Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 192
Thread: My Go Fast Bits
Hybrid View
    Veteran Member Four Rings well_armed's Avatar
    Sep 19 2012
    Sep 19 2012
    Come to find out, the ADS cars come with a 0.5" plastic spacer (REAR ONLY), as the ADS springs are shorter than the non-ads equipped springs.
    Greg @Eurocode informed me of this head scratcher after I couldn't figure out why my H&R OE springs were sitting higher than comparable cars.
    I had to actually put the car back on the lift and take the spacer out, and now all is well.
    FYI for you ADS equipped cars.
    #11 is actually comprised of two different pieces on the ADS cars.
    Sep 19 2012
    Fender measurements
    Before:
    Front/Left: 26.10
    Front/Right: 26.15
    Rear/Left: 27
    Rear/Right: 26.75
    After removal of plastic piece:
    Front/Left: 26.10
    Front/Right: 26.15
    Rear/Left: 26.5
    Rear/Right: 26.25
    Quote Originally Posted by Info@EuroCode View Post
    It is not that the ADS cars sit higher but the rear ADS springs are slightly shorter than non-ads equipped cars.
    When we do any spring install on a ads car, we remove the plastic spacer to ensure the car sits as the customer has expected.
    Sep 19 2012
    The way I understand it, the rear spring on ADS equipped cars is shorter. So therefore to achieve the same stock height, they use a plastic spacer.
    When you stack the H&R up next to the OE rear spring, it is not that much shorter.
    I installed the rear springs with the spacer, and the rear was actually sitting much higher (rake effect) than the front. This is what got me searching (took over a month to figure this out) and contacting various vendors (including H&R themselves). It may sound trivial for such a cheap mod, but half the reason is for the look, and I wasn't satisfied knowing it was wrong. Greg from Eurocode actually solved the mystery, after I called him and asked that maybe my height was being affected by sway bar preload (as I installed their full USS system), as the rear sway bar endlinks are not adjustable like the fronts.
    Thursday night I took the spacer out, and reinstalled the springs. The car sits how others do on the forums (comparatively), and the wheel gap is now consistent with the front.
    Non-ADS cars do not have the plastic spacer, so I am 100% positive that it will need to be removed for the H&R springs to sit the way they were intended.
    Additionally, the ride is much better now that the spring is stretched out to spec.
    This is with the spacer removed.
    Much bettar.
    Sep 19 2012
    Dyno'd my AWE Exhaust and Intake today. I am pretty sure my eurocode stuff added at least 1hp to the graph :)
    SAME DYNO, DIFFERENT DAYS
    Drive Select: Dynamic
    Gear: 3
    Traction control: off
    Octane: 92
    Car Mileage: ~1270 miles
    Tires: Blizzak LM-60's
    Dyno: Dynojet HPE 650
    Place: http://www.carbconn.com
    STOCK DYNO RUN:
    66.6F / 45% Humidity / Pressure 29.3 in-Hg
    AWE DYNO RUN:
    60.7F / 61% Humidity / Pressure 30.3 in-Hg
    Run File_3= Stock
    Run File_9= AWE Exhaust +AWE Intake
    (1) Uncorrected / No Smoothing
    Stock_HP: 300.92 / AWE_HP: 310.61 (+9.69)
    Stock_TQ: 286.53 / AWE_TQ: 291.82 (+5.29)
    (2) SAE / No Smoothing
    Stock_HP: 300.92 / AWE_HP: 310.61 (-5.10)
    Stock_TQ: 286.53 / AWE_TQ: 291.82 (-8.59)
    (3) 4th Gear Pulls
    Stock_HP: 280.05 / AWE_HP: 284.10 (+4.05)
    Stock_TQ: 284.89 / AWE_TQ: 291.03 (+6.14)
    And here is a buddy of mine's response to asking which graph to use (SAE vs. Uncorrected):
    Cliff Notes: Use uncorrected Dyno numbers (no SAE correction or smoothing) with forced induction engines.
