Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 191
Thread: My S5™
  1. #41
    Oct 30 2012
    Florida
    ***Getting some 90mm tips made for the stock exhaust at a local shop this weekend :
    Quote Originally Posted by tozer View Post
    Can always go to your local tint shop - they've likely done them before or know what is required to do it. Get them to show it to your before they do both sides, as you will want to see that it is right for you. Looking at it from the front is one thing, but from an angle you will have some questions on whether they need more material or not. My local tint shop was great. Goldwing Autocare in Ottawa.
    You're right; though I actually might do it myself since I like DIYs. I got some headlight film on the way. I'll post some pictures later.
    I did it to my RSX's reverse lights so it shouldn't be too bad.
    Rear by Sebastian Marin, on Flickr
    My DC5 by Sebastian Marin, on Flickr
  2. #42
    Established Member Two Rings tozer's Avatar
    Jul 23 2012
    Ottawa, Ontario, Canada
    Nice, looks much better. Amazing what a little film can do.
    Once you see the deletes covering the amber you're next wish will be for e-codes
    2012 Audi S5 4.2 V8 FSI Quattro "Metall" Edition | Monsoon | 6 MT | MMI | Alcantara | ClearShield (Full hood, leading edge of fenders, bumper, roof, trunk lid) | Black Vinyl Amber Deletes |
    SOLD - 2004 Volvo S60 R | Titanium Grey | 6 MT | EST Cat-back Exhaust |
  3. #43
    Oct 30 2012
    Florida
    I'm thinking on taking the headlight apart with a heat gun and applying the film on the side markers instead. Anyone know if the S5 headlights can be opened with a heat gun? Or are they glued with epoxy?
    ***I keep reading the A5/S5 headlights are held with epoxy Oh well... I'll just put the vinyl on top.
  4. #44
    Oct 23 2006
    2022 Chevy Tahoe, 2012 Acura MDX
    Houston
    Quote Originally Posted by marinse View Post
    And of coarse please add pics when done
    -Beck-
    2013 S5 Estoril Blue Crystal
    2003 A6 2.7T Silver
  5. #45
    Oct 30 2012
    Florida
    WOW... Order some stuff from DDM Tuning, was "Shipped" 12/2 and I am still waiting for the package... -____-
  6. #46
    Active Member One Ring Yuba's Avatar
    Jan 06 2013
    Lexus GX470 for the Wife.
    SF Bay Area
    Marinse-
    Nice work!
    Scott
  7. #47
    Oct 30 2012
    Florida
    ^^Thanks Scott!
    Took a picture of the 3.5" tips I got made. I'm waiting on a replacement bulb from DDM. Never dealt with such bad products, if you're contemplating buying stuff from them I would think twice.
  8. #48
    Established Member Two Rings O2ShootTheJ's Avatar
    Dec 15 2012
    VA
    Hey what's up! I'm in the Leesburg area every now and again. Where do you go to shoot around the area? I have a 60D and wanna get some nice shots of my car
  9. #49
    Oct 30 2012
    Florida
    My S5™
    Quote Originally Posted by O2ShootTheJ View Post
    What kind of location are you looking for? City/back roads/tunnel though I'm lore familiar with MD/DC than VA
  10. #50
    Sep 16 2012
    MD
    Sebastian, Text me about the VAG COM mod...I got my laptop back and we can meet this weekend.
    S5 4.2 | Flat Bottom Steering Wheel | Tubi Exhaust | Vagged | H&R Coilovers
  11. #51
    Oct 30 2012
    Florida
    Is there a way to turn off TPMS while running aftermarket wheels then turn it back on when putting the stocks back on?
  12. #52
    Senior Member Three Rings ChipB's Avatar
    Nov 04 2009
    '21 BMW X5, '16 BMW M4
    Morristown, NJ
    Not sure why you posted this question here, but... no, the TPMS warning cannot be turned off - at least it can't be turned off through the MMI or using VCDS. For clarity - I assume you're talking about the direct measurement TPMS that uses sensors in the valve stems, and you are not planning to install the special stems in your after-market wheels, correct?
    '24 RS5
  13. #53
    Oct 30 2012
    Florida
    Quote Originally Posted by ChipB View Post
    I just didn't want to create a whole new thread.
    Yea you're right the valve stem sensors. I'm not planning on getting sensors for my after market wheels. So I'm assuming there will be a message being displayed on the dash when I mount them.
    Would there be a problem once I put my stock wheels back on? Or the TPMS would automatically recognize the sensors once they're back on?
  14. #54
    Registered User Four Rings ModBargains.com's Avatar
    Mar 09 2010
    La Habra/CA/USA
    Car looks amazing with all the mods you've done so far! Which wheels are you planning to get? Coming from the makers of KW suspension systems the only main difference between the ST Variant 1 and KW Variant 1 is the steel they use. While KW uses Stainless Steel for their shock housing, ST uses Galvanized Steel. However, this does not mean a drop in quality, durability, or appearance. Although coilovers that use galvanized steel are more prone to corrosion due to environmental influences (i.e. mixture of salt water); those in the lower states: California, Texas, Florida, Nevada, etc. don't have to worry about corrosion. Those in the mid to upper States that snow still don't have much to worry about as long as they do not drive in heavy snow conditions upon where salt is used on roads. to further ensure those with doubt about Galvanized Steel, ST has corrosion resistant zinc plating on all of their threaded strut housings for further protection.
