Originally Posted by
lencho1500
My question is to anyone running this kit, how has your experience been? I searched and didn't find many people "reviewing" or stating what their overall experience was with this kit.
I read at some point that IE was going to do a write up on the install did it ever happen?
Thanks
Hello,
The actual install is the same as any timing belt kit, the way to apply tension is what differs. We did put together this quick DIY video on the proper tension technique:
Scotty@Advanced
I've never heard of an actual tensioner failure, most timing belt failures are the belt itself or the rollers, but MMM is right, the factory tensioner is hard to beat.
The actual tensioner itself is an ok design and would be hard to cause a failure. However the oil seal o ring on the tensioner is the common fail point, they grow brittle and fail allowing the fluid to leak or loose pressure and then the tensioner fails. We have seen many of these fail in our test cell and many engines have had problems before timing belt replacement was needed. This problem is more common on engines that run higher RPM's and higher horsepower over stock.
Another advantage is not having to buy any other timing belt components other than a belt/waterpump in the future.