    Quote Originally Posted by my honda engineer friend
    SAE correction factors correct for changes in Temp, atmospheric pressure
    and humidity. SAE standard conditions are: 77F, 29.23"/Hg, 0% humidity.
    The typical relationship to power is: as Temp increases Power decreases, as
    pressure increases power increases, as humidity increases power decreases.
    Looking at the conditions for run 3 the pressure was very close to
    standard. That's why run 3 didn't show much change between Uncorr and SAE.
    The temp, pressure and humidity all were different between run 3 and run 9.
    In run 9 the temp went down and the pressure went up. The actual humidity
    was probably quite close to the same, as Relative humidity % is dependant
    on the temp. So temp down and pressure up explains why the SAE correction
    would have your Run 9 power down. The problem is that the SAE correction
    factor, especially for pressure, doesn't work well for forced induction
    engines. The turbo is controlling the pressure entering the intake system,
    not the atmosphere. There was likely very little to no difference in
    cylinder pressure during your 2 runs. On top of that you have an
    intercooler influencing intake air temp, and changing the effect of air
    temp on actual power from the SAE correction.
    So I'd recommend looking at the Uncorrected numbers to judge the mods in
    this case.
    The smoothed vs un-smoothed doesn't really make much of a difference.
    Unsmoothed is just a straight line drawn between each point of data.
    Smoothed is a best fit curve between points to help eliminate noise and
    outlying points. I don't know what the sampling rate was in these runs.
    If its very high a smoothed line can be very accurate and better to use.
    If the sampling rate is low smoothing can introduce more error. Remember
    the max power and torque number really isn't very meaningful. The
    important thing is area under the curve, or the gap area between the line
    of the runs being compared. Based on the Uncorrected graph I'd say this
    intake and exhaust gave you a nice increase especially at high rpm
    Just an FYI.
    Sep 19 2012
    Ready to tackle eurocode headers
    Nah but really, I put a lift in for my Toyota FJ40 restoration project.
    Veteran Member Three Rings Gweezil's Avatar
    Apr 30 2012
    Honolulu, HI
    Quote Originally Posted by well_armed View Post
    This garage kicks ass.
    (SOLD) 2012 S4 6MT | Ice Silver | Black Nappa | Sport Dif | B&O | Nav | Adv key | StaSIS Tune | StaSIS Challenge Exhaust | Ohlins coil-overs
    Alcon BBK | Alu Kreuz | USS Sways/end links | SPC UCAs | 19X8.5 TI Reps | RS4 pedals and grille | 28% tint | VAG COM mods | Eurocode STS
    Sep 19 2012
    Thanks, switching to a side mount garage door opener to gain another couple feet (12 foot ceiling)
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    nice, i want to do a side mount one also, and also extend the track height to the ceiling.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Sep 19 2012
    Background:
    After installing the Eurocode's USS suspension kit myself (sways, links, Alu, etc.), I liked their build quality-- and most importantly -- the performance gains met my expectations.
    I purchased an AWE exhaust and intake from Alex @Tag Motorsports (and BBS wheels) -- loved the system. It gave me a dyno proven 10whp gain on pump gas. The sound was great, droned @1500-2000 RPMS with slight throttle, but I was happy with the overall sound it provided.
    Eurocode's headers were always on the radar, but I just spent $2K+ on an exhaust and didn't want to spend another $3500 (with install) on the header package. I also was on the fence of whether or not I wanted to go that far modifying the car -- afterall I was waiting for Stasis to come out with their tune.
    Well, once I convinced myself that headers were a worthwhile modification, (and a little research) I realized I had a little problem with the AWE exhaust being too loud with the catless headers. I needed a Milltek resonated system to mate with the new headers, but that would take weeks to procure from the local distributor.
    Enter Eurocode.
    I called up Greg and told him my situation, and we cooked up an awesome solution. He'd sell me Dave's milltek system (off his own car), and Dave would install my AWE on his car until the new milltek's came in from the UK. I was definitely impressed with the fact that they were willing to do that.
