Page 2 of 153 FirstFirst 12341252102 ... LastLast
Results 41 to 80 of 6087
  1. #41
    Veteran Member Four Rings Lastsummer's Avatar
    Nov 25 2011
    2021 B9 Audi SQ5 Black Optics
    Grayslake, IL
    Starting to notice this morning the fluttering sound when letting off the gas. When getting back on the gas (even at 5% throttle) the flutter goes away. Is this most likely a the cause of a bad cat or clogged? If so, I have a JHM tuned 3.0 with exhaust, would going catless or HFC cause any issues? I know smell is of concern as Ive read in other threads.
    2021 B9 SQ5 - IE Turbo Inlet, IE CAI, 034 Motorsport Stage 1 ECU/Stage 2 TCU, O34 Strut Brace, 034 F/R Sway bars w/ end links, 034 trans bushing & insert, 034 RSF inserts, 034 rear diff inserts, 034 lowering links
    B8.5 Audi S4 - Monsoon Gray - EPL Stage 2 - Single Pulley, EPL TCU, ECS Carbon Intake, ECS Mid-pipe, Magnaflow Catback, ECS Drivetrain/Trans inserts, ECS Lower Control Arm Brace, CR-15, S5 Peelers, H&R sports, Bilstein Shocks
  2. #42
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    :( sorry pat. that sucks.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
  3. #43
    Stage 2 Banner Advertiser Four Rings Tech/Sales@JHM's Avatar
    Jun 04 2008
    The Fastest Audis
    California
    Quote Originally Posted by Lastsummer View Post
    You can have no cats and be okay CEL wise with our JHM 3.0L Tune.
    Jake
  4. #44
    Nov 25 2011
    Grayslake, IL
    Quote Originally Posted by Tech/Sales@JHM View Post
    Jake
    Yeah Jake I knew that much... but I was more so concerned about from what Ive been reading smell. Essentially Id like to go with a catless downpipe, but was considering going with a HFC or gutting them entirely.
    But this still brings me to the current issue until I fix... what could be the cause of that fluttering noise on deceleration?
  5. #45
    Jun 04 2008
    The Fastest Audis
    California
    Most people don't notice the smell until the reach a stoplight, and even then its normally not very strong (unless you are behind your own car). Then again, some people are more sensitive to the smell than others. What muffler setup are you using? Some customers have reported that they smell it less with chambered style mufflers compared to straight through style.
    As for the issue you are having, its hard to tell without actually having the car here to diagnose. Any other symptoms you could provide?
    Jake
  6. #46
    Nov 25 2011
    Grayslake, IL
    Jake
    I am currently running 2.5in piping with an x-pipe and magnaflow mufflers. This set up was run on B6JoeS4's for awhile prior to him selling it.
    As far as any other symptoms, not really. You can only hear the fluttering when deceleration. Its basically when there is no exhaust being pushed out. Ill have to try and take a video of the noise on my way home from work.
    The only other things that I can think of are that Im getting pretty bad MPG right now and at times can feel a little sluggish in the low rpm range. Right around 3k it kicks in powerwise.
  7. #47
    Dec 18 2011
    Colorado Springs
    Quote Originally Posted by b6Hate4 View Post
    Motor wants to rip itself off my blown mounts.
    This! hahahahaha
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
  8. #48
    Veteran Member Three Rings stelvio's Avatar
    Feb 13 2012
    This is quickly turning into a "Why you should not buy a B6" thread...
  9. #49
    Aug 01 2011
    Indiana
    My CEL came back on for my catalytic converters that are on their way out. (3.0)
    My brake pad warning light came on despite my pads and rotors being fine. Guess I'll have to unplug the sensor!
  10. #50
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Waxed my car yesterday, bird decided to fix that by leaving its mark right in the middle of my hood today.
  11. #51
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    rear driver side window regulator went out today.
