Page 3 of 9 FirstFirst 12345 ... LastLast
Results 81 to 120 of 323
  1. #81
    Established Member Two Rings holyShred24's Avatar
    Oct 28 2013
    Norfolk, VA
    B8 A4 2.0 TFSI DIY: Carbon Intake Valve Cleaning
    Quote Originally Posted by wabbit23 View Post
    I found carb cleaner to work just as well. The BG cleaner was great and all but in the end I still had to use a pick to break off all the chunks.
    I was thinking of using carb cleaner when i do mine. Should work just as good with soft wire brushes and rags.
  2. #82
    Veteran Member Four Rings slvrb7's Avatar
    Dec 28 2011
    2016 Polaris RZR 1000, 2016 Jeep Wrangler JKU, 2017 Range Rover, 2018 Land Rover Discovery
    North Texas
    Brake cleaner works fine for this or just some good ol gasoline let sit over night then scrub also you should change the oil, you will get some left over in there especially when you start the car again.
    Kris
  3. #83
    Veteran Member Three Rings Eddie-B8's Avatar
    Jan 18 2012
    Brooklyn,NY
    Quote Originally Posted by k9lovr View Post
    No I bought two cans from a place in Georgia a seller named impart1731...looks like a parts selling company...they have individual cans for sale now
    That seller only had one left in stop but I did place an order for a three pack
    2017 Audi Q5 3.0T P+ with Tech and Sport Interior
    I have Ross-Tech VCDS, PM me if you need coding
  4. #84
    Veteran Member Three Rings Fburg A4's Avatar
    Oct 06 2012
    Fredericksburg, VA
    You can try bgfindashop.com to find local places in your area who sell BG products. It searches by zip code. This can be an alternative if shipping is too high when buying online or the shipping time is too long and you need the product right away.
  5. #85
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    Excellent DIY!
    Have a quick question for Dan_Q.
    I'm working on a mod and since you have already dissected these parts. I could really use your help. What is this hose fitting is used for? When I first noticed this fitting, I was scratching my head wondering if someone forgot to hook up a hose.
  6. #86
    Senior Member Two Rings Dan_Q's Avatar
    May 18 2011
    2011 BMW 335i, 392 whp
    Colorado Front Range
    Quote Originally Posted by DoItAllGarage View Post
    I think if you look into it you'll see that doesn't have a hole into the interior of the manifold. Not sure why the hell it is there but nothing needs to be connected to it. Perhaps Audi was planning to add a feature they could connect which would fail shortly after the warranty ended, then later reconsidered since the car already had plenty of features meeting that criteria???
  7. #87
    Oct 29 2013
    WA to ID
    You rock! I'm about to saw that fitting off!! It's in my way of some hoses I'm trying route. Thanks again!!
  8. #88
    Oct 28 2013
    Norfolk, VA
    Quote Originally Posted by Dan_Q View Post
    I have been getting an intermittent CEL (P0088 Fuel Rail Pressure Too High) for the last 6 months. Started out once every 6 weeks but has been increasing in frequency until it is now 1-2 times/week. I will put up a new post in about 2 weeks if it doesn't come back so I can confirm the sensor was indeed the problem.
    Quick question. Did this problem start after you did the intake valves cleaning or have you had this issue before? Just wondering. Ive read thru your write up again. I just got my car back from stealership and they told me that this is the reason my car threw the code P0420.
  9. #89
    Jan 18 2012
    Brooklyn,NY
    Did this cleaning last weekend took me a few hours longer but that's because I was in a rush putting back together, first I forgot the flaps after I connected everything back, so had to take it all apart again, then the second time I forgot to put one of the injector spacers that fell of when took the manifold of the first time, but all in all it went great car definitely feels smoother now. Here are some pics, of before was to pissed to take the after...
  10. #90
    Oct 28 2013
    Norfolk, VA
    ^ did you have to change your gasket? FI o rings?
