Page 1 of 11 123 ... LastLast
Results 1 to 40 of 426
    Senior Member Three Rings jovak0423's Avatar
    Dec 16 2011
    lebanon, pennsylvania
    Doing alot of everything on my a4 *pictures*
    I own a 98.5 Audi a4 1.8tqa. I bought the car for a steal and found out that the turbo was bad. So I did a full k04 setup. FMIC,giac the works. I didn't want to go crazy power because of it being tiptronic. No CEL. So I ended up doing some other mods instead.... Here's comes the real stuff... I've been instreaded in the widebody a4... So I found a cheap set of universal fender flares. So I mocked them up and went with it. Why didn't I go with the rs4 widebody kit? I don't wanna spend 9k$ on a widebody wen I can do the same thing with a different aprouch. This costs me about 700$ and month to complete.
    Before
    After
    Then I found a couple great DIY's on auto to manual swaps thanks to biketsai,walk-talky,papa_dios, so I'm in the process of the swap right now. Also I found out that I needed a new downpipe and while I was pulling the trans out I mind as well put top of the line stuff in. So I'm putting an fx400 clutch,awe LWFW,t3t4 full setup with um software and 3" turbo back exhaust with vband clamps the hole way thru. Here's some pictures o and every single thing I have done was by me myself and I, with the info from you guys...
    First batch of goodies..
    I should be completed at the end of this month, I'm just waiting on parts to come in and time to take off to complete this.
    98 audi a4 1.8tqa k04/FMIC/race n75/CCAI
    96 audi a4 2.8 CAI/racing springs/18" rs4 reps
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    When i read "universal wide body kit" i was expecting to scroll down to some huge ricer fail pics.
    but really, it looks awesome. Well done!
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Dec 16 2011
    Thanks man
    Senior Member Three Rings shinamura's Avatar
    May 22 2011
    Detroit, Michigan
    i love the hood! definitely had reservations when i read universal flares, but you definitely pulled it off! congrats bro, definitely doing some good work there!
    Dec 16 2011
    I forgot to mention my newest upgrade... I'm doing an s4 front brake setup. S4 upright,calipers,carriers,rotors and an s4 3 spoke steering wheel all for ...300$ yea everything I just mentioned for 300$ and he's local... Now that is a deal. I'm looking for used s4 front axels they also bolt right up to the 5spd trans so it's great
    Dec 05 2007
    You can find used OEM axles on part out threads on fourtitude, for starters. Then try ebay, car-part.com, and so forth.
    http://forums.fourtitude.com/forumdi...RS4-(B5)-Parts
    But looks like you know what you want out of your car. Be sure to place forged rods somewhere on your "to do" list if you plan on chasing some power.
    Dec 16 2011
    Yea keeping the boost waaay down thru winter so I don't blow the motor. I wanna buy a used motor and build it thru with winter for a side project. I get bored real fast that's how the widebody came thru my mind lol
    Veteran Member Three Rings ElliottG's Avatar
    Apr 30 2009
    '12 Q5 2.0T
    What do the universal fender flares look like? And how did you mold them into the body?
    Dec 16 2011
    2 part process, 1st- To mold it onto the car I cut the actual fenders so I could put spacers on to make the tires come to the wider fenders... 2nd- then grinded factory fenders down to bare metal so the fenders stick to the flare. The actual process to mold them I took durglass and put that in between the fender and the flare and used 1/8 rivits to keep them in place. After they are one with the car I used bondo glass(hardens like metal) then used a couple lot coats of bondo. He's some pictures
    Mockup
    I have s4 side skirts, I had to make a side skirt extention... My own creation, and it's out of cardboard.
    Also did the inside of the doors
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    same here. i got scared
    Quote Originally Posted by Euromike View Post
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    May 22 2011
    Detroit, Michigan
    this is really good work! the installation pictures are awesome!
    Veteran Member Four Rings A6Avant's Avatar
    Mar 09 2010
    T4 Eurovan 2.5L 5spd (Currently under construction). MKII Jetta (GLI in the making :)
    Salmon Arm , B.C. CANADA
    I have to say I am surprisingly excited to see this... The universal concept scared the hell out of me but you sir look to be on a correct path!
    Subscribed!
    Jeremy-
    1999 C5 Avant 2.8, 1992 T4 Eurovan 5 spd, Slammed and gift wrapped!
    Dec 16 2011
    Here are some more pictures of the little things that made it alittle longer to complete but I fixed it
    This is an after picture but before this the flare didn't match up at all
    Shaved the rear bumper
    Before
    After
    I shaved the upper/lower door moldings
    In the summer the car is gonna be nogaro blue or a pearl white
    Mar 09 2010
    Looking good...
    The blue is awesome. As us the white...
    Jeremy-
    Apr 30 2009
    '12 Q5 2.0T
    Ohhh I saw your other thread where you posted this. I forget where, though.
    Dec 16 2011
    Vwvortex-username k04pwrd...
    Jun 30 2008
    Erie, Pennsylvania
    Wow, lots of great DIY action going on here. Excellent work.
