Results 1 to 35 of 35
Thread: ESP on my s4 b8
Hybrid View
    Established Member Two Rings x610326's Avatar
    Jun 27 2009
    2001 Audi S4 B5
    Streamwood, IL , 60107
    ESP on my s4 b8
    Hey guys, is there any special coding in order to be able to turn off the ESP. When I press my traction control button it only disables my ASR but not my ESP. And when I press and hold it it doesn't do anything. How do you guys do it? I have 2011 s4 b8 prestige package with sport diff and its DSG.
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    Hold it longer, 5 sec or more
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Jun 27 2009
    2001 Audi S4 B5
    Is there any coding that I could do with vag-com to get it working?
    Jun 27 2009
    2001 Audi S4 B5
    I did but it doesn't work. One push is only ASR right and when you push and hold it, it only says on mine restricted stability and the ESP light doesn't show up on my RPM gauge
    Veteran Member Four Rings Jones2012s4's Avatar
    Nov 09 2011
    Michigan
    No that is correct. Push and it tells you ASR is disabled, hold for a few more seconds and it will then say "Warning, restricted stability". That is the only notification.
    2012 S4 - DSG B8 - [email protected]
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    so no way to fully disable it , i want to do donuts in the snow and let the ass hang out some :)
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Veteran Member Four Rings PaperishPlastic's Avatar
    May 13 2007
    Rats
    San Fernando Valley
    Quote Originally Posted by theswoleguy View Post
    When you push and hold the button until it says restricted stability ESP is fully off. You can't do donuts because your car is stock. also since you have an automatic the transmission probably cuts power too. I do donuts in the complete dry with my car.
    B8 Signal Green
    Nov 09 2011
    Michigan
    Quote Originally Posted by PaperishPlastic View Post
    I've done donuts and I am stock for all intent and purposes. ;)
    Just crank the wheel full tilt in either direction and mash throttle.
    Back to OP though, if you can't understand how to hold the button for 5 seconds in one single notion(don't release it and press it again), you probably shouldn't be doing donuts. :) I believe it even explains how to disable ESP in the owners manual.
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by Jones2012s4 View Post
    please see attached video of the cycles my ASR button goes through
    http://www.youtube.com/watch?v=banHv...ezuRAA&index=1
    as you can see it never goes to fully disabled only limited.
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    it looks like it went off to me..
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    You are seriously holding it for 5 straight seconds?? On the FIRST push. Do not push it twice.
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    I think you actually may be holding the button down TOO long. Release it when the warning shows ONLY "WARNING - restricted stability", then try it.
    Keep in mind that turning off traction/stability control doesn't change the fact that the car is AWD, and that quattro will still try to route power to the front wheels with the back wheels spinning. It's not going to be exactly the same sensation as drifting a RWD car....
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Oct 25 2008
    If you push and hold it. You can do donuts/ get tail happy
    Dec 07 2012
    Atlanta, GA
    Re: ESP on my s4 b8
    Quote Originally Posted by SASKCHAUCH View Post
    Mine doesn't when I push and hold I do get the reduced stability but as soon Asia get ass happy it brings it back :(
    Sent from my DROID BIONIC using Tapatalk 2
    Veteran Member Four Rings FITZ TITS's Avatar
    Phila
    You actually named your car Asia?
    May 03 2012
    NA
    Push and hold it. Don't push it, then push again and hold it. It's a single step.
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by FITZ TITS View Post
    lol tapatalk auto correct lol but no thats not her name, i dont really have a name for it.
    Jun 27 2009
    2001 Audi S4 B5
    Ok so now ill try it when there is snow
    Oct 27 2009
    Miami, FL | Boone, NC
    Re: ESP on my s4 b8
    OP, what year is your car? In my 2010 A4, when I hold my button the DIS will actually say "ESP off."
    I tried turning ESP off in my friend's 2012 6MT S4 and couldn't do it. I could tell I never fully disabled it because the stationary rev limiter stuck at 4k RPM - I believe with 6MT you can rev past 4k when ESP is disabled.
    Sent from my Galaxy Nexus using Tapatalk 2
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Dec 07 2012
    Atlanta, GA
    Re: ESP on my s4 b8
    Quote Originally Posted by jdwk View Post
    I have a 2013 with 6MT and the sport diff. If I press the button quickly I get the message: "Stabilization Control (ESC): Sport. Warning! Restricted Stability." If I hold it for 3-6 seconds, I changes from "Sport" to "Off". If I hold it longer than that the button ceases to work until I turn off the car. It will still light up the "ESC off" light above the cluster if you hold it down, but it turns off as soon as you release it.
    Not sure why mine says sport instead of ASR off. Even my manuals says it is supposed to say ASR. Maybe this is something they changed for 2013 but didn't update the manual.
    Very similar to mine, wonder if there's coding in vag to turn it to that, since it seems to be different from several cars
    Veteran Member Four Rings Seinsmeld13's Avatar
    Mar 23 2009
    2020 Porsche Spyder
    Niagara Region, Canada
    I have a 2013 Stronic. In dynamic it sends most of the power to the rear. I can do donuts very easily as most men will do in the snow. Mine shuts off fully the same as my 2010 did. This car is rear biased compared to my TT225 with Haldex. Even that one I could do donuts in.
    2018 RS5 2020 SLC 300
    Weekend and summer drive 2020 Porsche Cayman Spyder
    Established Member Two Rings r32breeze's Avatar
    Sep 17 2010
    2011 Audi S4
    Seattle,WA
    I was able to do snow donuts with my old R32 that has FWD based haldex AWD and most importantly you can't turn off the ESP completely for Golf 5 R32 / 6 R. However for S4 press and hold the ESP button for 5 seconds will turn off the ESP completely.
    My R32 donuts:
    https://www.youtube.com/watch?v=LBCmzjZnIpM
    I will upload a short video of my S4 donuts if I can find it.
    Jan 12 2013
    First thing this thread reminded me of. Relevant part is 1:40 seconds in.
    Dec 07 2012
    Atlanta, GA
    Re: ESP on my s4 b8
    I don't think us with stronic can. My 2011 couldn't and tried it last might when I traded it in on a 2012 with ads and sport diff...
    Maybe possible with vag coding as it was on my mkiv GTi
    May 03 2012
    NA
    Don't you have to turn it completely off for launch control? I would think if your car is 2010+ you can turn it off..
    Dec 07 2012
    Atlanta, GA
    Re: ESP on my s4 b8
    Quote Originally Posted by 13S4 View Post
    Asr has to be off for me to launch.
