Results 1 to 29 of 29
    using alientech powergate II to flash your me7 ecu :)
    got this little guy in the mail yesterday. its an alientech powergate. holds 3 tunes. stock and 2 modified files.
    can be used to reflash at will and will also read dtc's from the ecu.
    pc side software lets you save stock file from the device.
    once you download the stock file from the device it can be modified, saved, and then loaded back to the powergate using the software.
    no pc needed for flashing the ecu. just plug up the powergate after loading with files.
    powergate is powered by obd2 socket.
    pictures show me flashing my wifes car with it.
    contact via email please.
    Jun 30 2008
    Erie, Pennsylvania
    Bonus points if you didn't tell the wife you were flashing it.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear
    lol. she actually asked what i was doing outside for so long when i walked back inside.
    Veteran Member Three Rings catbed's Avatar
    May 22 2011
    South Jersey
    Nice! Sounds like an accessport jobbie for subarus. Could be nice for map switching without on-board routines.
    01 A4 Avant <- TwinScroll T3 jawns
    Built 06A|Built AEB|RR Stg3 Clutch|01E 6MT|60 Trim|1000cc EV14s|Bad MAF|Clunking Suspension|Cracked Dump tube
    NefMoto Tuned
    Quote Originally Posted by catbed View Post
    exactly. it is perfect for that without the fear of being served by apr.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Nice. Where did you order one of those? I only saw them on eBay.
    Apr 22 2007
    Riverbank, Ca
    So, This would be simply for switching files or would this basically be for those that want to DIY tune? Im confused as to the purpose of this product.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Quote Originally Posted by andyrew View Post
    a little bit of both really. its a tool that you can carry with you to switch files if you do diy tuning so you dont have to lug a laptop and flasher around with you.
    great for a end user that buys a package deal from their tuner (box + 2 tuned files) so they can switch tunes when they please.
    Apr 22 2007
    Riverbank, Ca
    Ah,
    I see now, thanks :)
    Registered Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    Does this tool read the flash out from a stock ecu??So can It read and write flashes or just writes files??
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicles,Odometer matching, SKC/Pin retrieval services.Located in Northern NJ.For inquries pm for details.
    Quote Originally Posted by EuroxS4 View Post
    reads stock.
    Jan 24 2010
    Paramus,NJ USA
    if the ecu is already flashed will it read that file if its a regular tuned flash without encryption??
    you need a 100% stock ecu. otherwise, whats the point?
    Jan 24 2010
    Paramus,NJ USA
    Well Initially yes.But lets say I have a stock ecu I flash a tuned file to it but then I wanna take it further and flash a more aggressive file to the car or further edit the tuned file thats in there.I'm on nefmoto as well.
    Also if you recieved tuned files are they in bin format or some other type of format??
    if you flashed it, then you just use whatever you used initially and flash it back to stock. then start from fresh.
    i made my own files.
    Jan 24 2010
    Paramus,NJ USA
    Alright thanks!!So I will assume this will flash any file you may have??if you made your own file it will flash it.
    it will flash a file that matches the original file, just the tuned version. you cant just randomly download files and think its going to work.
    Jan 24 2010
    Paramus,NJ USA
    So your saying you have to modify the original file in order to be able to flash it??It will not take a stage 3 file ive read out of another car??
    Stop trying to steal tunes!
    Jan 24 2010
    Paramus,NJ USA
    Not stealing tunes!I own 3 Ecu's that ive purchased over the last couple of years as far as I know the are my property.Just comparing the ones i have to see what things different tuners changed and start making my very own.
    Im only asking if the powergate will flash other tunes because as you mentioned its alot more handy than a laptop and nefmoto software and probably more reliable.
    you want to read the tune from ecu a and flash it to ecu b? that is stealing. you are flashing a file to an ecu for which you did not purchase the file.
    because if you werent trying to do that, you would go to a tuner and pay to have the ecu flashed.
    unless of course, you tuned the files yourself. but im going to go out on a limb and say you did not make the tunes yourself.
    Jan 24 2010
    Paramus,NJ USA
    I understand your point and its a valid one.However If I purchased 3 ecu's which were already flashed then technically I did pay for a flash but reproducing it or copying it is stealing yes.If I were to sell it.However this is not the case.
    It has nothing to do with paying the tuner.Different tuners changed different maps and so on.I simply want to tune on my own.I think self tuning with enough time invested and understanding on a personal vehicle can yield great results perhaps better than some commercially available files due to the fact that your constantly working to improve to get more power out of the car.Where as commercially available tunes are base files that need to be further revised.
    then you would just use the ecu that has the file on it originally, without copying it.
    Jan 24 2010
    Paramus,NJ USA
    Well the ecu's i have are mostly mbox's and I have abox ecu in my car.They are not compatible.I am simply asking if this tool can be used to flash instead of a regular laptop and nefmoto software.
    I am not using this for personal gain.But my wife is also complainign her car is a bit slow she has a b6 a4 1.8t this is why im asking.
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    I remember when I thought tunes were magic. I went about gathering as many examples as I could. Over time, I started looking at them for what they were. Garbage. I can honestly say the only files I now hang onto are those which I don't fully understand yet (AEB for instance). The rest I could care less about. If you're on nefmoto, create your own file. There's no need to save anyone else's files.
    Jan 24 2010
    Paramus,NJ USA
    I think I will do that.
    May 22 2011
    South Jersey
    Quote Originally Posted by ddillenger View Post
    x2. Most companies just modify maps to make they car behave how they want to. Not necessarily the right way or how bosch intended them to be used. I found my OTS was mostly garbage as well.
    NefMoto Tuned
    Jan 24 2010
    Paramus,NJ USA
    Im currently still waiting for c2 motorsports to update the software in the powergate 3 purchased because when i purchased they did not specify that it does nto support me7.1 or me7.5 supposedly they are in the final stages of testing the software so i should be able to read my ecu soon.So hopefully ill be able to get a legit read on the ecu and start tuning on my own.
    Apr 27 2012
    Albania
    Quote Originally Posted by k0mpresd View Post
    Hello friend.Please can you tell me where did you buy this POWERGATE.
    Thanks
