Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 197
Thread: JBDs B3 CQ
  1. #41
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    Looks like my hobby table. Nice build, good job reviving her
    I don't think I care anymore
  2. #42
    Veteran Member Four Rings jbrentd's Avatar
    Oct 31 2005
    '13 allroad, '91 Coupe Quattro, '64 Corvette, '93 Corvette, '21 Bronco
    Tulsa, OK
    Back in business...
    1991 Coupe Quattro - Project Car
    2013 allroad - My DD
    2011 A3 S-Line - Son's DD
    SOLD - 2007 A6 4.2L // 2001 Pelican A4 Avant // 1996 A4
  3. #43
    Oct 31 2005
    Tulsa, OK
    A recent picture I took.
  4. #44
    Oct 31 2005
    Tulsa, OK
    and another...
    Everyone got baths on Sunday.
  5. #45
    Veteran Member Four Rings 100Daily's Avatar
    Jul 03 2010
    Parker, CO
    Wow, awesome job. You are like Edd China fixing that car up! Nice.
    2012 Audi R8 V10 Gated - Stage 1 - Phantom Black - Carbon Package
    Gone But Not Forgotten: 2013 S4 3.0 ---- 2008 A5 3.2 ---- 2005.5 A4 2.0T ---- 1993 90S 2.8
  6. #46
    Oct 14 2006
    west coast
    where is the Suzuki?
  7. #47
    Oct 31 2005
    Tulsa, OK
    Quote Originally Posted by Ruffiano View Post
    lol. That's long gone. As you can see, I finally got that Jeep I wanted back when I was in high school.
  8. #48
    Oct 31 2005
    Tulsa, OK
    Parting shot of this car driven off by it's new owner. I'm sure I'll regret this in the future.
  9. #49
    Oct 31 2005
    Tulsa, OK
    Bringing my old thread back from the dead.
    Turns out I did regret the decision to sell. So much so that I recently contacted the guy I sold it to. Come to find out, it's been sitting in his shop for a couple of years after it developed a bottom end knock. He indicated that he would sell it back to me for quite a bit less than I sold it to him. I made the drive to central Kansas and trailered it home last week.
    In the 4-1/2 years he owned it, he was able to complete the DIY coilovers, get the AC system working again, and a whole bunch of other small maintenance/repair stuff.
    Needless to say, I'm pretty excited to have it back, but a little nervous on what it'll take to get it running again. Compression test shows no pressure in cyl #3 and a couple bent valves could be seen on the borescope. I'm starting to disassemble the engine now. Maybe it's time to swap something different into it.
  10. #50
    Junior Member Two Rings //Sporty's Avatar
    Jul 11 2016
    way too many
    north central mass
    awesome! I felt the same way when I sold mine a couple years ago. "what have I done?" if it had a little more power I would have been happier and probably never had sold. now is your chance... aan, 3b or 7k. wish I had done it...
  11. #51
    Oct 31 2005
    Tulsa, OK
    Quote Originally Posted by //Sporty View Post
    In a weird coincidence, a $400 ‘91 200 Avant popped up for sale this week, which is pretty rare around here in Oklahoma. Sadly, I missed it by a couple of hours.
  12. #52
    Established Member Two Rings Blueprint's Avatar
    Sep 08 2012
    CT/FL
    Frankly I'm shocked this thread was resurrected... it's a rare occurrence to actually get back the one that got away! Good luck with your project. If I was anywhere near Oklahoma I'd sell you the bone stock AAN out of my S6.
    '02 S4 6MT - III+ GT's
    '94 S4 5MT - K24/RS2
    '95 S6 5MT - Project FFFFF
  13. #53
    Oct 31 2005
    Tulsa, OK
    Quote Originally Posted by Blueprint View Post
    Yeah, I didn't really expect the guy to say he still had the car. I'd love to run across a stock 3B or AAN that is even somewhat local.
  14. #54
    Oct 31 2005
    Tulsa, OK
    I've been working on it a little at a time and have drained the coolant and oil, removed all of the intake, valve cover and head bolts. I started to remove the exhaust manifold, but could not get to the 2 rear nuts on the bottom. So, I moved to the EM/downpipe flange. Next is to separate the head.
    Just some notes along the way:
    • I work slow!
    • There are wasp and muddobber nests EVERYWHERE on this thing. I wish I would have taken pictures of them...it would make quite a collage.
    • I probably shouldn't care about breaking/shearing bolts and that's part of the reason I am so slow.
    • I only got a very small of amount of coolant out when I drained it. But I didn't see any in the oil.
  15. #55
    Sep 08 2012
    CT/FL
    Re: the coolant... if your engine (NG? AAR?) is anything like the AAN, coolant likes to hide in the motor and heater core.
    You basically have to do a full flush to get anything substantive out. You can adapt this procedure (for the AAN) to your car: https://forums.quattroworld.com/s4s6/msgs/261537.phtml
    Some people flush the heater core and engine separately to make things "easier" (more work, better results). Good luck...
  16. #56
    Oct 31 2005
    Tulsa, OK
    In my head, I was planning on some sort of flush routine, but that lays it out for me. Thanks for the link.
