I was wondering what the proper way to get the ECU to adjust fuel trims and run through its emission self tests is.
How do you go about it after changes in tune or fixing/clearing codes or in my case putting in a new battery?
My thoughts:
1) Cold engine
2) Clear codes
3) Throttle body adaption(either vagcom or wait for ECU to do it)
4) Start car and let warm up a few minutes
5) Drive slow speeds(25mph) with moderate accelerator positions for about 10 minutes
6) Get on highway and drive moderate for about 10 minutes...no WOT
7) Back to surface roads for 10 minutes
8) Park car and remove ignition for a few minutes
9) Check vagcom blocks such as LTFT, rpm/load barriers, boost control and of course codes.
10) See what readiness codes are not set and then set those.... as seen in Bentley or Ross Tech site(generating/setting readiness).
I'm specifically interested because I had codes for cat efficiency emissions and overboost when I generated readiness without doing a drive cycle. On another occasion I cleared codes and then did a drive cycle followed by generating specific readiness and then no codes. Or maybe the other way around....I forget.
My logic is that the ECU should first adapt some of the engine management like fuel trim and boost control and then check on the emissions side. Getting the sequence right would also be important for tuning. Would love feedback from you guys on this.
