Page 124 of 128 FirstFirst ... 2474114122123124125126 ... LastLast
Results 4,921 to 4,960 of 5103
  1. #4921
    Apr 29 2018
    Michigan
    Wheel bearing took a giant
  2. #4922
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    What Went Wrong With Your B6 Today?..
    Power steering pump started whining again. Have already purged system. Didnít work. Then I flushed the system. Worked for 2 days.
    So obviously Iím still getting air in the system. Lines seem tight, quick tug doesnít budge them. Bought a new Bosch ZF pump and reservoir seeing as how that would be the next step in the process.
    Almost looks like I have some wetness right around the pulley, so Iím hoping that is the entrance for the air.
    Will put better clamps on the low pressure side to the pump. Weíll see what happens from there.
    At the end of this all, I really hope I donít have to replace the rack. From what experienced guys say, itís a pain in the rear.
    Sent from my iPhone
    2003 A4 1.8T 5-spd w/ Motoza 93/E85.
  3. #4923
    Senior Member Two Rings projectvoltron's Avatar
    Apr 15 2012
    B6 Avant 2.7t, 2016 VW Tiguan
    Grand Junction, CO
    Quote Originally Posted by jpulll View Post
    Sent from my iPhone
    Good luck with that!
    His: 2005 A4 Avant 2.7t
    Hers: 2016 VW tiguan
    Sold: 2001 noggy b5 s4
    RIP: 2004 B6 s4 sedan
    "It could be a number of things" -anyone who has diagnosed their Audi
    instagram @chasetophor
  4. #4924
    Dec 28 2006
    '03 A4, '13 A5, '18 MB-GLA
    Western Maryland
    Try some Lucas Power Steering Stop Leak and Conditioner. It certainly won't hurt anything. You have nothing to lose and it may help your whining problem. It is one of the few additive products that I have found to actually do what it claims.
    A4 Motoza tuned Frankenturbo F21L / Bosch 550's / 3" MAF / TyrolSport SMIC / 034 HFC / TT 2.5" DP / Borla / Eibach ProKit / Koni Yellows / H-Sport F&R Bars / TyrolSport Brake Stiffeners / HyperShift Short Shifter / Podi
  5. #4925
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    I second trying some Lucas Power Steering Stop Leak. My system was leaking pretty bad, one bottle cleared everything up. Couldn't believe the results. No more leaking, no more whining.
    2005 USP A4 Avant 1.8T Follow me on instagram @cbarz
  6. #4926
    Jun 19 2014
    Ohio
    I donít appear to be losing any fluid though. I just have foamy fluid. The flush kind of concluded that because it worked for 2 days but bubbles slowly started appearing.
    The pump only whines with the bubbles. The pump also has a small wet spot on the pulley shaft. Right at the end where the o-ring would be. So I can understand how air could slowly get sucked in there.
    According to friendly google, the supply hose has a suction effect brought upon by the pump. So itís possible air is getting sucked in that way as well.
    When I get the reservoir/pump, Iím going to replace the reservoir and put screw style clamps on the supply hose and do another flush. If that fails, the pump is coming out.
    Sent from my iPhone
  7. #4927
    Dec 28 2006
    Western Maryland
    I would still give the Lucas a try. It can help swell the seals on the suction side of the pump and maybe stop the air from getting pulled in. There is no downside to using it.
  8. #4928
    Active Member One Ring Paradoxy's Avatar
    Feb 24 2015
    Long%20island%20NY
    so all the sudden my diagnostic (obd) port stopped working...
    still have power since it will light up the vag401 tool but will not connect at all
    tool works fine on a beetle and jetta we got here
    stock radio, never taken out, only light on the dash is from an incorrect flow code i know for sure
    no other lights at all which makes me think the port itself might be dead?
    car runs perfectly
  9. #4929
    Established Member Two Rings Jakal's Avatar
    May 27 2016
    Michigan
    Got my VCDS today. Havenít been able to find out why my turbo seemingly doesnít spool. Possibly spools in higher gears. (I really canít confirm besides what I feel/hear)
    Got these 2 codes:
    ē 17887 Brake Boost Vacuum System
    P1479 - 008 - Mechanical Failure
    ē 16683 Boost Pressure Regulation
    P0299 - 002 - Control Range Not Reached
    Now Iíve read it could be the pump, or the lines running to it or even the DV.