    Make sure you do some more research on your axles. 6MT axles won't bolt to a 5MT (inner flanges on a 6MT are 108mm vs 100mm on your 5MT quattro box), and the lengths will be wrong as well. What you want are B5 V6 5MT quattro axles, which are the same as 2001 B5 1.8T 5MT quattro axles. Those have the larger V6/S4/AWM outer CV's (for 82mm wheel bearing), with the smaller inner joints (100mm) for fitment to a quattro 5MT box. Axles that don't bolt up will wreck your day.
    Dec 16 2011
    There's not alot of diys but I'm going by this one http://forums.subdriven.com/showthre...amp;p=78921487
    It just says s4 front axels... Ill do some more research thanks for the info
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    So you never cut the actual fenders or quarter panels?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 16 2011
    Yea so I didn't rub when I put the 20mm spacers on.
    I don't have any pictures of the rear cut because at the time I was focused on measurements and cutting straight lines than pictures but I followed those lines
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by jovak0423 View Post
    There's not alot of diys but I'm going by this one http://forums.subdriven.com/showthre...ade&p=78921487
    Well, I was wrong about the length issue perhaps, but the DIY you linked is for a 1.8T FWD car. The 1.8T FWD inner axle joints are 108mm (same as the S4 6MT). Your quattro inner joints are only 100mm. So unless you obtain the 108mm inner flanges (generally sold with the transmission), S4 axles are not going to work for you. You need B5 A4 V6 quattro front axles to make it happen.
    Dec 16 2011
    Thanks man I'm looking for those ones now I'm really glad you told me because like you said bad axels would have ruined my day
    Dec 16 2011
    UPDATE:found everything I need to do a double din conversion, I already bought an s4 steering wheel. The guy selling the double din setup also has a mint s4 carpet. So next week I'm getting the full s4 brake setup,double din setup,carpet hopfully my turbo and other parts come in next week also
    Active Member Three Rings
    Sep 25 2012
    Macon, GA
    Is that cup holder only applicable to the post-facelift version??
    1996 Audi A4 Quattro 2.8 12V
    Dec 16 2011
    No just for the facelift version
    Established Member Two Rings DG NEMESIS's Avatar
    Dec 23 2008
    2000 Silver A4 1.8t, Nissan Altima, MK4 Jetta VR
    Love the widebody job well done sir!!
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by skim464 View Post
    ^lol. Post-facelift = facelift.
    Dec 16 2011
    Wen it comes to facelift pre post all tht stuff I don't wat tht all means. I just winged it lol
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    Lol.. 96-99 were pre-facelift, 99.5 was semi-facelift (still single din, new foglight/cupholder bezel), 2000-2001 was full facelift (double din).
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Dec 16 2011
    Got some more goodies. I picked up a used manifold and used tial 38mm wastegate.
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    what turbo are you going to mount to that?
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Dec 16 2011
    T3t4 50 trim 48 exhaust
    Senior Member Three Rings s3apra4's Avatar
    May 07 2011
    Sprint Blue B7 DTM that makes 1k whp.
    Houston,TX
    I was too quite surprised to see what the outcome is after reading universal fender flares. Great work!
    What is your suspension setup? Only reason I ask is that depending on the wheel and tire combo you might have some limitations with the rear of the vehicle going down without chewing up tires.(if you even intend to lower it) just a thought...
    ~Joshua
    JE Pistons / Pauter rods / 2.0l / GT3582R / 034 tubular manifold / 034 EFI IIc / Apikol IM / Ev14 1000cc / Cat 3658's / supertech valve's 1mm oversized exhaust / street density motor mounts / track density tranny mounts / H&R Coilovers / 034 Exhaust /Stop Tech 332 BBK / RS4 Pump in tank to 044 in 034 surge tank /034 300mm Rear Brake Kit
    Established Member Two Rings TheKid84's Avatar
    Jul 01 2012
    audi a4 b5 1.8T
    cape town
    Quote Originally Posted by nrowensby View Post
    a big ass mofo!
    I love my so much but I just wish I didn't have to on it so much, but I enjoy it non the less
    My 1999.5 A4 B5 1.8T FWD thread/build
    Dec 16 2011
    Quote Originally Posted by s3apra4 View Post
    I have h&r racing springs on stock struts for awhile now with no issues at all. I'm gonna stay like that for alittle while longer. I don't scrap or have any rubbing at all. Wheels/tires... 18x9.5 rs4s, khumo 225/35/18
    Dec 16 2011
    Quote Originally Posted by TheKid84 View Post
    a big ass mofo!
    I wanna go big but I'm not looking to drag or anything like that. I just want a nice dd and if someone wants to do alittle sprint I could dump the clutch once in awhile lol
    Dec 16 2011
    I shaved down the crank today,It wasn't too bad at all.
    Before no spacers
    Before with spacers
    After with spacers
    After without spacers
    Done with awe LWFW YAY!!
    Jun 04 2007
    Austin/DFW, TX
    Nice!! I might have to steal those last few photos to put into my 5spd swap thread. I have a lot of people ask me what I mean when I say to grind it down flush using spacers.
    My 5-Speed Swap DIY
    - B6 USP
    Dec 16 2011
    Yea no problem
    Senior Member Three Rings silverman's Avatar
    Sep 27 2008
    '98 A4 1.8tqm. Bilstein pss9.
    Hartford, CT.
    Very impressive so far.
    Cactus green B5 A4!
