Originally Posted by
airjawed
I noticed that when my engine gets hotter the numbers get more positive. Is this from the expansion of the engine? It is in a V so the two heads are moving further apart as the block heats up...also they are both moving further from the crankshaft too right? The belt is not stretching so this overall engine expansion should make the phases all go more positive(relative to cold engine).
I do have a question though: How can you tell if your CCTs are actually adjusting? In block 094 in basic setting it will only tell you that the system is working(after increasing rpm above 2K). Output tests will let you know if the solenoid is working. But what about if the CCT is actually moving? Blocks 090-093 seem to reflect the timing but to my understanding give only an indication if the overall timing is correct. When I rev my engine in neutral and look at block 093 it doesn't change. Shouldn't it change as the tensioners get activated? Or does it only happen when in gear?
To give you an idea, here is a snapshot of the table that ecu uses to activate NWS (that's what it is called in bosch's nomenclature):
Y-axis is RPMs, x-axis is load (100% being max without activating turbos, basically atmospheric pressure open to engine).
So as you see, at 3k rpms, you have to really step on it while driving to to activate it. Below 2000rpms, you will never activate it since the engine can't generate enough flow (load) to step into nws activation area.
