Page 3 of 3 FirstFirst 123
Results 81 to 94 of 94
  1. #81
    Jan 11 2012
    07 LBZ Duramax, B8.5 S4 6MT, 05 RC51
    Nashua, NH
    Quote Originally Posted by youngthug View Post
    Can someone help me with removing the bulb from the harness? I can't seem to figure it out. Going in from the wheel well.
    Quote Originally Posted by whiped View Post
    I always pop the fog grille off and remove the housing.
    I've done it countless times now. Made installing the HID fogs I currently have much easier.
    Alternatively, you can also do it easily from below, during an oil change. That's what I did for my HID fogs, super simple.
    b8.5 S4 PP 6MT || CF Inlays || Alcantara || Sport Diff || Roc - Euro || AWE Non-Res Dp + STaSIS Challenge || CR15 || 034 Inserts (Trans/Diff/Subframe)
    b6 04 S4 6MT || Daily || VMR 705 || Nitto || JHM Piggies || Fast Intentions || - Sold
    b6 A4 Sport 6MT || AMB / AEB || IE || JE || GT28R || AWE Tune || 480cc || R8 Coils || RS4 Clutch || Billy Boat || Podi || - Sold
  2. #82
    Nov 22 2016
    How do I unclip the harness from the bulb? Can't get it to move.
  3. #83
    Apr 05 2016
    Portland, OR
    This picture shows it the best:
    There is a little slip on the top, push that down and pull.
    If you're still having issues just go through the front.
    Geoff
  4. #84
    Junior Member One Ring smhagger's Avatar
    Jan 04 2017
    2015 VW TDI SEL, 2017 VW Jetta GLI
    Elkhorn, WI
    Hey guys,
    First, thanks for all the useful advice and experience in this thread-very helpful! I recently purchased the DeAutoKey H8 LED conversion kit and was going to go in through the wheel well, removing 4 T25 screws (after jacking up the car and removing the wheel). It was cold out and I wasn't really in the mood. I couldn't see a clean way to mount the ballast or resistor. Remembering this thread, I decided to fiddle with the grill (mistakenly trying to turn the recessed screw on the outer side of the fog light grill). Nada-got nowhere (after re-reading the thread, I now know how to do that).
    My question: anyone mounted a ballast and resistor for a LED conversion? it looks like the small ledge below the fog light might serve as a nice place to put the adhesive and mount the ballast to? The resistor supposedly gets very hot-which has me worried about mounting it correctly. Where should I mount it? I can get some limited access to the back side by removing the 4 T25 screws from the wheel well, but that's really a pain, and provides limited access due to the odd clips (higher in the wheel well) that don't allow easy removal of the whole wheel well liner.
    I almost bailed on the install and returned the lights, but now I'm really wanting to try it again and make it work. I live out in the country and the extra lighting to spot deer would be very nice for me!
    Any help you guys can provide is greatly appreciated. Anyone else install these liights? My car is a 2014 A4, Premium plus. The light kit is this one: http://deautokey.com/product/mk6-jet...-fog-light-kit The install instructions shown are for a Passat-and it's a good bit different than our cars, so the install photos are of limited use to me.
    Thanks,
    Sean
    My Ride: 2018 A4 Premium Plus, 19" Audi-Sport wheels, Black Optics Plus package
  5. #85
    Apr 05 2016
    Portland, OR
    You mean HIDs?
    I've ran halogen, LED and HID bulbs in mine. Currently have HIDs in, they get a little warm but not too bad.
  6. #86
    Jan 04 2017
    Elkhorn, WI
    Thanks for the reply. I'm glad to see someone else has done a similar install. No, I did actually mean LED (not a typo). See the link to the product in my post above. There is a ballast and resistor that needs to be mounted (ballast with just double-sided tape, resistor needs to be screwed down to metal due to heat-or it can be hung so it doesn't make contact with plastic parts).
    Question: how hard is it to drop the whole front trim piece like you show in your photo? Is that the best way to so the install?
  7. #87
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by smhagger View Post
    Removing the bumper is easy, I didn't remove it to install these, just happened to have it off so I took a picture.
    Realistically, I think your best bet is to remove the belly pan. (It's like 3 screws in the front, 3 on each side and 3 on the back. The 3 on the back are self-retaining and only need to be spun 1/4 turn)
    Geoff
  8. #88
    Jan 04 2017
    Elkhorn, WI
    Is the belly pan the whole piece in your photo? Or is that the black center portion in your picture? I was planning to pull off the fog light grills and mount the ballast on the front side-the horizontal surface below the fog light. But ai wasn't sure if there was enough room nor how to get the wires to the back side for the resistor (which would be mounted behind the front clip).
  9. #89
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Quote Originally Posted by Zafi View Post
    That's because you went in from the front!
    If you had gone in from the rear you would not be in this situation ;)
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
  10. #90
    Apr 05 2016
    Portland, OR
    Belly pan isn't shown in my picture.
    First 1:30 of this video shows how to remove it: https://www.youtube.com/watch?v=82QQoD0PElE
    Can easily be done on the ground assuming you are not lowered.
    Geoff
  11. #91
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by VR2V8 View Post
    Interesting that you removed the entire housing just to change bulbs. I found it much easier to go through the wheelwell....just 2 screws in the liner. Took less than 5 minutes to change both bulbs.
    that's how i initially planned on going but for some reason, i couldnt get the H8 bulbs to line up with the holes in the housing to insert and twist into place. I had to file away until i could get it in. Also it was easier to unplug the wiring from the from in my opinion.
    2011 S4 -Ibis White // GIAC Stage I // GIAC DSG tune // AWE Track Cat back // Injen SP Intake // VMR V710 19x9.5 //
  12. #92
    Jan 04 2017
    Elkhorn, WI
    Thanks for the help guys-I got my DeAutoKey LED fogs installed tonight and they are simply AMAZING! Super bright and they match the color of the DRL's and HID headlights perfectly. Super happy! I did the whole install from the front by removing the fog light grills. Thanks for this thread and the tips.
  13. #93
    Feb 02 2016
    Peoria, Arizona
    nice!
  14. #94
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    Thanks, that is great info, as someone was asking, all feedback says it does match but we never say 100% but we feel it is very close.
    Choose bulb you need on drop down:
    http://deautokey.com/product/led-hea...ast-1800-lumen
    But yes these are insanely bright:
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