  11. #91
    Jan 18 2012
    Brooklyn,NY
    Quote Originally Posted by holyShred24 View Post
    No, everything looked good, just take your time and examine everything, another thing to mention is be VERY careful with the little nipples for the vacuum hoses because if the plastic is cold they brake like chips... I learned the hard way...
  12. #92
    Oct 28 2013
    Norfolk, VA
    Quote Originally Posted by Eddie-B8 View Post
    Thanks for the tip. Last stupid question. Did yours have a 10mm triple square bolt or 9mm? Im doing mine tomorrow and i could only find 8, 10, 12mm sizes. Hopefully mine got a 10mm.
  13. #93
    Jan 18 2012
    Brooklyn,NY
    I didn't have a triple square but I managed to use a regular Allen key, I don't remember the size but that bolt isn't torqued down that much so it was easy to get it off
  14. #94
    Oct 28 2013
    Norfolk, VA
    I thought bout that too. They look pretty similar to star allen key. Thanks a lot for all the tips!
  15. #95
    Jun 26 2009
    Bremerton WA
    My car had a 10 triple square securing the support bracket.
  16. #96
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Quote Originally Posted by van462 View Post
    +1
    [B]Current: Shopping now....
  17. #97
    Oct 28 2013
    Norfolk, VA
    Just got done doing it today. This DIY helped a lot. Took me less than 20 mins to get the manifold off then about 4 hrs for cleaning. My car has 61k+ miles and i highly doubt the 1st owner did anything to it.
    You cant even see the inside since its so caked up with junk!
    I only got to take a pic pf the progress. It was already too dark for me to take pics of the final result.
    Really glad i did this and thanks for all the help from everybody here.
  18. #98
    Senior Member Two Rings Steelman's Avatar
    Feb 26 2013
    Charlotte, NC
    I'm about to tackle this project along with a new manifold on my '09 A4 with 64K on it. What chemical solvent did you use to clean the valves?
    RS4 Cab - Avus Silver on Black
  19. #99
    Oct 28 2013
    Norfolk, VA
    ^I just used some CRC carb cleaner and lots and lots of scraping and wiping. I used about 3 cans. Do yourself a huge favor and use a flexible wire brush thats small enough to get around the valves and make sure you do a really good blow out with an air compressor before you start putting everything together. Goodluck!
  20. #100
    Junior Member Two Rings
    Jun 15 2008
    2015 S3, 2015 A3, 2009 TTS
    Paradise Valley AZ
    Need help.
    My goal is replace water pump and per Dan’s recommended procedure the intake manifold has to be removed to gain access. I followed all the steps in the manifold DIY but the manifold will not come off. It is loose and wiggles a lot. It can lift up of the about a 1/16 off the head. I even removed the Throttle Valve Control Module to get a better view. Something on the bottom side in the middle is holding it. Not firm like a bolted joint but loose like a sheet metal tab or hose. I am pulling hard but have not yet resorted to a crowbar to gain leverage. I read that several of you did the manifold cleaning DIY. Did you to use huge force or I am missing something?
    Thanks
    Note an 8mm hex will work as a substitute for a M9 triple square for low torque situations
  21. #101
    Jan 18 2012
    Brooklyn,NY
    Yank it, it's the injectors holding it
  22. #102
    Veteran Member Three Rings wabbit23's Avatar
    Mar 20 2011
    2011 Avant Quattro & 2010 Jetta TDI
    San Diego, Ca
    There's only a few bolts and nuts holding it on. Theres also the bracket that attaches to the bottom of the throttle body that would definitely keep you from pulling it out. It needs to be removed completely.
    The last thing I remember was pulling up/out with a bit of force due to two of the injectors deciding they'd rather stay in the block.
    Mine- 2011 Avant Quattro- Premium Plus w/ Sport Package- APR Stage 2/ SPM Downpipe/ AFE Prodry S/ R8 Coilpacks/ ECode HFIP/ ECode Intercooler Piping kit/ 20% F & 15% R tint/ Dipped Parts & Vagcom stuff
    Hers- MKV Jetta TDI- Matte Black VMR V710's / H&R OE Sports/ Koni FSD's/ Dipped parts everywhere
  23. #103
    Jun 15 2008
    Paradise Valley AZ
    Update - It was the fuel injectors. All 4 stayed in the cylinder head.
