Page 3 of 49 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 1943
  1. #81
    Sep 18 2012
    State College PA
    I understand that the ball bearing chra will not spool "much better". I bought it so that I can run high boost in case I ever went crazy with the motor. I bought the 5858 to hopefully help with that spool issue and I would still like to make some respectably power.
    Also can someone tell me if this coolant hose that goes to the coolant fill tank is suppose to get a oring on the bottom hose (when the coolant hose is properly installed). All the other female hoses have a gland on the inside that holds an oring, but this one does not, so how does this thing seal????
    I'm not sure on that hose I'll see if my junk motor has one of those hoses on it still...
    As for your turbo don't worry t will spool just fine if it's anything like my S256 ;-)
    And I was just addressing Meow because he said "Also, I hope you got a ball bearing turbo not a journal bearing :)" that's all ;-)
  2. #82
    Sep 18 2012
    State College PA
    Hit that side of the motor with brake clean... the rest of it looks so nice you're not allowed to put it back in like that haha :-P
  3. #83
    Oct 27 2011
    TOYS
    Philly Suburbs
    I will
    My engine bay is nice and clean:
    Simple Green For The Win!!!!
  4. #84
    Sep 18 2012
    State College PA
    I will
    It's a lot cleaner than mine lol :-P
    I figure I will make mine nice and spotless when I put my built engine in. I'm still proving things out for now lol
  5. #85
    Sep 18 2008
    lancaster,pa
    Looks good... but I don't think that Throttle Body Boot is gonna work for ya :-P
    I'm going to recommend buying some shops lights. This looks amazing. Wish I had more time off, I'd drive up and help.
    Frankenturbos, Stage 3 tuning by Jfonz Tuning.
  6. #86
    Veteran Member Three Rings lo-lyfe's Avatar
    Mar 27 2012
    2006 tuned & lifted F350 6.0 Powerstroke, 1990 built Ford Bronco 5.0l 302, Built Stage 3 b5s4
    out on the farm, in the Mitten
    I will
    That engine bay will be my inspiration when I start tearing my ride apart. Love a build with a sparkling engine bay. Great job!
    Stay tuned...
  7. #87
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by micahmr2 View Post
    The garage was just finished but they are the first thing on the list once I get the S4 out!!!
  8. #88
    Oct 27 2011
    TOYS
    Philly Suburbs
    She is in:
    Wastegate clearance:
    Up pipe clearance to secondary fire wall = PERFECT
    Breather setup:
  9. #89
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    To much connections to the same line , I would keep valve cover ventilations separate from carter .
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
  10. #90
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by UkuRiSh View Post
    What negative effect could this have?
    And this is where I left her for the night.
  11. #91
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I use silicone hose and kynar fittings from mcmaster carr for the spiders
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
  12. #92
    Sep 18 2012
    State College PA
    She is in:
    Breather setup:
    Sweeeeeeet.
    Looks good.
    I see you did the old valve cover flip... should make things easier.
    And the pcv setup will probably be fine... but if your catch can has multiple inputs then I'd make use of them and run things on their own lines... but it'll be fine ;-)
  13. #93
    Oct 27 2011
    TOYS
    Philly Suburbs
    Yea my catch can has 1 in and 1 out.
  14. #94
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by zillarob View Post
    I'm so doing this! Thanks for the idea!!
  15. #95
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    You will be fine, other than the 20 lbs in hose clamps of course! lol, interesting flip of the valve covers, it would have been simpler routing the breather hoses if you had not filped them but im sure you have your reasons. Intercooler Pipe clearance?
    RIP Daz, you will be missed.
  16. #96
    Oct 27 2011
    TOYS
    Philly Suburbs
    Tune is getting shipped today. Intercooler piping is getting cut and tacked today as well. I will hopefully have an update tonight with some more pictures!!!
    Can a mod please move this thread to the build section
  17. #97
    Sep 17 2005
    Fremont, California
    Loving the progress!!
  18. #98
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by Max@034 View Post
    Thanks Max! Today is day 14 since the car has been under the knife.
  19. #99
    Oct 27 2011
    TOYS
    Philly Suburbs
    Updates. Compressor to intercooler piping is done. I'm going to tackle the intercooler to TB piping tomorrow.
    Intercooler mounted:
    Blow off valve doesn't work here:
    Fixed:
    To my welding buddy:
    And my shortened power steering hose:
    Tomorrow is another day
    And my tune should be here Saturday!!!!
  20. #100
    Sep 18 2008
    lancaster,pa
    Looks great! Every thought about rerouting all that wiring under the intake manifold. I realize it be a pain to do but in the end may make for a cleaner install. Are you not recirculating the blow off valve? If not, how are you getting away with that?
