Page 4 of 153 FirstFirst ... 234561454104 ... LastLast
Results 121 to 160 of 6087
  1. #121
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    My AC decided to turn itself off half way to work. Second time the AC has turned itself off on me, but I can't figure out why. Hoping it's from having just a little to much refrigerant in the system.
  2. #122
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    ^ Mine did the same thing today. Then it worked perfectly for the second half of the trip.....
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
  3. #123
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by imnuts View Post
    That's pretty easy to check if you have a 0-150 psi low pressure charge gauge. Use this chart to determine if your static pressure is excessively high. It's best to check it first thing in the morning when all the temperatures under the hood have equalized with the ambient temperature. Clicky click
  4. #124
    Aug 12 2009
    Dirty Jerz
    Thanks. I'll check it out tomorrow morning before I go anywhere
  5. #125
    Jun 24 2013
    bristol
    my esp warning light came on
  6. #126
    Established Member Four Rings milan2k13's Avatar
    Jun 09 2013
    Orlando, FL 407
    Quote Originally Posted by MurkyRivers_A4 View Post
    Happens to me sometimes too..
    More Power, More Problems! 1.8Tiny
    B6 ---> Motoza Stage 1+ | 550cc | 034 HFC | Forge TIP | Forge 007 DV | 2.0T FSI Coils | NGK BKR7E | K&N Drop-In | 93 Proof |
  7. #127
    Senior Member Three Rings ggcrash's Avatar
    Nov 25 2008
    Orlando, Fl.
    Crap...[IMG][/IMG][IMG][/IMG]
  8. #128
    Jun 09 2013
    Orlando, FL 407
    ^ dude wtf, how did you manage to snap that...
  9. #129
    Apr 07 2011
    Quote Originally Posted by ggcrash View Post
    Wow, that tire looks meaty too. That sucks.
  10. #130
    Dec 15 2011
    Edmonton Alberta
    After 16 years a VW/AUDI tech I have never seen that^^^... you are very lucky you did not loose control...
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
  11. #131
    Nov 25 2008
    Orlando, Fl.
    Quote Originally Posted by Dubsport Inc View Post
    Was in a mall parking lot, just off a speed bump, car was only going less than 5mph...you are correct, just call me "Lucky Charm"
    Both straight lower control arms were toast, right one completely snapped, left one was cracked...Go figure, how it happened...
  12. #132
    Dec 15 2011
    Edmonton Alberta
    Buy a lottery ticket quick!
    -Richard-
  13. #133
    Jun 09 2013
    Orlando, FL 407
    Have you ever changed them or messed with them your self? or are they oem factory ones still?
  14. #134
    Veteran Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    Quote Originally Posted by MNAudi101 View Post
    why did you have to know? think something was up?
    few weeks ago we had a big storm here in ny .. went to put my car in reverse and nothing was happening .. would go into limp mode trying to get it into D .. scanned it and came up with po706 - transmission range sensor ?? PRNSD would flicker a little and wouldnt engage in any gear . when it was in drive it would show N on the dash - so drove it home fine for some reason it didnt give me a problem .. but i havent driven the car in 3 weeks because its smoking oil because of a shitty valve job from the shop that built my motor .. owner refuses to answer my calls or texts so that he can fix the problem .. havent had the car back for even a year and its given me a million problems because he did a mediocre job .. so i started it up last night just to sit in it and was like let me see if its still in limp mode - when i 1 clicked the key and put it in tip it said 4 so i thought it was still in limp but u just confirmed thats normal so :) for that problem but :( for not having a functional car :(
  15. #135
    Veteran Member Three Rings Tkemp's Avatar
    May 30 2013
    Florida
    Installed S4 mounts and I think I fucked up a power steering line... it never stops does it?
  16. #136
    Dec 17 2009
    Kentucky
    ^ no it doesn't. My car was running fine with no leaks. Swapped mounts and broke the heater core return and now having a mystery leak from the rear coolant flange.
