Quote Originally Posted by Dan_Q View Post
See the little boxes on top of each connector? You need to pull slightly on the little protrusion to disengage a clip that holds the two connector ends together. You will hear a little click when you do it and they will just slide apart. Because of the angle your best bet is to use a pick that is curved at the end. Good luck.
I used a long screw driver
Sent from my SM-N900V using Tapatalk
