Hi Everyone.
I understand the DPF issue comes up a lot but I could anything really that describes what I want to do.
I have a 2008 3.0l A4. Its had a new engine put in by a previous owner. When I got the car it had the engine management light and flashing glow plug light on however was not down on power at all. Dpf laod was showing around 14g.
After some googling I had a scan done and it seemed to show that the sensor was faulty. I replaced the sensor but had some issues getting it to reset learned values. After fitting the new sensor I am also now really down on power / sluggish. The DPF load is showing around 63g. I also tried to force a regen but this would not start for safety reasons. I have tried driving at high revs to make it regen automatically but I am assuming the soot level is too high to do this. Pointing the old sensor back in did not bring full power back. These scans are shown below.
So I have come to the conclusion that my DPF must be well and truely blocked, enough so that a forced regen wont start. I have spoken to Audi and they want far to much money to just look at the car, before telling me exactly what I already know. I have been looking into DPF removal but there does not seem to be much around for the 3.0L and I am not really fond of the idea of removing it.
I have seen people talk about removing there DPF and physically cleaning it on a bench and then putting it back into the car to automatically regen its self. To me this seems like the easiest option and will save me some money.
So has anyone got a guide on how the remove the DPF on a 3.0L or know somebody that could give me some advise. I believe it to be the rather large thing behind the engine and it does look a right pain to remove. Sits right under the firewall.
Any help would be greatly appreciated
Another thing I have read that the ECU needs updating for a new dpf regen proceedure. Can I tell if this has been done through VagCom or just ring Audi?
Thanks again
Below is first scan I had done on the car. (Before buying new sensor)
5188 - Diesel Particle Filter
P2463 00 [032] - Excessive Soot Accumulation
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 131863 km
Date: 2008.04.10
Time: 21:02:24
5162 - Diesel Particle Filter; Differential Pressure Sensorá
P2453 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 131863 km
Date: 2008.04.10
Time: 21:07:57
5189 - Particulate Trap Bank 1á
P2002 00 [032] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 131863 km
Date: 2008.04.10
Time: 21:02:24
Readiness: 1 1 0 0 0
After fitting new sensor.
4 Faults Found:
P2463 00 [175] - Excessive Soot Accumulation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 133877 km
Date: 2013.03.12
Time: 19:40:57
18660 - Unknown Error Code
P151D 00 [032] - -
P2453 00 [104] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 132919 km
Date: 2012.12.30
Time: 15:36:39
P2002 00 [047] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 133877 km
Date: 2013.03.12
Time: 19:40:57
Readiness: 1 2 0 0 0