    2003 A4 Sedan:
    * GTRS Eliminator - 550cc Injectors - 034 HFC - Techtonics Tuning Downpipe - Neuspeed Exhaust - 034 TIP - Treadstone TR6 FMIC - Reisu Motorsports Custom Tune - JHM Short Shifter - Fluidampr Pulley
    * H&R Sport Springs - Bilstein Sport Shocks - RS4 Rear Sway Bar - B7/B6 S4 Front & Rear Brakes
    * 18" VMR v710
    2004 A4 Avant:
    * APR 1+ - Vogtland Coilovers - B7/B6 S4 Front & Rear Brakes
  12. #52
    Veteran Member Three Rings sillysod's Avatar
    Jan 28 2010
    E60 Sedan
    Calgary/AB/Canada
    Quote Originally Posted by Dubsport Inc View Post
    Thought they didn't have potholes in Calgary.. :(
    Dickhead. haha
    2011 Frontier DD
    2007 BMW 5'er (wifey's)
    2004 Audi A4 1.8T 6spd FrankenTurbo & Meth
  13. #53
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    Quote Originally Posted by stelvio View Post
    Mine decided to puke some ugly-looking fluid when I pushed back the tie-rod boot :(
    most likely its water that got behind it. it happened to me when I replaced mine last week
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
  14. #54
    Dec 15 2011
    Edmonton Alberta
    Quote Originally Posted by sillysod View Post
    Dickhead. haha
    I thought we had them all up here!
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
  15. #55
    Jan 28 2010
    E60 Sedan
    Calgary/AB/Canada
    That's the problem, was in Edmonton last weekend and as soon as I hit city limits you could see them everywhere (170th is a mess) so you slow down.
    Here they carefully spread them out so when you do actually come across one you are not only not expecting it but you are going 80 when you hit it.
    2011 Frontier DD
  16. #56
    Established Member Two Rings akvanden's Avatar
    Jul 09 2012
    04 USP FWD
    Rochester, MN
    Quote Originally Posted by MNAudi101 View Post
    Better hope its not power steering fluid...
  17. #57
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    CEL came on (SAI pump needs replaced - planned). New clutch is now slipping and needs replaced. Believe a spring broke (would explain sound I'm hearing when going over bumps - light metal sound). Since the clutch is new, it will get replaced under warranty.
    USP CLUB MEMBER #34
  18. #58
    Feb 13 2012
    Thanks! I think something's wrong with the inner tie-rod or steering column or something though still :/
  19. #59
    Jul 09 2012
    04 USP FWD
    Rochester, MN
    Well what is the fluid coming out? PS fluid? Mine dumped PS out the boot = Had to replace rack. Can be done for $200-$250 if you do the work yourself.
  20. #60
    Active Member Two Rings 02B6Kauffman's Avatar
    Mar 13 2013
    2009 Nissan Rouge
    Philadelphia
    Driving down the turnpike at 90mph and my exhaust separated... holy shit it was loud... sounded more like a 96 civic with shit exhaust on it
  21. #61
    Apr 07 2011
    Quote Originally Posted by akvanden View Post
    Where was your logic when I paid $2,000?
  22. #62
    Feb 23 2004
    Stow, OH
    Quote Originally Posted by 02B6Kauffman View Post
    It was your inner ricer coming out.
    USP CLUB MEMBER #34
  23. #63
    Mar 13 2013
    2009 Nissan Rouge
    Philadelphia
    Quote Originally Posted by CyberPMG View Post
    Haha I quickly had this fixed. Did not want to sound like a rice car anymore
  24. #64
    Jun 22 2012
    09 Honda Civic Si
    Dallas, tx
    My dumbass ran a parking curb over, nothing wrong as of yet though.
  25. #65
    Aug 18 2011
    Stuff
    Minnesota
    fuel pump went out, gave it a hit started right up but only for like 5 minutes. pushed it to a side street a couple yards from a friends house. doing the repair tomorrow
    200k daily tank
    My Build Thread
  26. #66
    Veteran Member Four Rings Samsonite's Avatar
    Apr 15 2013
    Golf Clubs
    Minnesota
    Sorry to hear Jordan, at least you didn't have to pay for a tow I guess. Are you going with an OEM pump?
    2020 Range Rover Sport • HSE Dynamic • SC 5.0 V8 • Santorini Black
    2016 S6 • Ibis White • Black Optic • Sport Pckg • APR TCU/ECU Stage 3
    2013 S6 • Phantom Black • Sport Diff • Revo Stage 2
    2013 Q7 S-line 3.0T • Glacier White • Sport Pckg
    2011 S4 6MT • Ibis White • Black Optic • Sport Diff
    2008 A4 S-line Avant 2.0T 6MT • Ibis White • APR Stage 2
    2008 A4 S-line Avant 2.0T • Dolphin Grey
    2005 A4 Ultrasport 3.0 6MT • Dolphin Grey
  27. #67
    Aug 18 2011
    Stuff
    Minnesota
    Quote Originally Posted by pAid4 View Post
    Yeah I do not want to pay for a tow so I am just going to do it right there since its a really easy job. as for the pump I am going with a OEM one, I am also going to change out the fuel filter as well
    200k daily tank
    My Build Thread
  28. #68
    Apr 15 2013
    Golf Clubs
    Minnesota
    Nice, that is definitely the way to go! New axels + New fuel pump = Happy Audi You could see a slight improvement in mpg now too
  29. #69
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    What went wrong with your B6 today?
