Results 1 to 34 of 34
    Veteran Member Three Rings quattro_silver's Avatar
    Jun 18 2008
    Chicago, IL
    Car won't start - after changing spark plugs yesterday
    I changed my spark plugs yesterday, drove the car 2x last night and it drove great (I did smell some gas though). It idles just below 1k and everything seemed fine. Today I drove to work, went out to lunch with the car.. no problems.
    However, I just went to start the car up to go home and it won't start. The only thing I changed was the spark plugs (NGK BRK7E) and I gapped them to 0.028. My battery is at 12volts when I try to start the car so I don't think it's the battery.
    Any ideas why the car won't start?
    EDIT: I switched coil packs 4 & 5 during the installation to see if #4 was bad. (not sure if this has anything to do with it though)
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    E-Codes + DDM 55w 6k
    SRP pedals
    Hawk HPS + Adams slotted
    Kicker CompVT
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Does it crank?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jun 18 2008
    Chicago, IL
    Quote Originally Posted by infinkc View Post
    Does it crank?
    Yes, I believe it does
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Aug 05 2011
    Memphis, TN for now!
    Pull the plugs...maybe you broke one of them trying to re-gap?
    Jun 18 2008
    Chicago, IL
    Quote Originally Posted by airjawed View Post
    Even if 1 plug and/or coil pack wasn't working.. wouldn't the car still start? (it would be rough) or would the car not start at all?
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Feb 23 2010
    Emmaus Pa
    see if its getting fuel. Rtl5009's car randomly didn't have the pump work for whatever reason yesterday. Pulled the relay, put it back in and it started. No idea why it happened
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Jun 18 2008
    Chicago, IL
    How do I tell if it's getting fuel? Also, which relay are you pulling?
    (I checked the fuel pump fuse and that seems ok)
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Feb 23 2010
    Emmaus Pa
    The relay is under the knee bolster.
    B9 S4- EPL/AWE
    Jun 18 2008
    Chicago, IL
    thanks, now how do you go about checking to see if it's getting fuel? This whole thing is weird because the car was running today and then all of a sudden won't start. Does anyone know if the car would still start if 1 coil pack and/or spark plug wasn't working?
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Feb 23 2010
    Emmaus Pa
    it would start, just run like shit. Pull a fuel line and see if it primes.
    B9 S4- EPL/AWE
    Aug 05 2011
    I don't really think one coil or plug would cause a no start condition. But, since you did some work on the plugs/coils I would look back into that and check on anything else that may have been knocked off or unplugged in those areas you worked. It could be something as simple as not clipping the coil connector.
    Jun 18 2008
    Chicago, IL
    But again, if it was just ONE coil connector it should still start.. at least you would think. I'm starting to wonder if it's the Ignition Control Module. The cars parked at work now, but the true test would be to see if I can get a spark from the coil packs themselves.
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Dec 17 2008
    Kansas City
    Had this same issue when I changed my spark plugs last time. To answer your question about the car starting with one bad coil/sparkplug, yes it would start. When I had my issue I tried just about everything to get my car running. I finally as a last ditch effort pumped the gas while trying and starting the car. After a few attempts while pumping the gas the car tried to start; didn't quite turn over, but was very close to firing up. Gave it one last go while giving the gas pedal a few really good pumps and the car fired up. Will I sit here and immediately tell you that pumping the gas pedal without the car starting is a good idea, No I won't. You can flood your engine and actually cause it not to start. I will suggest you at least give it a try since it seems like it is the same issue that I was having. In conclusion, it sounds like you aren't getting any fuel for whatever reason. Hit me up if you have any questions.
    Jun 18 2008
    Chicago, IL
    Quote Originally Posted by SRSslpr View Post
    Did you end up replacing any parts? Or was the car fine after that..
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Nov 21 2012
    Ohio
    lol you can unplug an ignition control module and the car will still run, one coil probably wont cause a no start.
    Sep 11 2009
    NE
    you can idle (like crap) on just two cylindes (done that), maybe even one if you step on gas... If it doesn't start at all then most likely culprit (due to age of car) if fuel pump or its relay.
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by OHS4 View Post
    Yes actually it could... They are all grounded into eachother like a chain.
