Originally Posted by
Doc Brown
So, I have been following this thread and many others. My steering has been fine, and for that I consider myself blessed. I am old enough that sayings like, "If it ain't broke, don't fix it" ring true for me. I had planned to leave it alone
Last night driving home, the car got kinda "wandery" on the highway. Yeah, I was traveling "at a good clip" with cross winds, but I did not think they were THAT bad and the car was dancing quite a bit. Steering never felt "loose" but I did need to correct a lot.
So this morning, I got out the VAG and found that in my car this French Driver Assist thing was already disabled. Mmmph. I guess that explains why my steering has not been sucking. Never had the notchiness. It is no M3, but the steering is direct and more than adequate, if a bit artificial in feel. No complaints. Never convincingly had the slip issue, but the steering did behave "oddly" with inappropriate boost on two occasions a few months ago which made the car a bit challenging to drive. Braking hard into low speed turns, to be exact. Control was never compromised, but it was a real event
My car was built in October, delivered in November and had its first service visit in late Feb. I will say that when I picked my car up from first service (5K miles), the steering felt different to me. I never thought it felt bad, but it felt different - or so I thought.
I attributed it at the time to my having just driven the Q5 loaner (a lovely vehicle) and getting back in an S car. I wonder now if Audi has also figured this out and is quietly turning off this feature at service visits until it can come up with a real fix. There was no mention of coding on my work receipt and the other VAG mods I made previously are still there. I recall one other poster on this thread (perhaps more) noting that the code was turned off in his/her car as well.
Anyone else connect the VAG and find this feature already disabled?
Doc my car was built around the same time, I have drive select and dynamic steering, and my DSR is not enabled. I had my 5k done a week ago. I do believe Audi is disabling this as a short term fix. As shared in the steering thread, my local shop foreman explained they just had a regional meeting with Audi field rep and all the area shop foreman's and were told the steering issue is still being worked on. I shared the coding change with him and asked if they did this, he indicated they just upload whatever program Audi gives them. Had my car in last month for steering rack replacement, which was pointless, and an alignment, 3 now. The steering is now perfect.
He is going to ask his field rep if this coding change was done for a short term fix but could not promise the field rep from AoA would know or would even answer this question as Audi may consider this info privileged. I am sure they don't want folks going in and coding their own cars.
It is clear that early rack replacements did not change this coding, and now it seems there is a variance of who has it enabled and who does not.
There also seems to be confusion about 2013s, packages, and differences in coding:
(PDD) which includes Audi Drive Select, Audi Dynamic Steering, and Adaptive Cruise control
(PDU) includes Audi Drive Select and Sports Diff
The PDD package with Dynamic Steering is not something that can be coded to enable as there is a mechanical difference with dynamic steering (while Drive Select can).
The mixed reports of DSR already disabled may be attributed to whether or not one has been in for service recently on this steering issue or a 5K, or it could be just coding differences based on build and date of manufacture. Not everyone has this slip issue.
I believe we will find coding differences between these two packages, as well as cars that don't have either for 2013. What the actual setting was and should be for each model/package variance, what changed, when it changed, and why is the question (I believe the why is short term fix).