  24. #104
    Jan 16 2014
    United States
    Will try this in a couple days
    Sent from my SM-N900V using Tapatalk
  25. #105
    Jan 16 2014
    United States
    One question will leaving some isc in to the valves and let it sit over night in the closed ones would that be bad or cause problems??and will leaving the flaps in some isc over night does that harm them or just leave max 3.5 hrs
  26. #106
    Jul 30 2013
    West Bloomfield, MI, USA
    Great DIY, dan. thank you for sharing!
    I have a cel that vcds has indicated as an intake manifold problem, so I am using this guide as instruction on getting the faulty IM removed. I have had no trouble up until this point, but I *cannot* get the lower two connectors removed. Is there some kind of trick to remove them, or could they be fused?
  27. #107
    May 18 2011
    Quote Originally Posted by mikewb View Post
    See the little boxes on top of each connector? You need to pull slightly on the little protrusion to disengage a clip that holds the two connector ends together. You will hear a little click when you do it and they will just slide apart. Because of the angle your best bet is to use a pick that is curved at the end. Good luck.
  28. #108
    Jan 16 2014
    United States
    I just used a flat head screwdriver, put it right there in between and twisted a bit to release. .idk if that is right or you shouldn't do that but I have not broken a tab doing like so...give it a try maybe it will come off for you
  29. #109
    Jan 16 2014
    United States
    I used a long screw driver
  30. #110
    Jul 30 2013
    Thank you for the suggestions! It kind of helped me to understand the mechanics of the connectors. Although I broke one of them slightly, I did manage to get them both off with this new information. Such a relief!
    If I manage to get this all pulled apart, I'll post pics of an uncleaned IM @ ~77k :P
  31. #111
    Jan 16 2014
    United States
    grad it helpef
  32. #112
    Senior Member Three Rings DJ_AudiA4's Avatar
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    i lost one of the plastic spacer between the injector and the manifold. any idea where i can get another? or a set of them?
    09 A4 6MT Quattro Frankenturbo, Eurodyne Tune,K&N intake , SPM TP, AWE catback, CTS FMIC, ST Coilovers, Roc-Euro STS, 034 Transmount, Apikol bushing, GFB DV+, H&R sway bars, AWE boost gauge, VMR 701's 19x9.5, RS4 grille and fog light housings.
    289HP @ 6100| | 297ft lb @3900
  33. #113
    Jan 16 2014
    United States
    Quote Originally Posted by DJ_AudiA4 View Post
    The Teflon? Or the rube seal?
  34. #114
    Senior Member Two Rings A4BGP's Avatar
    Oct 18 2005
    Dirt and Street bikes, '09 A4Q
    Moncton, NB
    http://www.rockauto.com/catalog/x,ca...parttype,13679
    Btw, dealer usually has these kits in stock for fairly cheap under 06j998907b.
  35. #115
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    Rockauto.com
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
  36. #116
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    No it's not in that kit, it sits in the hole under the intake valve, I have one is those kits and don't see it in there
  37. #117
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    Sorry it's between the engine and the injector.
  38. #118
    Oct 18 2005
    Moncton, NB
    DJ, that kit is the updated version. The earlier style had a white "plastic washer" with barbs on it (at least mine did). It sat in the pocket machined in the head. Is that what you're referring to?
    Btw, this is all that's avilable between the rail and the head besides the injector itself:
  39. #119
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    Yes that's exactly what I am referring to, do I still need it? Or can I take them all out
  40. #120
    Oct 18 2005
    Moncton, NB
    Best to replace the components with that new kit if you already have it. Brittle little shits huh? I honestly don't see how not running those white ones would hurt anything short accelerating possible corrosion issues...
