Results 1 to 20 of 20
    Apr 30 2010
    Miami Valley, Ohio
    Trouble replacing control arms
    I cannot get the bolt on top of the upright holding the upper control arm ball joints to move. I've tried heating, hitting with a small sledge hammer, nothing will make it break loose. Any ideas or suggestions?
    It's the one in the top of the pic.
    Jun 10 2010
    Search "pinch bolt" for other options.
    Heat is probably your best bet.
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    ah the dreaded pinch bolt. best advice is more heat, more hitting, and more PB blaster.
    Life is too short to drive ugly cars.
    Feb 27 2011
    04 A4 2.7T swap, 13 Q5 3.0T S line, 02 A4 1.8T tiptronic, 01 B5S4 tiptronic
    Winnipeg
    air hammer and heat, I just used wd-40 on mine, but I'd heat it and spray it and watch it bubble in and heat it more in cycles, then blast it with the air hammer. Did this in about 15 min a side
    Dec 05 2007
    There are people who can get it out with pb blaster and there are people who need to heat it bright red (map gas torch) to get it to budge.
    Senior Member Three Rings Artiemas's Avatar
    May 30 2012
    North Branford, CT
    One of mine came out fairly easy. The other one?
    It broke in three different pieces.
    Someone's literally took a part of the upright with theirs when it came flying out. I forget the thread name.
    1998.5 Cactus Green A4
    30v AHAQM Bone stock
    Apr 30 2010
    Miami Valley, Ohio
    Well I spent a couple hours on it yesterday, no luck.
    Back to the grind today, I'll try some more PB and heat this eve. and see what happens.
    Thanks for the replies, sounds like I'm doing what I can short of replacing the upright...
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Dirt bikes and empty boxes
    Bend, Oregon
    Air hammer and chisel bit in the slots. Spread the slots, spray more pb blaster in slots. heat is your friend.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2000 A4 Sedan Sport 1.8TQM - Hibiscus - Tan two-tone - All stock - SOLD
    2001 Allroad 2.7t - Atlas Grey - Grey / Grey - SOLD
    2000 A4 Avant Sport 1.8TQM - Silver - Black
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    2013 Q5 2.0t - Black - Black
    2003 RS6 - Avus Silver - Black / CF
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Pull the whole strut assembly and take to a local machine shop with a 100 ton press. Best $15 I've ever spent.
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Apr 30 2010
    Miami Valley, Ohio
    Lots of heat and an impact on the bolt head broke them free.
    Jan 06 2013
    Ann Arbor, MI
    For future reference, I always use MAP gas. I don't use the blue torches anymore. Go with the yellow. That is, if you hadn't been using that already.
    09 Audi A4 2.0t Quattro - Stock - Automatic
    98 Audi A4 1.8t Quattro - Stock - Automatic - AEB
    Veteran Member Three Rings Lornnn's Avatar
    May 01 2011
    Wisconsin
    Also for future reference put a jack under that whole assembly and lift it up... don't put so much stress on the top control arms with the suspension hanging like that. Once you jack the knuckle up I bet you'll be able to get it out easy.
    Dec 05 2007
    Place anti-seize on your new pinch bolt before placing them in. Then anytime you have the opportunity, take it out and place more on. I do this on one side that I had work done on years ago. The other side is going to be a nightmare breaking free.
    Veteran Member Three Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    Also, put a nut on the end of that bolt before whacking it with a hammer. You don't want to mushroom the tip.
    I've seen people use this method with success:
    http://www.passatworld.com/forums/61...easy-pics.html
    2008cc - PTE6262 - Lugtronic - ID1700Xs - IECVA1s
    --> first start <--
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Do like the one guy said and take the whole thing out and use a press. You stand less of a chance of causing more damage that way. While heating will work, it will ultimately weaken the metal and there has been more than a few members who have broken the upright in just that spot. Then when you put it back in, use grease or something in there.
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    I found that lots of PB blaster and an air hammer worked well for me, didn't have to use heat.
    Jason
    ECS Tuning your #1 source for all things German automotive
    Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
    Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
    sales@ecstuning.com | customerservice@ecstuning.com
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    The good ole' blue wrench is always your friend
    Another thing to try is a 50/50 acetone-ATF mix. It makes PB look like a little bitch.
    Also, on a somewhat related note, ATF is awesome for getting dirt and grease from under fingernails.
    Established Member Two Rings 1999blacka4's Avatar
    Aug 09 2012
    1999 1.8TQM
    Impact gun
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    I had to drill mine out. Probably the worst thing Ive had to do to my car. Replace with new, and smother in anti seize.
    1998.5 A4 1.8TQM
    Jan 06 2013
    Ann Arbor, MI
    Quote Originally Posted by arorem View Post
    haha you know that ATF can cause liver damage and other serious health problems just by coming into contact and absorbing into skin? Get a dollar store scrub brush, swipe it across a bar of soap and scrub your fingernails with that, it works great and has no chance of health disorders!
    But yes, ATF has awesome cleaning capabilities, for corrosion and it is the best carbon buildup breaker I have ever used.
