Results 1 to 5 of 5
    Veteran Member Three Rings djsnowman777's Avatar
    Apr 22 2008
    Queens NYC
    Xenon headlight question b7
    I got a steal deal on a set from craigslist. they guy said they came off a 2008 Audi s4
    my concern is that one headlight uses the short ballast and the other long one. will that have any effect on the install ?
    also it looks to me like the projectors are slightly turned and not straight ? I am guessing I can turn them once I put new bulbs in ?
    haven't had time to take a real close look at everything but my mine concern right now is the ballasts and lining up of the projectors.
    the part number is 8E0 941 004 AP is one part number I got of the headlights ..the other one didn't have any.
    Aug 19 2005
    07 A4 Avant S-line 6MT
    CNY
    RE: Xenon headlight question b7
    Not sure if all HIDs do the turning bit...bit they might just need to be powered to auto align. Mine adjust everytime I turn them on.
    Sent from my Lumia 900 using Board Express
    '21 SQ5 Ultra Blue
    past: B7 Avant 2.0t S-line Manual [CTS K04, 034 K04 Tune, Golf R intake cam, CTS HFC, Stasis Exhaust, BFI Snub, 034 Street Mounts, Apikol Race Diff Mount, Hotchkis 29mm RSB]
    Oct 16 2008
    South Florida - Ft Lauderdale
    One of the headlight is adaptive and the other one is not
    If you upgrade from halogens, do not worry about the beam not being centered (as long as its just a bit off centered otherwise consider them broken internally), once installed on the car, you can adjust them with the upper Allen adjusters
    Phil
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Re: Xenon headlight question b7
    Similar question fellas. Great deal on a set of adaptive xenons. I can retrofit to car with Halogens, right? Meaning it doesn't matter they are adaptive, does it? Thanks!!
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Yes you can swap. Since you don't have the sensors on your chassis, you will adjust the beams manually and they will be fixed in that position.
