My transmission goes into limp mode after a few miles. Here is the vag-com reading.
Control Module Part Number: 8D0 927 156 BN
Component and/or Version: AG5 01V 1.8l5VT USA 8508
Software Coding: 00000
Work Shop Code: WSC 00000
1 Fault Found:
00652 - Gear Monitoring
27-10 - Implausible Signal - Intermittent
According to ross tech wiki:
Possible Causes
Automatic Transmission Fluid (ATF) Level not OK
Vehicle Speed Sensor (G68) dirty/faulty
Impulse Wheel dirty or Installation faulty
Gearbox Speed Sensor (G38) dirty/faulty
Multi-Function Switch (F125) faulty (but not detected)
Clutch or Valve Body faulty
Automatic Transmission Fluid (ATF) Pump faulty
Possible Solutions
Check Automatic Transmission Fluid (ATF) Level
Check/Clean/Replace Vehicle Speed Sensor (G68)
Check/Clean/Replace Gearbox Speed Sensor (G38)
Check/Replace Multi-Function Switch (F125)
Check/Replace Clutch and/or Valve Body
I replaced the vehicle speed sensor with one from ECS tuning, I don't think that's the problem, but you never know. I could try swapping in the old one to rule it out.
The transmission has no signs of leaking, but I will check the level tomorrow.
How common is it for the gearbox speed sensor to go bad? In all my searching about limp mode, that has never come up, but perhaps people got a different code than I got.
I have always seen this problem point to the multifunction switch.
What do you guys think? Where would you start, assuming the ATF level is fine?