  15. #55
    Nov 04 2009
    Morristown, NJ
    No problem at all. The system may take a few minutes of driving before it recognizes the sensors are back, and you may have to recalibrate the TPMS in the MMI.
    '24 RS5
  16. #56
    Oct 30 2012
    Florida
    Quote Originally Posted by ModBargains.com View Post
    I'm waiting for incurve's S10, will get 20x10.5 all around most likely. In regards to ST, if I was to get them I could rust protect them with a coat of a product (I forgot the name of it). Maybe I'll go this route.
    Sep 16 2012
    MD
    I hated having to stare at the TPMS light on my old car since I had my after marker 80% of the year. I wouldn't mind picking up a used set of TPMS to avoid it this time around.
  18. #58
    Oct 30 2012
    Florida
    Quote Originally Posted by beta View Post
    Do they have to be S5 specific?
  19. #59
    Sep 16 2012
    MD
    Knowing Audi, they probably cross share those TPMS sensors between all B8 if not even with other Audi/VWs.
  20. #60
    Oct 30 2012
    Florida
    My S5™
    True, just did a quick search on eBay. Found a set of used ones for $60. But gonna wait till I get the wheels.
    Btw, text me when you're free to try to get rid of the service message please.
  21. #61
    Oct 30 2012
    Florida
    H&R coils and spacers on the way! RS5 grill in the works as well.
  22. #62
    Sep 28 2010
    NW NC / DE
  23. #63
    Oct 30 2012
    Florida
  24. #64
    Sep 14 2012
    1993 Nissan 300 ZX TT 5speed 53k miles
    Upstate NY
    what year is it? 2012?
  25. #65
    Oct 30 2012
    Florida
    I wish... its a 2008
  26. #66
    Oct 30 2012
    Florida
    Getting ready for the H&R coilovers install this weekend!
    Snowmaggedon? by Sebastian Marin, on Flickr
  27. #67
    Oct 30 2012
    Florida
    Waiting for wheels to come in soon.
    My S5 by Sebastian Marin, on Flickr
  28. #68
    Established Member Two Rings jynx's Avatar
    Sep 16 2012
    Calgary, Alberta, Canada
    what did you order?
    2008 S5 Phantom Black Prestige | V8 | 2G MMI | B&O | VAG'd | HID | Honeycomb | 19" Avant Garde M510s |
  29. #69
    Oct 30 2012
    Florida
    Quote Originally Posted by paulgifford View Post
    what did you order?
    Got a set of BR10s from a new company called Brada Wheels.
  30. #70
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    I've bought the Show-and-Go license plate bracket, but there's not enough space between the edge of the front bumper and the intercooler.
    I'm just wondering how did you get yours installed?
    Thanks in advance !
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
  31. #71
    Oct 30 2012
    Florida
    Quote Originally Posted by xuandatou View Post
    Thanks in advance !
    I have mine on an angle down so that it slides under, then used a bent piece of metal to screw it on the car.
  32. #72
    Oct 17 2012
    NoCal
    Thank you sooo much !
    I will try that way !
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
  33. #73
    Oct 30 2012
    Florida
  34. #74
    Sep 28 2010
    NW NC / DE
    Damn, looks good! Not sure I have seen the S5 that low on oem's. I would raise the rear or lower the front a bit if it were mine. @bknewtype
  35. #75
    Oct 30 2012
    Florida
    I could go lower up front, but would have to remove one of the rings haha
    We'll see what it looks like when the wheels get here, I'm hoping to be tucking some tire.
    I do have to say, the ride is awesome compared to my RSX on coilovers rolled all the ay down. It feels a little bumpier than stock but other than that, I'm really happy.
  36. #76
    Sep 28 2010
    NW NC / DE
    Glad to hear
  37. #77
    Senior Member Two Rings Marce318's Avatar
    Feb 28 2013
    Austin TX
    nice congrats!
  38. #78
    Oct 30 2012
    Florida
    Photoshoped e-codes in for fun
  39. #79
    Veteran Member Three Rings H20pologoalie's Avatar
    Sep 26 2011
    01 Honda Accord.... still going
    Kalbi Province, TX
    Man I bet you can't wait to get those new wheels in. I've only ever seen guys post pics of spacer/offset wheels with the drop, not unspaced with the drop. Being from a slightly more rural area of MD, it reminds me a bit of the "muffin top" residents. haha. But I may go against the grain here. Alot of guys really like the raked look, and it's not that I don't, but I also like the even look dropped look as well.
    Where are you at in MD?
    S5 4.2L V8 6MT, Ti Pkg,, CF, Sport Diff., Michelin PSS, Tunerdomes, Full Dip, Lamin-X, 35% tint, H&R 20/25, K&W v1, SPC CA, VAG-Com, AWE S-flo, AWE DB Touring, AWE Non-Res, Eurocode Sways & Alu Kreuz
    Build Thread FTW!
  40. #80
    Oct 30 2012
    Florida
    Quote Originally Posted by H20pologoalie View Post
    I don't mind the no flush look for now, and I actually have a set of 25mm and 15mm spacers at home... just too lazy to put them on. Will be up for sale once I get the wheels.
    I'm located near Rockville, MD.