  17. #137
    Nov 25 2008
    Orlando, Fl.
    Quote Originally Posted by milan2k13 View Post
    They were not OEM, they were Febi brand control arms, about 60K on them...car has 215K on it. Go figure??? FCP, here I come...
  18. #138
    Aug 12 2009
    Dirty Jerz
    Based on the chart and calculator, I should have been at 95-105 psi when I checked this morning, it looked to be more like 120-130 psi when I checked it. However, after running the AC for a little bit after driving around, I put it back on LO and max fan, checked the pressure while running and it was below the recommended pressure. Reading a little more about static pressure, low side and high side pressure, I think I'll just go to a shop and get it evacuated and recharged properly if I continue to have problems.
  19. #139
    Veteran Member Three Rings Joey0918's Avatar
    Oct 13 2011
    1000HP Trailblazer SS
    Nevada, USA
    A/C Leak... Fun times. Seems to always go out at the most inconvenient times(120+ Temps)
    Econ Mode
    Stage Stock.0 1.8t TIP to Stage 3+ 450hp 2.7t/01E Swap in progress
    /// ST Coils /// BBS RS II's /// Red out interior /// Podi /// E-Codes/// Hardwired Valentine V1 with Custom mute switch integration /// orange city lights /// ROTW VAG-COM programming ///
  20. #140
    Rest in Peace Four Rings EURO_DOLL's Avatar
    Jul 22 2011
    Long Island, NY
    What went wrong with your B6 today?
    Inner axle joint let go or center drive shaft bearing committed suicide
    She's getting her first piggy back ride tomorrow
    BOOBS& BOOST
    Current: Bagged 04 B6 A4 1.8T | Bagged 2017 MK7 Golf R
    Past: 03 B6 A4 3.0 Quattro
    Bagged 02 B6 A4 1.8T FWD
    14 MK6 Jetta
    Static 94 Corrado SLC
    15 Golf TDI
    Instagram: @boobsandboost
  21. #141
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    Piggy bank..
    for a Piggy back..
    Ed
    why say lot word when few word do trick.
  22. #142
    Jul 22 2011
    Long Island, NY
    Quote Originally Posted by elewsader View Post
    Piggy bank..
    for a Piggy back..
    Lolol
    BOOBS& BOOST
    14 MK6 Jetta
    15 Golf TDI
  23. #143
    Established Member Two Rings brandn3w's Avatar
    May 09 2009
    z
    Quote Originally Posted by b6Hate4 View Post
    CEL must be broken.
    Lol...
    i thank GOD a lot
  24. #144
    Nov 11 2010
    Rochester, MN
    Less than two months after installing Eibachs and FSD's, I discovered today that both inner and one of the outer CV boots are ripped. I'll be ordering a complete set of boots for both sides.
    19" B8 S5 Peelers
  25. #145
    May 10 2012
    downingtown, PA
    i found out my misfire on cold start is due to coolant leaking in cylinder 2 :-/
  26. #146
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    Quote Originally Posted by SlickFix View Post
    cheaper and less work to just get new axels, plus the install is simple
    edit: I dont really mean cheaper but it comes out to nearly the same price when you get done ordering boots, shipping, grease, and everything
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
  27. #147
    Veteran Member Four Rings freeloader700's Avatar
    Mar 23 2012
    '03 A4 1.8TQM
    The Hills, OR
    Okay so this has been very annoying. Driver front turn signal wasn't working. The bulb was intact. Parking lights worked no problem. After swapping in a new bulb the same issue is present. After that I swapped the bulb carrier from driver to passenger, passenger to driver. That fixed the issue.....for a few days. Now it sporadically works. For the most part the turn signal does not work while the parking light does.
    Also my door ajar /low fuel, etc. bell is no longer sounding. Any clues on either of these issues?
