As posted in the "Steering Issues Thread" and "VAG COM Security Codes" threads, I wanted to start a new thread on the Steering issues in an attempt to track the success of various VAG COM Adjustments.
I finally got the chance to "deselect" the box indicated by Tomasz in my "VAG COM Security Codes" thread. The box is under 44-electric steering assist module > coding > long coding > byte 0 > bit 4 (uncheck box for "Driver Steering Recommendation"). I did this last week and have since put well over 100 miles of highway driving on the car with NO steering issues AT ALL! Not even the faintest "hint" of crappy slippy steering. Overall, in EVERY MODE the steering is MUCH MUCH more reliable feeling and consistent! I'm starting to believe that this may in fact be a solid band-aid fix for "the slip" issue many of us have ben experiencing. Before I made this adjustment my steering had been HORRIBLE lately! In fact the worst it had ever been! And since this adjustment my steering has been utterly flawless in every way!
I HIGHLY recommend any of you who have VAG COM make this adjustment and put some miles on your car, then report back. I sincerely hope the rest of you have as good an experience as I have with this adjustment! Now I won't be 100% on board with this being the "end all fix" until I have put many many more miles on my car with it, but so far, I am VERY HAPPY with how the steering is behaving on my car with it!
This "fix" is for "the slip" issue where there is a noticable "slip" across 12 O'Clock in the steering wheel (mostly occurs at highway speeds, others have described this issue as a notch or point of resistance or detent at 12 O'Clock). To my knowledge this DOES NOT fix the "MMI wheel nothciness at all steering angles and speeds" issue (that was fixed for me with the new steering rack).
Please report back any findings any of you have in this thread while making this adjustment.
CREDIT TO TOMASZ FOR BEING THE FIRST PERSON TO GIVE THIS A TRY! I AM JUST REPORTING MY PERSONAL EXPERIENCES WITH THIS.
Edit: (to add wikipedia definition of Driver Steering Recommendation found by Weminuche)
