I will be getting my new ones 50% off. Still sucks but I guess I'll have new tires that should last me till I get rid of the car.
    -Chadwick
    FULLY BUILT ENGINE!
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    That's good. Seemed like the shop stepped up and at least went half way.
    Mar 03 2012
    Jeep Comanche
    Yup they have proved themselves a worthy shop to work with.
    -Chadwick
    FULLY BUILT ENGINE!
    Veteran Member Three Rings schmiesus's Avatar
    Jul 25 2011
    BC
    Quote Originally Posted by cheemn View Post
    They're doing what's standard warranty practice in the tire industry for manufacture defect. You pay for what you used basically.
    2007 A4 S-Line TI Brilliant Black - .......Not Stock
    Bought Not Built, Build!
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by schmiesus View Post
    Dry Rot is generally not covered under a manufacturer warranty since it is not a defect in the manufacturing of the tire but could be claimed that they were not maintained properly after the sale.
    OP, good for you on getting half off your new set!.
    '09 C6.5 A6
    Jul 25 2011
    BC
    That looks like a seperation from what I can see. Dry rot you usually see it going in many different directions not usually the same all the way around. ALSO is extremely unlikey you would get it on a tire under 10years old with the current rubber tech. Mind you anything is possible and with some of the off shore tires popping up you can get a whole host of new issues from the varying conditions found in the USA alone.
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    stupid tree huggers
    2018 A5 S-Line Manual
    Mar 03 2012
    Jeep Comanche
    Quote Originally Posted by konarider94 View Post
    stupid tree huggers
    Stupid Finns
    -Chadwick
    FULLY BUILT ENGINE!
    Jul 19 2011
    stupid tree huggers
    Talk like this is why you were invited to the festivities next week ha ha
