hello, i know that there is many threads on this forum about steering vibration at high speeds (50 to 65 mph)... many of them are not resolved. so finally, yesterday i i found the issue. Lets start from the beginning, year and a half ago mine front inner cv boot went so to make it easy and quick fix i bought new aftermarket axle from EMPI for around $150. After 6 months i started having vibration at high way speeds in my steering wheel with a feeling that my wheel is coming off or the bearing is done. i search many threads about this problem and some people said it could be the wheel balance so i redone that twice at two different locations no help, some people said is the bend hub or the bearing but i check it and it was still good and some said its the shock but i have year old kw suspension so it could not be that. so i was driving with it for almost a year and tried to deal with it as most people said or just drive over 70 mph in order not to feel it. And finally an Youtube vide came to my attention how some guy was replacing his axle as well as his bearings on vw jetta. he explained that when cv boot breaks is the best way just to replace the boot and keep the original shaft because many aftermarkets and rebuilds use oversized bearings or unbalanced/solid shafts this way they sale for cheap. So i found my original axle with torn boot that i keep for the future and order two replacement boots for outer and inner... Yesterday i finally swap back original axle in place of aftermarket and went for a drive. I did all speed tests with breaking and acceleration between 40 - 70 mph and vibration at steering wheel was gone. i though it could be nice to share this info and i hope some of you can finally resolve the problem.