    Iíve also heard you can test the vacuum pump in VCDS? While driving, Iíve found that the vacuum pump is always off.
  10. #4930
    Aug 27 2013
    Philly
    3rd time in a month that my car refused to let me fill up. Not sure whats going on. I really need to get better at keeping some more fuel in my tank so Im not at 15 DTE when refueling.
    2003 3.0 6 Speed - Quattro. 157k.
  11. #4931
    Jun 19 2014
    Ohio
    Quote Originally Posted by SJorge3442 View Post
    The fuel tank is pressurizing and refusing to allow new fuel to enter. Hold your finger on that little silver door before you fill up to allow the pressures to escape.
    AFAIK it is involved with the evaporative system.
    Sent from my iPhone
  12. #4932
    Aug 27 2013
    Philly
    Sent from my iPhone
    Yeah its just weird its got me 3 timed in a row. Left the nozzle in on an angle for like 5 minutes and it worjed.
    Sent from my LG-H871 using Tapatalk
  13. #4933
    Senior Member Three Rings 2004a4b630QT's Avatar
    Mar 30 2015
    '04 A4 3.0 QTip
    Was introduced to the dreaded dying SAI pump howl on startup. standing over the engine it gets louder towards the firewall. Touch the accelerator and it goes away. It's at the bottom of a long list.
  14. #4934
    Mar 05 2013
    CA
    Depressed the clutch pedal with the door open and heard it making a sound from outside the car.
    I'm guessing it's supposed to be quiet when new and normal. Am not sure what it is.
    The slave cylinder is probably old and original.
    I know the pedal makes a click noise when working the clutch but that's just because I probably need to clean and lubricate it.
    However, this noise came from outside the car and was different.
    It sounded more like a creaking. Like slowly opening a creaky door, or walking up creaky wooden stair steps.
    This happened inside of a garage so maybe that helped get the sound to my ear.
  15. #4935
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    Has anyone ever had this happen... When driving down the street, out of nowhere the car will randomly start dropping rpm regardless of where my foot is on the pedal and regardless of what rpm it is currently at. The car will fall to idle when rolling even when you bury the pedal to the ground. However, the moment you let go of the gas pedal and re-engage it will pick right back up like nothing happened. There is no real way to reproduce this issue, it just happens randomly.
    I know that my brake light switch is going bad and not sure if this has anything to do with it.
    Thoughts?
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
  16. #4936
    Aug 27 2013
    Philly
    Quote Originally Posted by NaiveTurtle View Post
    Thoughts?
    Your brake light switch is the culprit. When the ECU senses the brake being activated while the throttle is activated for ~3 seconds or so, it cuts fueling as it thinks the throttle is stuck open and you're trying to stop the car.
  17. #4937
    May 20 2013
    Vancouver, WA
    I had wondered if the two were connected as the throttle problem hadn't become present until I really noticed the brake lights being on several days in a row in the morning.
    Thanks for the info, I have a new brake light switch on the way.
  18. #4938
    May 22 2007
    Santa Monica CA
    Surprisingly, nothing. But, tomorrow is another day...
  19. #4939
    Established Member Two Rings modfan61's Avatar
    Feb 02 2017
    1988 Dakota 360Swap Project
    Connecticut
    Random misfires at higher rpm (5k+). First happened when it was raining out so I thought it was just bad coil(s). Now happens randomly no matter the weather but still only at higher RPM. Should I still consider a bad coil or 2? Definitely sounds like multiple cylinders. I'm guessing there is an ICM somewhere under the hood and that is a possibility? It's an 04 w/ the 1.8t
    2004 Audi A4 1.8t 6spd
  20. #4940
    Dec 25 2009
    South Bay, CA
    Quote Originally Posted by modfan61 View Post
    Check for air leaks, do a boost pressure test and check your fuel pressure to make sure itís up to par.