    Lets see, damaged coilover, seized pinch bolt, then seized driver side tierod
    instagram: @low_n_slo
    https://forums.vwvortex.com/showthre...le/page2&amp=1
    79 VW Rabbit 🐇
    13 VW Golf R 🚗
    09 Triumph Daytona 675 🏍
  30. #70
    Dec 05 2007
    Great thread. Can a B5 guy play too?
    Car is on downtime from manifold cracking. Need my car back. Family beater is on it's last leg, so putting my sister's car back on the road (she is not in the county most of the time). No way I could keep this car as a dedicated "reliable" daily driver. But it is indeed my daily driver. Need to pick up my own cheap beater.
    Quote Originally Posted by audi_nightrider View Post
    turbo bolts keeps on getting loose -_- dont know what else to try....already changed them to stud and used those fancy locking-washers but still no luck. I even used a little JB weld as a last resort and they didn't hold up too.
    I, along with many others, have resulted in just coming out the pockets...
    http://trackspeedengineering.com/pro...products_id/98
  31. #71
    Aug 18 2011
    Stuff
    Minnesota
    Yeah little by little haha hopefully I do get a little better mpg
    200k daily tank
    My Build Thread
  32. #72
    May 08 2013
    New Bedford, MA
    I have to keep filling up my 1.8T weekly with a qt of oil because theres no leak and it burns it. Lot of smoke sometimes from the exhaust. What this could be?
  33. #73
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    Quote Originally Posted by Smithyork View Post
    new turbo very soon
  34. #74
    Dec 28 2008
    Got a CEL on the way to work, p1176. On the way home started to sound like DP ripped in half and lost some power. Stayed that way for a few lights when under load..Then boost returned to normal and started acting normal.
  35. #75
    Veteran Member Three Rings Joey0918's Avatar
    Oct 13 2011
    1000HP Trailblazer SS
    Nevada, USA
    Tail light went out, restarted the car and it was fine
    Stage Stock.0 1.8t TIP to Stage 3+ 450hp 2.7t/01E Swap in progress
    /// ST Coils /// BBS RS II's /// Red out interior /// Podi /// E-Codes/// Hardwired Valentine V1 with Custom mute switch integration /// orange city lights /// ROTW VAG-COM programming ///
  36. #76
    Jan 28 2010
    E60 Sedan
    Calgary/AB/Canada
    High speed express coming through the rockies and the traction control light started flashing. It went out but came on again 2 or 3 times in the 8 hour trip. Looking forward to spending $$$$
    2011 Frontier DD
  37. #77
    Active Member Two Rings ecko-mob's Avatar
    Jun 08 2013
    2011 Nissan Titan
    Colorado Springs/Colorado/USA
    Everytime I'm shifting into gear the car seems to rock. Tranny mount maybe...
  38. #78
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    f***in exhaust mani to turbo bolts keeps on getting loose. slightly grind-ed the mani and the nuts so JB weld can find something to grab onto but still no luck -_-.
    Let's see:
    convert from bolts to stud & nuts - check
    nord-lock washers - check
    those nuts with oval holes(heavy duty) - check
    grind-ed and JB welded - check
    Is it because I am cheating and only did bolt to stud conversion for only 2 of them and not all 3???
    reason why is I'm running FT exhaust mani and they're a b!tch to install....
    Removing exhaust mani is the only way I can get access to the inner most turbo bolt which I'm pretty sure is the main culprit and the one that starts backing out first.
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
  39. #79
    Established Member Four Rings milan2k13's Avatar
    Jun 09 2013
    Orlando, FL 407
    Did an oil change.. and behold, saw it leaking.. here's some pictures.. local mechanic quoted me$700 in labor. .. said he has to drop the tranny to get one of the seals?
    What I need http://www.ecstuning.com/ES1899281/ and http://www.ecstuning.com/ES263904/
  40. #80
    Jun 09 2013
    Orlando, FL 407
    Just called the audi dealership here.. said rarely do the rear crankshaft seal goes bad, it's most likely the cam seals...
