Page 2 of 2 FirstFirst 12
Results 41 to 60 of 60
  1. #41
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Re: Wow... Audi is replacing my entire engine in my 2009 A4.
    I would doubt they ship the motor without heads on there.
    Short block = no heads
    Long block = all mechanicals
    Sent from my SPH-L900 using Tapatalk 2
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
  2. #42
    Jan 23 2012
    Quote Originally Posted by 34dean View Post
    My car was burning a quart of oil every 2000 miles or so when I purchased it a year ago. Brought it in and it passed the stage 1 test. About 2 months ago, it started burning a quart every 400 miles. Brought it back in and this time it failed stage 1 and 2. They decided to replace pistons and rings to correct the problem. When they took a closer look at/in the engine, they determined there was additional damage. Hence, the new engine.
    So, will my car still have 51K on it... or...... 0?
    What is the protocol for breaking in a new Audi 2.0T engine? Can anyone help with this?
    Same thing with the CPO Audi that I purchased. It had many oil consumption issues and they just replaced the engine with a new one. I talked with the previous owner and he said the car practically spent half the 4-year lease in the shop. I've put 40,000 KM on it since I purchased it at 80,000 KM and it's been running great!
  3. #43
    Deactivated One Ring
    Mar 31 2013
    Stocholm, Sweden
    Same thing. A friend of mine owned my A4 before me, and just before he sold it to me, he had a repair done (car consumed a lot of oil). A week later, the engine broke down, at about 95000 km running distance. Audi technicians couldn't exactly address the problem though. Brand new engine and voilą, oil consumtion seems to be at normal. This was a 1,8tfsi though, and as sad as it sounds, warranty was out only 2 months before the breakdown, so the repairs was pretty expensive for my friend... But I got a great price on an A4 with a brand new engine!
  4. #44
    Veteran Member Four Rings if6ws9's Avatar
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    Quote Originally Posted by Liquidsystm View Post
    The service advisors at my dealer are all pretty cool. They just told me to make sure to switch back to stock when I drop off the car, so the system wouldn't flag me.
    Reeves Audi in Tampa is mod friendly but they said that putting the ECU back to stock won't fool Audi's headquarters. They said that Audi has the capability of detecting a tune even if you go back to stock and lock it out. The Audi dealership has to fill out forms to get aproval for any major work and if the they know that you have a performance tune they can't/won't lie bacause it'll get detected anyway. I'm at stage 2 and I was SOL in getting the oil consumption test done because Reeves thought I'd get flagged with a TD1.
    2014 A5, Gloss Boat Blue, Black Optics, Sport package, MMI+, B&O, AWE Touring, AWE DP, USP HFC, CTS CAI, APR Stage 2, ST Coilovers, Alu Kruez, 034 TX insert, ECS diff bushing, Apikol blue diff mount, VAG's, Escort Redline, ZR4 shifters, 20% tint, Sprint Booster, ECS dipstick, FB steering wheel, piston diverter valve, ECS rear lower control arm brace, 10mm & 12mm spacers, BFI shift knob, CR 15, powder coated calipers, extended paddles, Vossen CV3-R's, Eurocode F&R sways, RS grille
  5. #45
    May 22 2013
    Hermosa Beach, CA
    I've been going through the same thing. I bought my first Audi last year (CPO 2009 A4 cabriolet). A month after driving it, the low engine oil light came on. The dealer performed an oil consumption test and the car failed. They replaced the piston rings, which unfortunately did not address the problem. Several weeks later the low engine oil light came on. A second oil consumption test was performed, and the car failed a second time. Audi is now offering a new engine. I'm aware of a bad batch of piston rings that have plagued the 2009-2011 models but can't seem to find independent information about any changes made to the engine to make me feel confident that I won't have to deal with the excessive oil consumption again. I'd appreciate any links/information. Thanks.
  6. #46
    Mar 26 2012
    Charlotte, NC
    Quote Originally Posted by lo5ree View Post
    You will be getting the updated engine.
    Well long block anyways, pretty much everything new. You will not have any oil consumption issue after that, that's almost guaranteed.
