Results 1 to 14 of 14
Hybrid View
    Veteran Member Three Rings stevengrande's Avatar
    Feb 28 2013
    NH
    Vag-com mod for drl now my high beams dont work.
    I did the DRL mod to my car today and noticed tonight that my high beams are inoperable. Oddly, when my lights are off and my DRLs are on, the high beam 'flash to pass' works but when I flip the stalk fwd, nada!
    Any thoughts?
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    What is "the DRL" mod?
    If your car is equipped with OEM Bi-xenon, use the code in red. If your car has halogen headlights, you cannot run independent DRL, because there is no independent "DRL" bulb for halogen B7s.
    Coding
    ?xxxx: Chassis
    0 = Limousine (PR-K8B)
    1 = Avant (PR-K8D)
    2 = Cabriolet (PR-K8K)
    x?xxx: Driving Light Switch
    0 = Rain/Light Sensor (G397) not installed (PR-8K0/8K1/9C6/8K4)
    1 = Rain/Light Sensor (G397) installed (PR-8K3/8K7/9C7/8K9)
    xx?xx: Trailer Hitch
    0 = Trailer Hitch not installed (PR-1D0)
    1 = Trailer Hitch installed (PR-1D2)
    xxx?x: Headlights
    0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7)
    1 = Halogen Headlights with Daytime Running Lights (PR-8Q0/8Q1+8K1/8K3/9C6/9C7)
    2 = Bi-Xenon Headlights with Daytime Running Lights (PR-8Q3/8Q5+8K9/8K4)
    3 = Bi-Xenon Headlights w/o Daytime Running Lights (PR-8Q3/8Q5+8K0/8K7)
    4 = Bi-Xenon Headlights with Daytime Running/Tail/License Plate Lights (PR-8Q3/8Q5+8K1/8K3)
    xxxx?: Country
    1 = Rest of World/Nordic Countries/Denmark/Croatia/Baltic Countries with Bi-Xenon
    2 = Nordic Countries/Denmark/Croatia/Baltic Countries without Bi-Xenon
    3 = USA/Canada with Bi-Xenon
    4 = Canada without Bi-Xenon
    5 = Special Vehicles
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Feb 28 2013
    NH
    I am running halogens and we used XXX12 for a final code. What was odd is the default code for my car came up as XXX03 which is bi-xenon. I've never had bi-xenons...ever.
    We coded it so that I have this set up:
    Key on, light switch in off position
    Key on, light switch in position 1
    Key on, light switch in position 2 (fogs on, as well)
    2005.5 B7 AUDI A4 2.0T - UNITRONIC STAGE II / CTS TEST PIPE / GFB DV+ / RS4 RSB / OEM A3 STEERING WHEEL w/ PADDLE SHIFT MOD / LED INTERIOR MOD /
    Feb 28 2013
    NH
    Bump... for any help w/ the right codes to remedy this.
    Anyone...
    Bueller..!?
    May 20 2008
    2013 Passat TDI
    0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7) is stock code for your halogens.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Feb 28 2013
    NH
    Quote Originally Posted by airbornerifleman View Post
    I know it's supposed to be 0 as default but I would like to keep either my city lights or something on as a DRL. Can I not do that based on my halogen setup?
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by stevengrande View Post
    No you can't with Halogen setup
    Phil
    May 20 2008
    2013 Passat TDI
    Yes you can have DRL and every thing functioning properly. You have to change your coding to XXX04. I'm not 100% sure on the code, but I know in Canada, Halogen B7s have DRL (All lights minus low beam ON with ignition).
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Feb 28 2013
    NH
    Phil
    Well, that sucks. I guess I'll have to REALLY start saving for those new STi's, Phil.
    Oct 16 2008
    LOL
    Got a set ready to go in the Classified
    Phil
    Feb 28 2013
    NH
    LOL
    Phil
    You're an evil man, Phil. The good kind of evil, though. Lol!
    Oct 16 2008
    Hahaha
    Feb 25 2011
    Seacoast NH
    Get Phil's lights, Steve! They look real nice!
    Feb 28 2013
    NH
    Quote Originally Posted by wildcat333 View Post
    I just ordered rims/tires and coil overs...don't get me started! My wife doesn't know about them yet and when she finds out, get the spare bedroom ready, Mike.