  21. #4941
    Mar 05 2013
    CA
    Quote Originally Posted by mobilesuit818 View Post
    I was gonna say, if fuel pressure could be possible. Because I assume that at higher RPM, fuel demand is greater.
    Could this include fuel filter? Although those are "cheap" and one can only hope for a problem to be a cheap fix.
  22. #4942
    Established Member Two Rings BlackJon's Avatar
    Mar 07 2018
    Philadelphia, PA
    Supercharger Pulley Upgrade is done, ooo yea!!! Went with CTS Turbo Pulley 20180609_182207.jpeg20180609_182153.jpeg
  23. #4943
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    Saw the temperature gauge drop below the middle mark for the first time. While driving on the highway, AC on, and 70 degrees out it fell between the 2nd and middle mark. Turned the AC off and it went a bit back up. Kind of weird since I've driven the car in negativd degree weather and not once did the temp gauge drop from the middle mark. I'm hoping it's one of the CTS.
    Brilliant Red 2004 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Gray A4 1.8T quattro 2004
    Brilliant Red A4 2.0T quattro 2007
    DIY - A4 B6 Boost Leak Test
  24. #4944
    Jun 19 2014
    Ohio
    Found my exhaust leak, happens to be the pipe I welded up. Lesson learned, donít grind the weld down unless you paint over it. The weld was ugly cuz I used my 70 amp stick welder. Terrible welding machine. Iím used to big 4-phase industrial welders. Now that I have a proper TIG welder at home Iím going to do it right.
    Also I believe my boost gauge needs an ďadaptationĒ. With the ignition on, engine off the gauge sits at 24inhg when it should sit right at 0.
    Sent from my iPhone
  25. #4945
    Established Member Two Rings IceQB's Avatar
    Feb 01 2017
    SA
    How do I get my car to do that @jpull?
    "Press Clutch Pedal To Start Engine"
    Or did it not come with that options
    ___________________
    Audi A4 B6 1.8T Avant
  26. #4946
    Jun 19 2014
    Ohio
    Quote Originally Posted by IceQB View Post
    If you have a manual transmission, this is the prompt that appears on that screen when you have the ignition on, engine off.
    Sent from my iPhone
  27. #4947
    Apr 07 2011
    I was an hour away from home yesterday when my car decided to start backfiring and bucking in the middle of traffic. Check engine light and traction control light went on when it started. Was able to limp my way home slowly. Used ELM327 and was able to pull a P0103 code for MAF sensor. Once I was home checked wiring out and looked for vacuum leaks. After doing some logs it was obvious the MAF was not functioning properly. Swapped it out with a spare I had and all is well.
    Every time something like this happens at 230k miles I think to myself, must be the end of the road for this one... Haha
  28. #4948
    Established Member Two Rings jj94tt's Avatar
    Feb 24 2011
    Pittsburgh
    Low washer fluid light on the way home from work.
    At home, add 1 gallon of washer fluid.
    Next morning - start car. Low washer fluid light. Check tank - empty.
    2005 A4 B6 3.0L 6MT USP Ocean Blue
  29. #4949
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    Dolphin Grey Audi A4 3.0 Q 6MT
    Dirty Jerz
    Quote Originally Posted by jj94tt View Post
    Check your pumps. My headlight washer pump split open several years ago. The head pressure in the tank forced the fluid up into the pump and out the cracks in the casing. A replaced the pump and problem was solved.
    Sent from my Pixel 2 XL
    Retrieve your SKC for use with VCDS
    Setup Ross-Tech VCP Drivers
    3.0 JHM Tuned, JHM LWFW & Clutch, JHM Solid Short Shifter, Zingo Airbox Mod, quattro, Vogtland Jr. Suspension, Single Xenon E-Codes, Apikol Snub, 034 Motor & Trans Mounts
  30. #4950
    Established Member Two Rings obaka's Avatar
    Feb 17 2018
    Chile
    Quote Originally Posted by imnuts View Post
    happens the same here bud.... Where's the pump to give it a check?? thanks in advance!