    If the first grund it taken out, the whole bank can go.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Veteran Member Three Rings Yankeefan7592's Avatar
    Aug 12 2009
    2001 S4
    New York
    could be just a cooensidenc, it may not have to do with the spark plugs. Can possibly be the cps mine is on its way out and sometimes it will start fine, but when it's hot it will just crank and won't start.
    I Do Independent Fog Mods For B5's PM Me
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by Yankeefan7592 View Post
    Change it!
    2001.5 S4 - Stolen
    2011 M3 - Blown up
    Aug 12 2009
    2001 S4
    New York
    Quote Originally Posted by DiscoPotato View Post
    Change it!
    I don't get a code for anything though. I don't know if its the cam sensor or the crank. Supposedly they both give the same issue.
    Sep 18 2008
    lancaster,pa
    Quote Originally Posted by quattro_silver View Post
    It either cranks or it doesn't?
    Frankenturbos, Stage 3 tuning by Jfonz Tuning.
    Sep 18 2008
    lancaster,pa
    Speaking of ignition modules, did you unplug both of them for some reason when pulling the plugs? If so maybe you have them swapped. This will cause a no start.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    You're guessing again... Scan for codes.
    If it doesn't start it's either not getting one of two things.. fuel or spark. Find out which is missing.
    Jun 18 2008
    Chicago, IL
    UPDATE: It's at my mechanic now, I had to get it towed earlier. He was able to get it started but then the car died.. He said it's getting a spark so he's thinking it may be fuel related. I'll update this thread when we figure out what it is. It's just weird that it started for him and then died.
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Jun 18 2008
    Chicago, IL
    UPDATE: My mechanic just called and said it's the fuel pump. He quoted me $180 for labor + $400 for the pump.
    Hopefully I'll be good to go after I replace the pump, the cars got 170,000 mi so it was probably time to change it. I appreciate all the replies back though!
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Oct 27 2011
    TOYS
    Philly Suburbs
    I would have sold you my stock pump for $50.... 89,000 miles on it...
    Jun 14 2007
    2000 S4
    Connecticut
    $400?! Hope you're getting an 044 for that price :)
    Also, $180 labor! Hope you're getting a full tank of gas after he drains yours for that price!!
    Veteran Member Three Rings Cadiburns's Avatar
    Feb 17 2010
    Chicago
    Which shop did you take it to? Seems steep.
    B5 Casa S4 Avant | Tial 605s | EPL | Aquamist
    Jun 18 2008
    Chicago, IL
    Quote Originally Posted by Cadiburns View Post
    I agree, a bit steep. I took it to Rauch Performance in Lake Bluff. Normally I would just do it myself but kinda in a bind with the car. They do good work, they had to diagnose the car today
    and then the labor for putting the new pump in comes out to $180 total. The Audi Exchange in Highland Park I believe is $175/hr which was my other option.
    PureMS has an OEM (brand new) Fuel Pump for $333.07 (shipped) so I am getting charged a bit much for the pump.. oh well. I'll chalk it up to all the times they've helped me but never charged.
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Jun 18 2008
    Chicago, IL
    Quote Originally Posted by AudiSportB5S4 View Post
    LOL, I know what you mean. I've never replaced the fuel pump on this car, how hard of a job is it? And how long does it usually take?
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Jun 14 2007
    2000 S4
    Connecticut
    No more than 30 minutes! I wouldn't get a stock pump man.. If you are allocating that much to this repair, at least upgrade!!
    Feb 17 2010
    Chicago
    Sucks. I have my oem sitting in a closet. Now that I've been in my fuel tank several times, it really takes no time.
    Jun 18 2008
    Chicago, IL
    Damn, I would have taken it to if I had my car in my garage :( I appreciate the offer though bro.
    On a side note, I just saw you have the 605s and are located in Chicago (I'm considering that setup w/ EPL). I gotta check your setup sometime. Do you go to any of the Chicago events?
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Dec 17 2008
    Kansas City
    Sorry about not getting back to you sooner. No i never replaced any parts, but like I said it sounded like you weren't getting any fuel. Good to hear you got the problem figured out and solved.
