Originally Posted by
mrrun2fast
Looks like this is happening across model lines.
Add mine to the list. I have a 2013 Q5 2.0T. Build date is July 2012. I currently have 6K miles and the issue started at 5K miles. I bought the car in October.
The steering is unbelievable. Going straight on a highway, I can feel it shifting and floating. I constantly have to correct it. Going around a curve is even scarier at speeds of +60mph due the shifting. The steering is very imprecise and unpredictable. I really hope there is a permanent fix to this.
I haven't been to the the dealership yet due to work, but I look forward to hearing more updates from you guys. Thanks!
Bummer man, sorry you're having this issue with your Q5 as well! I got a 2013 A4 loaner last time my car went in for this issue and it had the SAME issue even worse than my S4! Then I traded that for a 2013 Q5 and it was PERFECT! So at least I can confirm that if the electric steering is operating correctly, it's actually really solid and confidence inspiring.
The more I think about this, the more I believe there are multiple issues here, two for sure (I've personally experienced two different issues), possibly three.
The notchy steering issue I've had has been at every speed, in every mode, and happens at any steering position and angle. The "slipping" sensation where the steering seems to "over power boost" and the wheel just slips and then grabs again, only seems to happen at higher speeds, and only across 12 o'clock in the steering. These are two DISTINCTLY different feelings and issues in my opinion. I could see and rack fixing the notchy issue, but I think the "slip" is a faulty sensor.
Ugh, this is all very frustrating. I for one can promise all of you that if my new rack this Friday, doesn't fix my issues, I'll happily take the lead on filing the appropriate papers with the safety groups needed to push this issue further with Audi