  21. #101
    Oct 27 2011
    TOYS
    Philly Suburbs
    BOV is getting recirculated. There is no room under the intake manifold.... and if there was, there is no way to fit the harness in between the stock intake runners. Don't forget there is a flange on mating surface of the intake manifold to the heads...
  22. #102
    Established Member Two Rings TheKid84's Avatar
    Jul 01 2012
    audi a4 b5 1.8T
    cape town
    Love this build!!
    I love my so much but I just wish I didn't have to on it so much, but I enjoy it non the less
    My 1999.5 A4 B5 1.8T FWD thread/build
  23. #103
    Oct 27 2011
    TOYS
    Philly Suburbs
    Oh and I forgot to add that my fuel rail needed some massaging to clear the compressor:
  24. #104
    Oct 27 2011
    TOYS
    Philly Suburbs
    Also, who knows what the two connectors are for (what is each sensor for?) that go down to the trans, 1 by each axle?
  25. #105
    Sep 18 2012
    State College PA
    Looking from front of car:
    Left side (Passenger) is Back Up Switch
    Right Side (Drivers) is Vehicle Speed Sensor
    OF course then you have the Engine Speed Sensor on the bellhousing too.
  26. #106
    Sep 18 2012
    State College PA
    Go Blow Through like me then you can dump :-P hehe
    As for the wiring harness mine is tucked under the intake manifold in the back... It hugs over the top rear of the drivers valve cover then goes under the intake in the rear then comes out behind the passenger side head.
    But in doing this my VSS wire was too short by an inch so I extended it a little.
  27. #107
    Sep 18 2012
    State College PA
    You can kinda see where it goes around the back of the wastegate in this pic:
    Oh and I love my turbo blanket... I can do pulls to over 100mph and get out and put my hand ont he blanket :-)
  28. #108
    Sep 17 2005
    Fremont, California
    Looks like you have your turbo sitting more forward than absolutely necessary, making fitment of the fuel rail a bit more difficult. Remember you can position the turbo fore and aft between the manifold and the false firewall by tightening the top and bottom nuts on the exhaust manifold to merge pipe junction.
  29. #109
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Intercooler piping looks really good.... I wish I had time to work on my car...
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
  30. #110
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    You are moving fast on this thing. Good work!
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
  31. #111
    Oct 27 2011
    TOYS
    Philly Suburbs
    Did you see the picture the shows the uppipe flange at about 7mm away from the secondary firewall. The spacing is as good as it going to get. Everything seems to fit fine though.
    I do need a 3" - 2.5" 90degree reducer coupler to go from my TB my 2.5" ic piping. Hopefully I pick that up locally.
  32. #112
    Sep 18 2012
    State College PA
    You'll probably end up with a 3" 90 and then a 3 to 2.5...
    Just make sure you only get 4 ply silicone... the parts stores don't tend to carry multi ply couplers... and they just blow apart.
  33. #113
    Oct 27 2011
    TOYS
    Philly Suburbs
    Yea a local speed shop has the 4ply couplers I need.
  34. #114
    Sep 18 2012
    State College PA
    Good good.
    I've used the cheap ones while waiting for parts to be delivered before... never works out well lol.
    Now I have a bog of 3" piping, couplers and clamps ;-)
  35. #115
    Established Member Two Rings Brodyaga's Avatar
    Nov 21 2010
    01.5 S4 STK, 01.5 S4 Avant SRM K24, 87 E30 Mtech1, '77 Porsche 911, B8 A4
    Fair Oaks, CA
    why did you have to shorten the power steering hose?
  36. #116
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by Brodyaga View Post
    Because I wanted to keep it far away from the up pipe. But apparently I could have just left it in its stock location and just bent it slightly....
  37. #117
    Nov 21 2010
    Fair Oaks, CA
    gotcha. yea I'm gonna need to do the same cause mine is sitting too close to the up pipe for my liking. I'll try to just heat it and bend it.
    Build is moving along quickly tho. :)
  38. #118
    Oct 27 2011
    TOYS
    Philly Suburbs
    I wouldn't heat it unless you have cleaned all the oil out from the inside. You don't want to cook that oil and have it sludge and ruin your PS pump. I'm sure you can gently bend it without heating it.
  39. #119
    Oct 27 2011
    TOYS
    Philly Suburbs
    WOW.... look at all that room!!! Must be nice not having a secondary firewall in your way....
  40. #120
    Oct 27 2011
    TOYS
    Philly Suburbs
    I have finished the wiring harness. I have also verified oil at the turbo feed line (no turbo hooked up yet).
    Also got this yesterday:
    Today I will install turbo, downpipes, intake, front bumper support..... and fire her up. Check back this afternoon for a video......
