Results 1 to 14 of 14
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    DIY: Big 3 Ground Upgrade.
    Hey guys, I was experiencing some dimming of my lights from my music and with the use of my window switches. Decided I'd upgrade the grounds as this is a common problem across most platforms when you upgrade stereos. I remember someone asking for pictures so I just decided to make a quick DIY.. Hope it helps!
    I assume no responsibility whatsoever for damages that
    an end user may inflict upon their vehicles or themselves
    using information contained herein. Proceed with caution and care
    when performing modifications to your vehicle. Be advised
    that making modifications to your vehicle may void your manufacturer's warranty
    What we're going to do is upgrade the
    • A (-)Chassis - Battery,
    • B (-)Chassis - Engine block
    • C (+)Alternator - Battery
    Sorry I stole this pic off the internet because my engine bays too dirty to take any useful pictures.
    it gives you an idea of where the wires have to go.
    So I picked up some 4ga car audio power wire and some ring terminals.
    • 7.5' Feet of 4ga wire
    • 5 Ring connectors
    • FUSE FOR ALT TO BATTERY + POWER
    THE FIRST STEP IS TO DISCONNECT YOUR BATTERY.
    The next step is to cut the wire to appropriate lengths.
    I chose to cut
    • A- 12"
    • B- 18"
    • C- 60"
    YOU MAY WANT TO CUT DIFFERENTLY.
    Getting started
    C- Alternator to + battrery
    run a POSITIVE (+) wire from the POSITIVE sided of you battery to the nut located on the alternator. The nut is visible between the 1st and 2nd runner of the intake manifold.
    Here is a picture looking through that runner.
    Then you can run it through the grommet located under the the battery and above the transmission.
    Remember to put this to POSITIVE. You can not remove the original wire there because it runs to your starter also.
    EDIT: BE SURE TO FUSE THIS WIRE TO AVOID OF ENGINE FIRE, SEE COMMENTS.
    B- Engine to Chassis.
    this is located on your passenger side frame rail. Right next to your motor mount. Its easiest to access from underneath. Here is a picture for reference sorry that there is so much going on in the picture focus on the brown wire.
    again here I ran the wire next to the original one.
    A- Battery to Chassis.
    last step, pretty simple. Connect wire to negative side of battery and to chassis. You can either replace your original or run another one next to it.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    helps if you can clean those contact points up with a wire brush to.
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Great write-up, I would strongly suggest fusing the power line though. I made the mistake of not doing so and my engine bay caught fire from the wire slipping and shorting out. I lucked out and put the fire out before there was much damage.
    DG '02 A4 1.8TQM
    My Build Thread
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by agart View Post
    Did the same, except mine caused a lot of damage
    - Clint
    Jan 13 2010
    Toronto Canada
    the power wire from the alternator?
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by iamshayan View Post
    Yea, unless the wire falls off directly at the battery with no way of swinging to hit the frame then you leave the potential for shorting. Also if anything were to happen in the engine bay and the insulation melted off the wire you would have the same result.
    I've never been so scared about the future of my car as I was when this happened. Electrical wires do not go out with regular fire extinguishers because it keeps going until the battery drains entirely.
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Four Rings daihashi's Avatar
    Apr 03 2010
    houston, tx
    Regarding the insulation.. that's one of the main reasons I tell people to just go with 0ga weld wire. It's super flexible and is made to withstand a crazy amount of heat, more than what radiates throughout the engine bay.
    What size fuse are you running? I actually ran a breaker on mine for a while before giving it to a friend. It was similar to this one:
    http://www.amazon.com/Stereo-Amplifi...dio+breaker+0g
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by daihashi View Post
    Just a basic ANL fuse, I believe it is a 150 amp but it's possible it's a 200. I do have a breaker on my amp wire for ease though. I find myself disconnecting(breaking I guess?) that one somewhat often, looks exactly like the one you posted.
    I never thought about weld wire to be honest, I just had some 0ga sitting around from my stereo install and decided I'd put it to use.
    DG '02 A4 1.8TQM
    My Build Thread
    Apr 02 2013
    above top secret
    Which location did you put the fuse? At battery or alternator post? Or both?
    Mar 05 2013
    CA
    Why add extra ground wires instead of replacing the stock old ones with fresh new ones, and bigger gauge? (to keep the engine bay simple)
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    Have to add this to the list of things I need to do before winter comes for the 2 B6's. One of them wouldn't turn on because the connection from the battery to alternator at the starter was corroded. Cleaned it up a bit and it works fine now, but I'm sure 14 year old battery cables won't be realiable for long.
    Is 0AWG weld cable overkill or worth it? Going to be doing all the ground cables and alternator to starter to battery positive cable.
    Brilliant Red B6 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Grey B6 A4 1.8T quattro
    Brilliant Red B7 A4 2.0T quattro
    Jan 24 2010
    Paramus,NJ USA
    You do realize now that you have upgraded the wires.Depending on your needs of the sound system and other various electronics in the car the lights will now DIM even more??If you have a pretty good system.Just saying something grounds arent enough.Different alternator might be a better solution.
    Ziddy Autowerks
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by maxiz1 View Post
    You always want the fuse as close as possible to the source. In this case, the battery. You could say the alternator is also a "source", but only when the engine is running.
    Apr 02 2013
    above top secret
    Yeah.. thats the whole confusion is all about
