Results 1 to 15 of 15
    Senior Member Three Rings Dayne's Avatar
    Aug 13 2012
    Bunch of crap
    Colorado
    Passenger window, bein' a bitch!
    My passenger window has worked perfect since I bought the car about 6-7 months ago. Today while I was running around my friend rolled the window down for a minute. Tried to roll it back up. and it didnt... rolled up about 2 inches then just went back down. because it was blizzarding outside I had to pull the window up while he held up on the switch. took about a minute but we got it all the way back up. Did some searching and it seems most people don't really like to help out much on this topic. But from What I've read it can be the window reg. Not really wanting to spend $100 on that is there anything else I should look into before I take the door panel off and get a closer look? Anything to look for specifically once I have the panel off?
    TIA
    Dayne
    Edit:
    How likely is it that it just came off the track? Messing with it a bit more it seems that's all that has happened. It's like 0 degrees outside and its not looking like its going to warm up anytime soon so its probably going to be a week at least before I'm messing with this.
    Edit Again:
    I just remembered a few days ago I had closed the door and it sounded different from the usual "thud!" tried opening and closing it a few more times and it seemed fine so I shrugged it off and the window hasnt been rolled up or down since then. I'm really starting to think it just came off the track.
    The Red Laser!
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    They have these plastic clips in there that like to break. I think my rear pass just ate shit the other day, been afraid to roll it back down to find out
    There is a guy that sells them, I think vtraudi here or try http://regulatorfix.com/product_info...8ca2797dd8659a
    Aug 13 2012
    Bunch of crap
    Colorado
    Quote Originally Posted by zillarob View Post
    Nice! Ill have to take a look and see whats going on in there.
    The Red Laser!
    Senior Member Three Rings ReDLiTe's Avatar
    Mar 24 2009
    Pittsfield, NH
    Like said above.. there are green clips that hold the window to the arm attached to the regulator. usually if there are problems it's best to replace the whole assembly as something is misaligned and you'll be chasing it forever. I have a used assembly if interested pm me.
    When in doubt, when in fear, drop a gear & disappear!
    2000 S4 6mt Stock (dd)
    2000 S4 6mt Stage 3
    May 23 2008
    birth place of land speed reco
    If it is not the clips that are mentioned above, then it could be the plastic rollers that holds the cable in place, open it up and report back. You can get the rollers from home depot if it is the case. Good luck
    Aug 13 2012
    Bunch of crap
    Colorado
    So I got around to pulling the panel off and I found that both plastic clips are cracked. Not "broken" but obviously cracked. This is what I found
    Before I buy these clips:
    I just want to double check and make sure that these white clips are the same as the green ones and the ones I need.
    EDIT: Sorry about blurry quality not to much help but whatever I guess. Just want to make sure those green clips are the same as the white ones on that link.
    The Red Laser!
    Nov 16 2010
    WetSide, WA
    Thats them, they are an updated version I think.
    PM vtraudt on here or nef, I think it may be his site.
    Dude in here http://www.audizine.com/forum/showth...hlight=vtraudt
    Aug 13 2012
    Bunch of crap
    Colorado
    PM'ed him
    The Red Laser!
    Nov 16 2010
    WetSide, WA
    Hes a good dude. Sent me a set for helping him out with some stuff.
    I havent installed yet but they are white.
    Aug 13 2012
    Bunch of crap
    Colorado
    Nice, any idea on how hard this is to do? I would assume there is a DIY. I just havent looked yet.
    The Red Laser!
    Nov 16 2010
    WetSide, WA
    Not sure, I might be finding out soon though. Dont think anybody sells the rear sets though.
    Aug 13 2012
    Bunch of crap
    Colorado
    The website has the rears available for $6
    The Red Laser!
    Nov 16 2010
    WetSide, WA
    Nice! He didnt have them before.
    Never looked at the drop down, lol.
    Aug 13 2012
    Bunch of crap
    Colorado
    Good to know. Pretty sure my girlfriend broke em. She loves to slam doors for some reason. :(
    The Red Laser!
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    RegulatorFix Dude (vtraudt) speaking:
    - I haven't found a manuf that makes the rear clips for the B5 (have B6/B7 rear in stock).
    - color of front: my original B5 front were green. Typically, the replacements are white, but color can change (and does not matter). For the B6 front (and C5 front for example), I have had orange, pink, blue, white, yellow production batches over the last 12 months. Material on all of those mentioned here is POM (very good coefficient of friction, low wear). SOME clips (some complex shape BMW) are made from ABS (a bit tougher/stronger, but NOT as good friction and wear). ABS clips are typically in the 'natural' color (beige/grayish).
    My regultorfix emails:
    [email protected]
    [email protected]
    Website: we had lost the entire content (host company) and had to start from scratch. Only recently active again with just a few products entered. Working on it.
    www.regulatorfix.com
    http://www.regulatorfix.com/
    Ebay store:
    http://stores.ebay.com/RegulatorFix?_rdc=1
    http://stores.ebay.com/Car-Stuff-Regulator-Parts-Turbos
    B5 front DIY links just in case (if you have other/good links, send them).
    B5 Rear:
    http://forums.audiworld.com/showthread.php?t=321269
    http://www.audizine.com/forum/showth...regulator+rear
    B5 Front:
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.kraftwerkturbo.com
