Originally Posted by
SRSslpr
Had this same issue when I changed my spark plugs last time. To answer your question about the car starting with one bad coil/sparkplug, yes it would start. When I had my issue I tried just about everything to get my car running. I finally as a last ditch effort pumped the gas while trying and starting the car. After a few attempts while pumping the gas the car tried to start; didn't quite turn over, but was very close to firing up. Gave it one last go while giving the gas pedal a few really good pumps and the car fired up. Will I sit here and immediately tell you that pumping the gas pedal without the car starting is a good idea, No I won't. You can flood your engine and actually cause it not to start. I will suggest you at least give it a try since it seems like it is the same issue that I was having. In conclusion, it sounds like you aren't getting any fuel for whatever reason. Hit me up if you have any questions.
Did you end up replacing any parts? Or was the car fine after that..
