Results 1 to 8 of 8
Thread: P2404 question
    Jan 30 2009
    A4 B7, Ford Expedition
    Orlando
    P2404 question
    My Audi intermittently is throwing a p2404 code. I have replaced the n80 valve and gas cap but I keep getting the code. I am kind of stumped at this point without taking it to the dealer and see what is going on. I have the 2.0t and the cvt transmission.
    Thanks for any help.
    Jan 21 2013
    Santa C
    Did you ever get this fixed? I have the P2404 Issue right now and trying to figure out how to fix it.
    Thanks,
    Ron
    Established Member Two Rings frankh's Avatar
    Dec 14 2006
    2005.5 A4 3.2 Quartz Grey on Black
    Millbrae/CA
    Ron, not sure if you have resolved your issue. I may have just resolved mine, so wanted to share my experience with you. I was also getting the same fault code and I had the LDP pump replaced, N80 valve, smoke test was done, no leak... It came down to a faulty ECM. Bought an used one on eBay for $40 then spent $350 at the "stealership" to have it sync'd and installed. It's been 3 days now, and the fault code hasn't came back. I was actually getting a different fault code when I got the car back, but it was because the throttle body needs to be realigned whenever the ECM is replaced. The stealership wanted to charge me for looking into the issue when should have done it as part of the ECM replacement service.
    Quote Originally Posted by neovalentine View Post
    Thanks,
    Ron
    Jan 21 2013
    Santa C
    Thanks! I just swapped out the N80 valve and no luck. Really not looking forward to trying the ECM next but might be my next option.
    Ron
    Dec 14 2006
    Millbrae/CA
    Yeah. It was my last option too. Luckily I got a good deal on the used ECM. It's been a month and so far so good.
    Good luck!
    Ron
    Jan 21 2013
    Santa C
    is the issue still gone? Was the ECM really the fix? Mine keeps coming back and I'm looking at the ECM as the next step.
    Dec 14 2006
    Millbrae/CA
    Seems to be the case for me. Haven't seem the error code since the ECU was replaced.
    Veteran Member Three Rings vacsimile's Avatar
    Nov 15 2008
    2004 Audi S4, 1991 Nissan D21, 2001 GTi VR6
    Outer Space
    You two have different ECM's (3.2 vs. 2.0) and because it fixed his car doesn't mean it will fix yours, too. I say get it checked out by someone who specializes in Audi's instead of just throwing parts at it. Especially expensive parts.