  7. #47
    Sep 22 2011
    Western MA
    Quote Originally Posted by SDF1 View Post
    2009 Cab (B7) is a EA113 FSI engine not the EA888 TSFI engine.
    2020 SQ5 Ibis White
    2016 A3 Cabriolet Glacier White 2.0T
    2011 Q5 Ibis White 2.0T (sold)
    2008 A4 Cabriolet Ibis White 2.0TQ (sold)
    2000 A4 Laser Red 1.8TQM (sold)
  8. #48
    Aug 25 2012
    Upstate NY
    Audi is replacing my 2011 audi a4 premium plus 2.0L turbo motor as my oil light low pressure came on and metal shavings were found in the oil pan. lil have a brand new updated motor put in. ffree of charge. 53,000 miles bought as CPO with 44K, cant complain. 11;000$
  9. #49
    Aug 09 2012
    2013 S4 phantom pearl
    IL
    So my 2009 A4 was in for new pistons and rings to fix my oil consumption issue. Apparently, when the technician was beginning the work, he noticed "some things he didn't like". This was the exact quote from my dealer's service department. They sent the report to Audi and a brand new engine was approved for my car and will be installed next week.
    I commend Audi for standing by their car and their customer.
    My question... has anyone else experienced this? I assume I will need to break this new engine in like any other?
    Any input is appreciated.
    I know this is an old post, but I wasn't so lucky.. wish I was, but I definitely feel like I'm getting the short end...
    I just went through stage 1, cost covered by the dealer. I've got an 09 with 74k. it failed stage 1 miserably consuming oil at a rate of 3.3 quarts per 1,000 miles. I can also see small tufts of smoke from the exhaust under heavier acceleration so there's some very adequate burning going on inside the combustion chamber. The audi dealer called AOA and was approved to proceed with stage 2 of the oil consumption and replace pistons/rings.
    after i left in the loaner, i got a phone call from audi telling me in order to proceed with stage 2, I had to replace the oil pan which had a very slight trickle leak and that skewed the oil consumption tests. after replacing the oil pan, i'd have to go through stage 1 again. the pan would done at my cost, the others costs done at audi's expense. now, under normal circumstances, i'd say this is fine, I understand having to replace an oil pan seal. But, the service advisor and technician at audi commented on how very minimal this leak is and how it very likely wouldn't account for most of the oil consumption. I've been on the phone with AOA trying to get some kind of progress with this, but they simply are unwilling to move forward with stage 2 without me spending over a grand to fix the oil pan. this seems ridiculous to me. There's visible oil burning off through the exhaust and 3.3 quarts per 1k?
    I'm not sure what other direction I can go at this point, but it's clear my car has the consumption issue with bad pistons/rings. I have to invest over $1k to fix this thing now. does anyone have any recommendations of someone else I can contact through Audi? I've owned more than 15 audi's and never have i been disappointed. This is the first time where I feel like there's a lack of common sense. After all, why would the audi dealership proceed with step 1, tell me step 2 is about to begin, then pull on the regins? if the leak were that significant to these results, it should've been corrected before taking me through step 1 the first time. I feel like I'm spinning my wheels. Very close to leaving the brand, which would be a shame.
  10. #50
    Senior Member Two Rings A4BGP's Avatar
    Oct 18 2005
    Dirt and Street bikes, '09 A4Q
    Moncton, NB
    Das4, that pan is $152 at Genuine Audi Parts.(06H103600AA) and the sealing compound is $24 (D174003A2) Change that thing yourself over a few beer and then bring it back. I've an electronic service manual if you have questions or want to check before taking something off.
    However, as I stated, there is no gasket on there... and if it isn't perforated by an impact of your fault, I think that should be on them as they need to take the thing off anyway! Especially since the SA and Tech confirm that the leak ( seepage) wouldn't adversely affect stage 1 test results.
  11. #51
    Aug 31 2014
    2007 335i
    Chicago, IL
    This is a pretty old thread but My engine is being replaced (under warranty) right now. According to them its the "long block." I have no idea what that means lol.