  17. #57
    Oct 31 2005
    Tulsa, OK
    I went to put #1 at TDC and align all of the timing marks before removing the timing belt. And I think this thing is out on its timing.
    In the pics below, #1 is at TDC(verified with a long 1/4” extension) and the crank pulley marks are lined up. But it looks like the cam pulley is off by a couple of teeth and the camshaft marks aren’t lining up. Am I seeing that correctly?
    Doesn’t matter much anyways. But it might help explain what happened to it. Maybe it skipped a tooth? Or the PO did it intentionally hoping for performance gains?
  18. #58
    Oct 31 2005
    Tulsa, OK
    Could dirt and debris cause the timing belt to jump? The crank, cam and water pump sprockets all had junk in the cogs.
    More mud dobber nests...getting chewed up by the water pump, I guess.
  19. #59
    Oct 31 2005
    Tulsa, OK
    Going to inspect the cylinder walls for signs of damage and then check the piston deck height across all cylinders. If everything looks okay there, the plan is to take the head to a local machine shop to have it checked out.
  20. #60
    Oct 31 2005
    Tulsa, OK
    The deck clearance numbers showed cylinders 1-4 were about +0.5mm (above) and #5 was about -0.5mm (below). I decided to not spend any more time/money on the original 7a engine. So, it is out and on the stand. With it stripped down to just the short block, it was pretty easy to remove by myself with just a jack.
    More mud dauber nests
  21. #61
    Oct 31 2005
    Tulsa, OK
    So, it looks like I'll have a replacement 7a on the way soon, thanks to a generous member of the vintage Audi community. Hopefully, this will get her back on the road until I can source a proper swap.
    My car came with the late 7a and the replacement looks to be an early 7a. I understand that the wiring harness, ECU, and ISV are some of the more important differences between the two. Some questions I have regarding the differences in the early and late 7a's:
    1. Are there other differences I should be aware of?
    2. Can I simply use my original intake manifold, TPS, and ISV for the swap?
    3. What about running the bag o snakes without a heat shield? Seems like there are too many electronics, rubber bits and intake parts that are too close.
    Thanks,
    Brent
  22. #62
    Sep 08 2012
    CT/FL
    I'd like to say all that stuff should swap over just fine, but I don't know enough about 7A's to definitely say one way or the other. Lots more knowledgeable vintage Audi guys on motorgeek or QW or Project Pad will be able to help you out with those queries.
  23. #63
    Oct 31 2005
    Tulsa, OK
    Thanks for the reply. Yeah, I have a few of these threads going. It seems the vintage crowd has been using facebook mostly, which I'm not a fan of really. So I posed the questions in a few places. It seems I'm on the right track.
  24. #64
    Sep 08 2012
    CT/FL
    I've noticed that too and I'm also not exactly thrilled about it. On the one hand, it's very convenient to troubleshoot or just "talk shop" while you're also interacting with the rest of your social circle. Also, throwing a question on FB can often mean much quicker replies, a much larger audience, and/or more input. However, it comes at the expense of a finite lifespan.
    A forum thread can be searched, archived, stickied, bookmarked, linked, etc. but on Facebook, no matter how valuable or relevant the information may be (for you or anyone else who comes along in the future), it eventually disappears off the front page, and that's all she wrote. And then the same questions get asked over and over again. The more that people migrate away from forums and onto FB, the more it compounds.
    I can't count how many times the "eureka!" piece of information I was looking for came from a 12 year-old thread on a forum somewhere.
  25. #65
    Oct 31 2005
    Tulsa, OK
    Exactly! I hate to think about all of the useful information that will be lost if motorgeek were to go down. It's a ghost town nowadays.
  26. #66
    Oct 31 2005
    Tulsa, OK
    The replacement 7a showed up last week. I had hoped to start working on it this weekend, but my son was in town from college and I didn't get much done.
    It'll need a new timing belt, but I'll probably wait until it's in the car so I can break the crank bolt free.
    I did manage to swap a Dave Kase recharged bomb into the coupe this weekend.
    I'm also going to attempt to clean up the slop in the shifter bushing by following this tech article from AW. Hope I can find the bushing and grommets I need for that.
  27. #67
    Oct 31 2005
    Tulsa, OK
    This explains the variance in the deck clearance measurements on the old 7a. #5 on the left.
  28. #68
    Oct 31 2005
    Tulsa, OK
    Small bits of progress here and there...
    Have been working on the replacement 7a. My plan is to clean up the block, give it a coat of engine paint, and freshen up all of the upper gaskets.
    Trying to stay somewhat organized.
    I ended up buying a bucket-top parts cleaner with a submersible pump and a flow through brush. It works pretty well, but requires water based degreaser.
    Got distracted and worked a little on the valve cover.
    Rebuilt the shift linkage. I'm cheap and wanted to try the DIY method, so I followed this Audiworld DIY.
    Started with this.
    Ended with this.
    And used a few pieces from the hardware store and amazon to get there.
    Here's a list of the parts I used in case anyone needs them.