    2003 A4 1.8TQM // Motoza // GTRS // 550cc // TR18T // Forge Splitter // 034 RSB & End Links // V710 Gunmetal 19x8.5
    →→FrankenTurbo F21 BUILD←←
  28. #148
    Nov 11 2010
    Rochester, MN
    Quote Originally Posted by freeloader700 View Post
    This just happened on Wifey's Avant, too. From the searching I've done, it appears that the speaker located in the console has died...or rather, the connection to it. I was concerned after Wifey left her lights on twice within a month long period after if happened, but now it's actually quite nice to not have the car dinging all the time.
    19" B8 S5 Peelers
  29. #149
    Nov 11 2010
    Rochester, MN
    Well, I did contemplate just installing new axles. But after doing some reading on this in other threads, it seems that the Audi OEM axles are the best, and if you can save the CV joints from dying, they'll last a long time. So I'll try this first and see how it goes. Parts cost for all 4 front boots was a shade over $100 from Blauparts, and another $40 for the Schwaben long reach triple square socket kit from ECS.
    19" B8 S5 Peelers
  30. #150
    Apr 07 2011
    I agree with your decision, just try and save the OEM as they are much more durable then aftermarket. It is a lot easier to just buy aftermarket axles and throw them on but I found out the hard way that it was a waste of time and money after a few axle changes. I believe being lowered puts much more stress on the axles and if you plan on staying lowered just stick to OEM. I'm sure others have had success with aftermarket but I for sure wasn't one of them.
  31. #151
    Mar 23 2012
    '03 A4 1.8TQM
    The Hills, OR
    Yeah it has its pros having it out as well as the cons. I just wondering if it is related to the turn signal issue. Any idea on that?
  32. #152
    Nov 11 2010
    Rochester, MN
    It sounds to me like your issues are two different issues. I would probably try a new bulb carrier, unless it's ridiculously expensive.
    19" B8 S5 Peelers
  33. #153
    Jan 30 2011
    la puente, ca
    the other night, turned on the car put the AC on then reversed out of the driveway, then put on my headlights.. and the AC stopped.. WTF?? man audi... never going to own an audi again.
    i wonder if my car thought... ohhh Mr. Driver turned on the lights.. oh its night time.. it must be cold outside. lets turn off the ac to help him out.
  34. #154
    Mar 23 2012
    '03 A4 1.8TQM
    The Hills, OR
    I think they are about $35. The one thing the held me back from buy one is that the issue didn't follow the carrier when I swapped sides with them as well as bulbs
  35. #155
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    Geez, I'm going to look at a USP B6 this weekend...maybe I should stay out of this thread lololollo
    The harder I practice, the luckier I get.
    - Gary Player
  36. #156
    Jul 25 2012
    MI
    Bushing died in the rear end somewhere, so much clunking it is crazy.
    sic semper tyrannnis, canis
  37. #157
    Apr 07 2011
    Quote Originally Posted by 94jedi View Post
    Well the problem with looking at this thread is you're only going to hear about what went wrong. There's no thread about what went right with your B6 today, maybe we should make one of those to get a positive outlook on our cars. There is lots of things that don't go wrong but we generally don't talk about them.
  38. #158
    Apr 23 2012
    statesboro ga
    got a coolant leak and an oil leak. narrowed the coolant leak down to the coolant flange which makes me think the oil is gonna be the cam chain tensioner. got the coolant flange and a new hose on order need to order the CCT stuff.
  39. #159
    Active Member Two Rings Chard_bb6's Avatar
    Jan 04 2013
    09 toyota matrix awd
    Chicago, IL
    When I flip in the right turn signal the left one turns on. I stopped using the right blinker. Must drive the people behind me crazy.
    106, XXX miles
    02 a4 3.0 quattro 6spd (mine)
    09 toyota matrix awd (wifes)
  40. #160
    Aug 03 2013
    Beverly
    Drivers door puddle light won't stay on after I open the door more then 3 inches
