Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Jul 20 2009
    FRANCE
    Quote Originally Posted by Slikk View Post
    Tried to get my hazard switch apart, unfortunately it appears to be designed in such a manner that the circuit board is captive once it is assembled (6 pins are soldered on that hold it permanently in place, thanks to the design of the housing). I can't get at the circuit board itself without entirely disassembling the switch, so I'm pretty much dead in the water.
    If I'm feeling destructive later I might attempt to desolder the pins, but as I don't have much experience desoldering anything, I probably won't bother. Looks like I'm falling back on hacking up the wiring harness to wire in a standalone relay.
    Post pics.
    In Europe, we have position lights and turn signals. I wanted to mean the turn signals only flash there, so you can downsize the resistors in term of wattage.
    If signals are assumed to be always on, take margin regarding the wattage according to the heat dissipated in warm weather.
  2. #42
    Jul 20 2009
    FRANCE
    Quote Originally Posted by Delighton View Post
    This led tutorial is a decade ago. Is there any new tutorial like 2019?
    Lol, indeed not, the info are still valid.
  3. #43
    Active Member One Ring Malkierie504's Avatar
    Sep 11 2015
    mk4 GTi GLX 12v vr6
    New Orleans
    Does anyone have the photos of this thread saved? I’m trying to do this mod as well since I have swapped all signal and brake lights to led so my lights only flash when I turn on the hazard switch. During normal use I get solid light and a dry buzzing from my hazard switch. If I replace either a front or rear LED with a regular incandescent bulb it flashes quickly but not quite hyper flash. I actually like the slightly faster than stock flash, js.
  4. #44
    Junior Member One Ring
    Mar 30 2013
    Charleston, WV
    Quote Originally Posted by Malkierie504 View Post
    Bringing it back again.
    I'm with your Malkierie504. Anyone have the pictures still?
  5. #45
    Jul 20 2009
    FRANCE
    You need to log in to see some pics.
    Other pics are PhotoBucket and are accessible.