    He was mentioning that there may be a lot of things that the warranty might not cover...... nuts bolts hoses belts (all of this stuff is a maybe) but they would let me know because they'll use as many things off the old engine as they can reasonably use.
    But basically the reason they are replacing it is because i was hearing this rattling noise around 3000 RPM. I was told this might be just a heat shield or maybe even the timing chain. I personally thought it was the turbo. Once they started with the engine, they found that the timing chain had been stretched (by the previous owners) somehow and that it was very very close to breaking. They said that due to this, other things in the engine were warped slightly and was causing the engine to run.......... i forgot the word he used. it meant "badly" lol. They were about to just fix the chain and some things they could see, until they drained all the fluids and there were metal shards and dust everywhere! they said there's no telling what could have caused that but rather than spending the next few weeks doing a complete tear down and looking at every piece of the engine, its best - and cheaper - if it was replaced. Not sure how long it will take for them to fix it, but i hope its done soon. I like the A6 they gave me but man its too big. i want my car back!
  12. #52
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by Whyu1nunno View Post
    A long block is the engine block, pistons, and rings without the head. They reuse your original head. Good luck with the repair!
    Edit: That was backwards, a long block includes the cylinder head while a short block does not.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
  13. #53
    Mar 26 2012
    Charlotte, NC
    Quote Originally Posted by ProjectBlackout View Post
    What about new timing chain? Ignition Coils? Intake Manifold?
  14. #54
    Mar 24 2014
    The timing chain should be included, I would think, but they only replaced the pistons and rings in mine so I can't say for sure. Intake manifold would probably be reused, I'm not sure about coils but I'd guess they'd be reused. Also I had it backwards; a long block includes a new head and a short block would reuse the old one.
  15. #55
    Nov 26 2011
    grand haven/mi/midwest
    same deal
    I had a very similar situation back in 2011 with my 2009 a4. It started consuming a quart per oil change (5000 miles) around 70k and by the time I hit 90k it was a quart every 200 miles. It was early in the game for the B8 and audi wanted the engine back for engineering to inspect.
    fast forward to today, I have 175k and my timing belt tensioner went, allowing the chain to jump time and wrecked the engine. Just put a 'new' engine with 30k on it. not cheap, if you're getting up there in mileage at least get the timing chain tensioner inspected for wear.
  16. #56
    Senior Member Two Rings Vinhouw's Avatar
    Jan 14 2014
    my two feet
    Tampa, FL
    i have a 2011 a4 with almost 70k miles on it. I also have to refill 1 qt of oil every 5,000 miles on average. Friends told me that my exhaust relieve a white smoke everytime I take off or accelerate... Should I get worried? this thread is freaking me out. It is my first Audi so I am not familiar with this whole oil consumption issue. The only thing I have added to my car engine wise, is a Forge DV Spacer for the sound. Should I remove it before taking my car for maintenance service?
  17. #57
    Jan 13 2014
    nyc
    this happened to me too.....then I dropped the ball by missing a free turbo replacement due to their loose wastegate issue. AoA deny me the turbo or to repair my wastegate til this day
  18. #58
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    Quote Originally Posted by Vinhouw View Post
    Keeping the Forge installed is a gamble; some dealerships will ignore the DV Spacer but some will try to blame anything they can on it.
  19. #59
    Established Member Two Rings Allroad!'s Avatar
    Mar 21 2014
    Wow very impressive. This is one of the reasons why I wanted to get an Audi. I was sick and tired of the crappy and imcompetent service from the previous 2 brands I had.
  20. #60
    Jan 14 2014
    my two feet
    Tampa, FL
    Quote Originally Posted by if6ws9 View Post
    @if6ws9 I live in new port richey FL, so I saw that you also go to Audi Reeves Tampa as well... Like you said on a previous post, they are pretty much Mod friendly, but most of the representatives over there are not very friendly. I guess I should remove it before I take it for maintenance and point them on what is wrong on my car... ugh what a pain to install/remove it tho lol