    From the hardware store (Ace has the best selection in my area):
    • (2) Nylon spacers 1/2" ID 5/8" OD 1/2" long
    • (2) split steel spacers 3/8” ID 1/2" OD 3/4" long (cut down to about 13.5mm)
    • (2) 5/8" electrical grommets
    • (2) M6x1.0 16mm allen heads(used to bolt u joint assembly to rod)
    • (4) M5x.8 10mm for holding box together
    From Amazon:
    • (2) 25mm x 10mm threaded sleeves. Threaded for M6x1.0. They come in a 10 pack. Joined together with an M6x1.0 bolt that I cut the head off of. I added this to my list of parts because I couldn't tap the ends of the steel pin.
    Serviced the injectors this weekend.
    And one of the reasons for the lack of any real progress. Been fighting the leaves the past couple of weekends.
  29. #69
    Oct 31 2005
    Tulsa, OK
    Have a few more parts to clean up, but I should be putting everything back together soon.
  30. #70
    Oct 31 2005
    Tulsa, OK
    Seems like the parts to be painted just keep coming. Getting there.
  31. #71
    Oct 31 2005
    Tulsa, OK
    Made some more progress this weekend. Exhaust header, brackets, alternator are on. Also torqued down a new valve cover gasket.
  32. #72
    Mar 25 2017
    Lithuania
    wow.. what a comeback
    B4 & B5 & B6 / Avant TDI
  33. #73
    Oct 31 2005
    Tulsa, OK
    Quote Originally Posted by Poderis View Post
    Thanks
  34. #74
    Oct 31 2005
    Tulsa, OK
    Refreshed the heat shield on the AC line that runs from the dryer to the firewall. Found this one with Velcro on Amazon and cut it to fit the length.
    Old
    New
    Had the flywheel resurfaced.
    Also discovered that I’ll need a new radiator. Ordered a Hella/Behr radiator from Rock Auto.
    AND...Got the replacement 7A bolted up yesterday. This was my first time doing this, so it took a lot longer than it should have. It felt like wrestling a gorilla at times, but once it was lined up right, it slid right it.
  35. #75
    Oct 31 2005
    Tulsa, OK
    Itching to get this thing fired up. Just need to bolt up the exhaust, change the TB/WP/pulley, and fill up the fluids.
    Had to trim the heat shield a bit due to clearance issues with the AC line running from the dryer to the evaporator.
    New Behr/Hella radiator.
    Bought myself some new exhaust for Christmas.
  36. #76
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    Just went through this thread, and I'm glad you bought it back. I'm going to buy one pretty soon and I'm glad you're still on AZ so I can ask you questions if that's okay.
  37. #77
    Oct 31 2005
    Tulsa, OK
    Quote Originally Posted by Nano909 View Post
    Sure, anytime. Good luck with your search.
  38. #78
    Oct 31 2005
    Tulsa, OK
    Spent some time chasing down a no spark issue. Lots of things that it could be. Turned out to be the hall sensor/distributor. After I swapped in my spare, the engine was showing signs of trying to start, but it was chugging and bucking quite a bit. One too many attempts and it locked up and the starter wouldn’t turn it over. I hand cranked it a little and heard some awful grinding sounds that I originally though were coming from the engine internals. But it turned out to be the starter.
    After reading up on what causes a broken starter nose cone, I figured it was engine kickback. Basically, ignition is happening a touch too soon (i.e. ahead of TDC) ...causing the engine to rotate in the wrong direction. It's violent, as evident by the damage to the starter.
    So, I adjusted the distributor alignment and installed a replacement starter and she runs! First time in several years.
    https://youtu.be/vZurDlwClz0
  39. #79
    Senior Member Two Rings snolvr's Avatar
    Nov 11 2013
    2000 S4 Stage 3, '11 A4 Avant Prestige, titanium, sport, '87 4ktq 20v turbo, '07 997 turbo
    Broomfield, CO
    Nice persistence. Hopefully it's running strong, before you pull it and put in a turbo motor :)
  40. #80
    Oct 31 2005
    Tulsa, OK
    Quote Originally Posted by snolvr View Post
    Well unfortunately, it only ran that one time. After running some more checks, I decided to buy new rpm and ignition reference sensors. I also thought I had a bad hall sensor, so I replaced the one inside my distributor and installed a new rotor and cap while I was at it. The car was still not starting.
    Went to test for power at the distributor and the positive wire gave up by breaking off at the plug. So, I repaired that...still no start. Back to testing for power at the distributor and I wasn’t getting 12v across the plug. I was getting 12v from the positive wire to engine ground.
    So, I got looking for wiring issues between the distributor plug and the ECU. Everything looked fine. I plug the ECU back in and check the distributor plug again and I was getting a nice steady 12v across the plug. I thought, I better try to fire it up. Sure enough, it started right up like it should. It scared the crap out of me because I wasn’t expecting it to start and there’s no exhaust after the header.
    It’s been started several times since and I took her for a spin around the block yesterday. I’m not confident that my troubles are behind me yet, but at least it’s running! Pretty sure there’s something wrong with the distributor ground wire.