    "Toda la gloria del mundo cabe en una cerveza"
    2003 Avant ABT tuned
  31. #4951
    Aug 12 2009
    Dirty Jerz
    The pumps are on the reservoir. The actual replacement procedure says to take the front of the car apart. I was able to replace it by just taking the driver's side headlight out and doing it based on feel. You can see them with the headlight out, but if your arm is in the opening, you can't see much. The pump that is higher up on the reservoir is for the headlights, the lower is for the windshield. It wasn't all that difficult if I remember correctly.
  32. #4952
    Feb 24 2011
    Pittsburgh
    I looked from underneath with the belly pan removed and it appears to be the grommet sealing the headlight washer pump (?, inboard one) to the reservoir. Perhaps I can get away with just cleaning things up a bit. Thanks for the tips!
  33. #4953
    Feb 01 2017
    SA
    Yip have manual trans, but not prompted with this when ignition is on, engine off.
    Could it be a setting in VCDS?
    - - - Updated - - -
    Sent from my iPhone
    ___________________
  34. #4954
    Mar 14 2010
    Q7 4.2 Prestige & 911 C4S
    Wyoming
    Front driver window regulator decided to fail today. Made a weird crunchy noise, so I did the normal try and make the sound again thing. It fully failed with the window all the way down.
    2002 and 170k miles so it had a good run.
    Sent from my SM-G920V using Tapatalk
    Daniel J
    http://www.gtgdrives.com
    @gtg_drives
  35. #4955
    Jul 21 2013
    Midcoast/Maine
    My car has 94k on it and I believe the original clutch, so itís getting to be that time anyway, but, something really weird happened the other day. I brought it to a tire shop to get some new summers put on and it had functioned perfectly, engaging just where it always has etc. After it was returned to me it was incredibly difficult to engage reverse, 1st, and 2nd. 3rd through 6th were also troublesome but not nearly as bad as r/1/2. I was able to row through all gears with the engine off fine so something with the clutch is going to be the culprit. A day later, everything was back to normal and shifting perfectly. This is my 4th VAG mk4/b6 platform so I am positive it didnít just ďfixĒ itself. Where should I start to try and figure this out?
  36. #4956
    Sep 27 2010
    Chicago, IL
    I have a B6 USP 1.8TM, for the past almost 2 weeks I have been hearing beeping in the rear. I scanned it with my HEX-NET VAG COM, but I got no errors. I can't figure out what's wrong with it. I search the web, but no one seems to have a complete understanding of the problem. Definitely don't want to take it to the Stealership!!!
  37. #4957
    Aug 12 2009
    Dirty Jerz
    I've been getting random oil sensor alerts on the DIS. It comes up for a few seconds then goes away. Guess I'll be replacing that at the next oil change.
  38. #4958
    Jul 14 2009
    Pasadena
    had the same issue. Oil lever sensor. Got mine from europaparts its the OEM brand without the audi logo grinded off for like half the price. 5 min job while doing oil chance
    GTX2867r Audi A4 B6 TQM RECARO|HRE|ER|IE|APR|AWE|034 Build page here
    Daily Driven Audi Q3 Neuspeed|HRE|REMUS|KW Build page here
    IG: @matthewee
  39. #4959
    Apr 24 2017
    Los Angeles, Ca
    Quote Originally Posted by tuntsfaah View Post
    Do you have RNSE? Mine would beep if I had the radio in CD mode and have it on a random track that didnít exist. Put everything back to CD 1 track 1, it went away.
    05' S4 6MT Moro Blue
  40. #4960
    Nov 28 2009
    Winchester,va,east coast
    Mine does the samething it creaks when working the clutch pedal, sounds like a leakage underneath needs lubricated, just haven't had time or a lift to really inspect it
