Page 2 of 2 FirstFirst 12
Results 41 to 66 of 66
  1. #41
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by SandmanRUS View Post
    Hmm.. Interesting is there one more sock filter in DS tank?
    And is it possible to attach second hose by some adapter, that bifurcate on sock filter and second hose?
    I'm guessing that is possible, but for the time being, I went back to oem. In process of trying to fix other things, went back to oem lpfp.
    Still have the DW300 if anyone wants it.
    2021 Audi S4, P34 Intake
  2. #42
    Feb 10 2012
    parts
    Napanee, ON
    Anyone know where i can source one of the small filters on the bottom of the pump from??? I think jim sent the pump to me and i possibly didnt see the filter in packaging and tossed it out. This is going to be a temp solution till i sort out some other car issues i just need to get her running. Or will the stock filter work on the dw301 pump?
    I know there is probably an easier solution for the lpfp but currently cannot due to holidays.
  3. #43
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by canadianA4B7 View Post
    I think seal66 had sourced some different filters. I definitely sent you the one I had. ...
  4. #44
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    I might have a spare in the garage.....
  5. #45
    Feb 10 2012
    parts
    Napanee, ON
    Thanx big time guys. Jim was right he sent it. Luckily for me in tossed the package under the seat b4 crossing back to canada :-) so i found it.
    Suggestions to weather i should use the original lpfp controller or the RS4 unit with the new pump?
    My car actually is reading im out of fuel, but theres a half tank at least?????? Does this sound like anything else?? The basket seems to be fine and i cannot read any codes cuz the battery died.
  6. #46
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Found the dirt that was causing your fueling issues!
  7. #47
    Feb 10 2012
    parts
    Napanee, ON
    Mine was completely clean. When I installed the rs4 controller I washed all that junk out. Mine was actually green when I cleaned it. Not nearly as dark as the images in this thread. I checked the wiring aswell when I pulled the pump out no damage by accident when rs4 controller was installed.
  8. #48
    Nov 23 2013
    ABITIBI
    Hey what I do with the second skinnier hose on the fuel pump? I just let it hang in the tank ? what does it suppose to do?
  9. #49
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by pzupp View Post
    Pm sent
  10. #50
    Veteran Member Four Rings Shanster's Avatar
    Jun 02 2011
    2016 B8.5 Allroad, 2022 Volvo XC90 T8 Recharge R-Design
    Maine
    Jimrobbington,
    To confirm, you're still using the stock LPFP, correct? Any fueling issues since switching back from the DW300? I'm trying to troubleshoot some fuel cuts/hesitation at WOT in higher gears (5th mostly) and I'm wondering if my LPFP is going out on me (haven't scanned yet...wondering if I have P0089). I plan on upgrading my HPFP for JHM Stage 2, but want to make sure the new OEM LPFP will be fine for this tune too.
    Thanks,
    Brent
    Brent
    2016 B8.5 Monsoon Gray Alload
    Sold: 2007 B7 A4 Avant 2.0T 6MT, 2014 B8.5 Ibis White Alload
  11. #51
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Shanster View Post
    Jimrobbington,
    Thanks,
    Brent
    Can you take logs? If so I can tell you.
  12. #52
    Jun 02 2011
    Maine
    I just need VCDS to do that?
    Brent
  13. #53
    Aug 31 2011
    Lathrop
    Yup!
  14. #54
    Dec 03 2008
    2018 SQ5
    Jimrobbington,
    Thanks,
    Brent
    Yes, I'm back to OEM and its been running fine! Good luck
  15. #55
    Jun 02 2011
    Maine
    Cool...i know you mentioned all this in the PM (sorry for making you repeat yourself!). Should I just call Lathrop when i have it in hand?
    Brent
  16. #56
    Veteran Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Sorry for the necro. Is this a part that slowly fails or catastrophic?
    My respray thread
  17. #57
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    The lpfp is going to give up at some point.
    Sent from my SM-G920P using Tapatalk
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
  18. #58
    Oct 24 2015
    Perth, WA
    So the USP version is no longer?
    bump?
    My respray thread
  19. #59
    Oct 24 2015
    Perth, WA
    Bump. I upgraded mine in about 1 hour last night. Simple mod, fixed my LPF issues even though I had a new LPFP. Idles and runs much nicer, definitely an improvement. Actually a really easy mod.
    My respray thread
  20. #60
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Does anyone have photos for this upgrade? They're no longer linked because photo bucket is trash. I'll be rigging up the Walbro 450LPH LPFP in the next few weeks, and controlling it with TorqByte's CM5-LT and PM3 combo on my GTX2867R (thanks CanadianA4B7) race car (yes, I'll get around to making a build thread once the season is done).
    I'm a visual learner, and would benefit from seeing the process before I undertake it.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
  21. #61
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    I'm bumping this old thread as I'm having fuel cutting issues at high rpm with a walbro 450 and would like to see what you guys did to solve this problem.
  22. #62
    Feb 10 2012
    parts
    Napanee, ON
    What lpfp controller? What prv? Who’s tuning?
  23. #63
    Dec 19 2013
    I dont have a controller. Not sure what prv is. Motoza is tuning it. I asked here because I have a 2005 B6 which is the last year B6 and they decided it was a good idea to use B7 fuel pump assembly for this year. So nobody in the B6 forum can help me as none of them seem to build 05's. Mostly 02-04. I pulled my fuel pump out to upgrade it for my build and realized it's a B7 pump and basket. Totally different from B6. So I got JHM's B7 kit with the bracket and whatnot. And instead of using their pump I decided to go with a walbro 450 and never worry about if I'm getting enough fuel or not.
    Upon finishing the assembly I noticed the spring loaded top portion of the basket would make contact with the hose that came off the top of the pump and had clearance issues . So I trimmed the nipple on the top of the walbro pump in half and clamped the hose back on. It cleared and the car was fine until I came down to a quarter tank of fuel. Then I noticed at WOT high rpm pulls on the highway the car leans out and cuts fueling and the o2 sensor is trying to compensate but it eventually just jerks and cuts fuel . Jhm claims fuel cutting out is normal if cornering hard with less than quarter tank but I was not cornering at all.
  24. #64
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Did you hook up the T in the JHM kit that draws fuel from the other side of the tank? If not, you’ll have fuel cuts when the tank is low.
    Does the B6 year that uses the B7 fuel pump also use a fuel pump control module like we do? It it does and you’re running the stock fuel pump controller I doubt you’re supplying enough amps to run that Walbro 450 at WOT. I bet you’re way below requested fuel pressure because the stock controller limits duty cycle and can’t supply enough amps to power the pump at the flow rate it needs.
    Of course if the B6 doesn’t use the fuel pump control module like we do, none of that last bit probably applies.
    Are you saying that with a full tank, everything works as it should? If so, just fill up before you get to a 1/4 tank or make sure you’re getting fuel from the other side of the tank.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
  25. #65
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Quote Originally Posted by Furly View Post
    Did you ever figure out what was causing these problems for you?
  26. #66
    Mar 23 2022
    Finland
    I know this is a 6 year old thread answer but I've seen your responses to other threads and you seem quite knowledgeable in this stuff. I'm just asking if you'd know how does the JHM kit draw fuel from the DS tank if in this install video the valve points away from the PS tank.
