Hello Audiziners! We decided to combine all our product threads into one giant thread so it is easier for you guys to go through, and the forums will get less cluttered. As we make more and more products, we will continue to update this thread! And remember, you are always welcome to call us at (310) 294-8108 or stop by the shop if you have any questions!
Suspension:
When Quattro is not enough, we are here to help! Even though the B8 S4 has very competent driving manners, there is always room for improvement. EuroCode has developed an entire suspension set up, comprised of multiple parts, to optimize the sportiness of your ride.
EuroCode ÜSS Adjustable Anti-roll Sway Bar
Swaybars are a great way to reduce the body roll caused by sharp lane changes. If you feel the ride is a little sloppy in the corners and the car sways or rocks during sharp turns, then this is the perfect item for you. EuroCode’s ÜSS front stabilizer bar measures in at 32mm and has two adjustment settings allowing full stiffness or a 30% reduction. EuroCode’s ÜSS rear stabilizer bar measures in at 25.5mm and has two adjustment settings allowing full stiffness or a 30% reduction. We also included brand new OEM hardware so you don’t have to re-use your current bolts. Combined with a set of KW V1 coilovers or H&R springs, and your car will ride on rails. What sets this B8 S4 sway bar set apart from others is that it is designed to work with our front and rear end links to make the car feel even more planted and sporty.
EuroCode ÜSS Billet Aluminum Adjustable Front End Links and Rear End Links
Further refining the car’s driving characteristics, the end links are designed to make the car more planted through turns. Right away you will notice the attention to detail: the body of EuroCode’s ÜSS front adjustable end link is T7 billet aluminum with a clear type III hard anodize finish, laser engraved with EuroCode’s logo and features a threaded body to house threaded heim joints. The heim joints feature both left and right hand threads for ease of adjustability while on the car. Adjustability range is 155mm to 195mm. The ÜSS adjustable end link is compatible with EuroCode’s ÜSS front adjustable sway bar, the OEM sway bar and any aftermarket bar that is designed to utilize the factory end links. End-links come as a pair, left and right.
Alu Kreuz Drivetrain Stabilizer
The last part of our suspension set up is the drive-train stabilizer (or front brace) that we have dubbed Alu Kreuz (pronounce “alu kroitz”). This has been a big hit with you B8 S4 guys, and anyone who has installed one will tell you it makes the car not only take on sharp turns better, but overall makes the car an even bigger joy to drive. One of the many criticisms we have of Audi is their steering feel- on center it is numb, a little sloppy, and feedback is generally non-existent. Through testing, we found quite a bit of chassis flex from the stock brace, which is actually 9 pieces welded together. In no time, Dave (a.k.a. The Chip Father) set out to design a one-piece brace that tightens the steering feel, gives it more feedback, and makes the steering more point-and-shoot. Everyone will benefit from this mod, because even if you don’t track, you will notice a difference in any sharp turn (parking lots included) and the steering wheel will stay linear on long highway commutes instead of moving sideways. As per our other suspension items, quality is top notch- billet T7 aircraft aluminum construction, type III hard anodized coating, and all necessary provisions to attach the OEM sound deadeners. It requires zero modification to the vehicle, and works perfectly with the OEM power steering cooler. The Alu Kreuz is also nearly two pounds lighter than the OEM brace and greatly improves chassis torsional rigidity.
Headers
To really unleash your force-fed beast, you need EuroCode’s long tube headers. Months of research and development went into making this system, ensuring optimal horsepower gain. We dynode our in-house bone-stock B8 S4, with and without headers on the same day (no other modifications done), and found a 30.2 WHP gain/23.2 WTQ gain. Not only will this system give you a noticeable power bump, but the engine howl is delicious, especially when paired with the Milltek Resonated catback exhaust.
Meisterwerk Adjustable Short Throw Shifter
For those refusing to give up the third pedal, this is a must-have upgrade. The EuroCode Tuning's Meisterwerk Adjustable Short Throw Shifter is not your ordinary short shifter upgrade- height adjustability, ease of install, and higher quality components make this a premium upgrade for those looking to get the most out of their car. The Meisterwerk shifter offers up to a 42% throw reduction and up to a 38mm height reduction, using a unique billet aluminum modular assembly. The result is a precise accurate shift feel that communicates directly with the driver.
Features of the Meisterwerk Adjustable Short Throw Shifter:
•CNC machined, lightweight build, red anodized billet aluminum main body assembly (precise to .005").
•CNC machined, replaceable Delrin bushings and reverse catch (precise to .005").
•Bronzoil, replaceable self lubricating bearings for the throw pivot.
•Black oxide coated steel shift rod, 38mm of height adjustment (achieved w/out removal), machined to fit the OEM shift knob.
•Three adjustment points for the throw, overall reduction of up to 42% from the OEM shifter assembly.
•Sealed spherical bearing assembly, pre-lubricated for ease of installation.
•CNC machined, lightweight build, red anodized billet aluminum bearing race (precise to .005")
•Optional retention of the OEM plastic ball joint and ball socket
Thanks for all your support guys! We consider it both a pleasure and a priveledge to be serving the Audi community. We want to continue to develop this platform by producing high quality products. Whatever your car needs, hit us up and we will take care of you!
Sincerely,
The Team at EuroCode
