Results 1 to 22 of 22
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Bird chirping/ cricket noise from engine bay, at wits end. (Video content inside)
    Hey guys, Ive got an issue with my car sounding like there is a bird stuck in the engine bay, the noise seems to be absent when the car is cold, but once it warms up the sound comes up. Happens weather moving or still, and Is not speed related or related to anything to do with the cooling fans or climate contol fan bearings that I can tell. Recently I have installed a BT setup and a few issues are starting to arise from the new power, this being one of them. Heres the run down:
    Gt2871r elim
    Custom tuned on 550cc's
    Unitronic downpipe
    Borla exhaust
    Silicone intakes FMIC
    Stock exhaust mani
    Still on stock clutch untill next week (slipping like a mofo)
    154k miles
    Shot motor mounts
    TT DV
    That al i can think of that would possibly relate to this noise.
    Video: http://youtu.be/Fn97ScjjZCA noise seems to be in engine bay but is not heard over the engine but you can hear it pretty good in the wheel wells.
    Anyone?
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    possibly one of the tensioners?
    Brilliant Shwartz 2004 S4: Stock
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by rocky.ca View Post
    Good thinking, i did my timing service at 86k so im due for #2, just thought tensioners would be very audible from front of engine, but I cant pinpoint where the fu82!:@ the sound is even coming from
    2016 S3
    Veteran Member Three Rings DNasty777's Avatar
    Aug 01 2010
    '69 Plymouth Valiant
    Rochester NY
    The bird is getting uncomfortable when the engine bay gets too hot. Peehaps, you could cut some vents into your hood to keep the bay temp down and keep the bird comfortable, maybe if you get lucky it'll just fly out of one of your vents.
    In seriousness, I'd check the belt tensions.
    2003 A4 1.8TQM
    [Tein S.Techs][Bilstein Sports][RPM 505s][RAI TP][Milltek DP][TT225][Uni Stg2][Magnaflow 16601][Hyperboost DV]
    --Dave--
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by DNasty777 View Post
    Reminds me of family guy when peter had the bird living in his beard hahah.
    So in order to check either Ill be having to drop the lock carrier into service mode correct?
    2016 S3
    Veteran Member Three Rings foley803's Avatar
    Sep 29 2011
    is the outdoors
    San Antonio, TX
    You should be able to slip the serp belt off to feel around for a gritty pulley without taking the whole front end of the car apart. You may also want to start it with the belt completely removed to see if the noise goes away.
    -Rich
    "Because magic, and science, and learning books" -Dan[FN]6262
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    OMG I have the same noise and it drives me batty. When you depress your clutch does the noise go away? Mine does. In fact, all I have to do is just put a little weight on the clutch pedal and the noise goes away.
    I thought it may be by throwout bearing, or the pilot bearing, or possibly something loose from when I did my 5MT swap.
    It doesn't seem to be causing any issues, so for now I have let it be.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by MikeWire View Post
    Yup. When i depress it just a tad the noise stops. Now that you say that im remembering. I think it might be my stock clutch hating its life. Need to get my new one installed, but my friends garage who is doing it is booked through the week. If when its installs the noise goes away Ill PM you.
    2016 S3
    Oct 27 2010
    Norwood, MA.
    Oh yeah and for good measures a 71r can get you the holeshot just redline it and drop your stock clutch.
    2016 S3
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    I have the same chirping noise and mine seems to be either the tensioner or idle pulley, not to mention probably needing a new belt soon too.
    Anyone know if all these can be installed easily?
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by coowhip View Post
    http://www.ecstuning.com/Audi-B6_A4-...ine/ES2523917/ seems like its a cheap enough fix, cant comment on difficulty but doesnt *seem* too bad.
    2016 S3
    Sep 15 2010
    massapequa ny
    Sounds like a pulley or bearing. Alternator , valves , I recently Had a spark plug blow out of cylinder and it was making a high pitch chirp before it happened.
    Quote Originally Posted by b6Hate4 View Post
    Gt2871r elim
    Unitronic downpipe
    Borla exhaust
    Stock exhaust mani
    154k miles
    Shot motor mounts
    TT DV
    Anyone?
    Sep 29 2011
    is the outdoors
    San Antonio, TX
    The tensioner is cake, but the idler requires you to be in service position (why mine is still sitting in the closet).
    -Rich
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    I have a sound like that only when the car is moving and it sounds like its coming from the left front wheel area of my car. The second I apply any pressure to brakes it stops and if going downhill it stops...
    Any ideas?
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Oct 27 2010
    Norwood, MA.
    After a quick peak in my engine bay i noticed one of the purge valves in the vac system had come undone, the one that is inline with the check valve above the air box. Im gonna go for a drive and see if the noise pops up since its intermittent for the first 10 mins of driving. Fingers crossed.
    2016 S3
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    part car, sell me the complete turbo setup, buy hyundai, no longer at wits end. :)
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    B8 A4 Avant S-Line Prestige
    Jun 27 2011
    If it goes away when the clutch is depressed, I bet its the throwout bearing...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by Peacob View Post
    one million dollars.
    2016 S3
    Oct 27 2010
    Norwood, MA.
    the noise SEEMS to have gone away, but i wont know for sure untill my work commute tomorrow. If it is till present I hope it is the TOB, because ive got a new one right next to me.
    2016 S3
    Jul 08 2009
    Bicycles
    Detroit MI
    I can swing it, I have my buddy who is the son and prince of South arabia send you a moneygram tomorrow for double the money if you can send out the parts tonight
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    Oct 27 2010
    Norwood, MA.
    Deal.
    In all seriousness this turbo setup may or may not be in my car for a whole lot longer, i dont know. Once i get my clutch in and really beat it if Im satisfied then Ill keep it a little while longer, if not I will start puting money aside for a BAT build.
    2016 S3
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: Bird chirping/ cricket noise from engine bay, at wits end. (Video content inside)
    This is a throw out bearing going bad
    Sent from my cm_tenderloin using Tapatalk 2
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