    After driving from Seattle to Los Angeles (wife was visiting with my daughter @Disneyland, so I surprised them), I dropped off the car the next morning with Greg. They installed the headers in one day. Since I was visiting friends (ie. drinking that night) I told Eurcode to keep it overnight and take their time.
    Recap of Eurocode's Customer Service:
    -Great deal on the installation since I was driving from Seattle
    -The owner gave me the exhaust off his own car, since they couldn't get one in time for my impromptu road trip
    -Sold me Greg's headers he was going to put on his own car
    -Boxed up and shipped my old exhaust to the buyer
    -Free tank of gas to get me home, and a comped the alignment because their local guy took forever to complete
    Impressions:
    After driving it for 24 hours, I can say without a doubt the power increase is noticeable. The torque comes on sooner, and it pulls with more gusto towards redline. Remember, I drove down fromSeattle (1200 miles) just a few days ago, so the stock feel is still in my muscle memory. It just breathes better.
    The AWE system was installed on Dave's car, and it is so fucking loud that you would have to be 21 to think its cool (wink: Auditude). The milltek on the other hand is almost as quiet as a stock system while putting around town, but throws the V8 bark when you step on it. The sound of the Milltek with the headers is great, it is definitely different from the AWE lamborghini tone, but it is OH so sweet sounding (both inside and outside the car).
    Most importantly, it is wife approved. She thought the AWE was too loud, the new exhaust is "great!"
    Inside the cabin, it is a civil sounding combination. It idles the same, cold starts much quieter than with the AWE, and has considerably less drone in 7th gear @2k rpm vs. the AWE (even with Headers!). Surprisingly, I almost find the milltek/header combination quieter than a stock AWE system.
    Milltek:
    AWE:
    Conclusion:
    If I were to do it all over again, I would go Milltek from the beginning and install headers before I get an exhaust to begin with (stock pipes if necessary). Exhaust is basically for sound, and the headers give this to you with a healthy performance gain to boot. Pound for pound, its more logical and economical for the gains to get headers. I am a believer.
    Next up: GIAC tune tomorrow @10am
    Sep 08 2012
    unknown
    great setup. just installed awe intake and catback. love it so far, felt a difference right away in power , very exotic sounding exhaust. did too many 1st -3rd gear pulls in one day lol. headers are definately something id consider for power gains, but would only do it with miltek ofcourse. headers and awe is crazy loud!! lol
    are you going for st.1 giac first? granted that st.2 and pulley isnt out, unless your getting special treatment:(.
    trying to convince myself to just get st.1 for now , cause im dying for a tune :(.
    Sep 19 2012
    Stage 1. They are only developing a S2 tune for only B8 cars (not B8.5).
    Sep 08 2012
    unknown
    Giac stated that the b8.5 tune would follow shortly after release of the b8. Unless things have changed.
    Veteran Member Four Rings thedollardoctor's Avatar
    Oct 28 2012
    Dayton, OH
    Quote Originally Posted by scrofas5 View Post
    +1, this is correct! The B8.5 Stage II tune will be released along with B8. According to my conversations with GIAC the B8.5 DSG Tune may take a bit longer to be released due to new torque monitoring functions in the ECU for the B8.5s..... just my luck :-)
    OP, have you finally had the chance to let the Stage I tune fully take hold? And if so...................... well?
    2013 Audi S4 | Ice Silver | DSG | GIAC/AWE Stage II with DSG Tune | Roc Euro Intake | AWE Full Exhaust w/ Resonated DPs | VMR V713 19x9.5 et45 Matte Black | H&R OE Sport Springs | USS Sway Bars and End Links | Alu Kreuz | Color Coded Custom Painted Headlights and Emblems by ONEighty Customs | RS4 Style Honeycomb Grille by ECS
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Re: My Go Fast Bits
    PM sent
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Sep 19 2012
    GIAC Stage 1 tune + Eurocode Headers + Pacific Coast Highway + =
    Sep 19 2012
    yup, its fully seated. Remember, I flashed in Irvine and drove into Seattle two days later....
    Tune is great -- coupled with the headers-- it really gave me the low end torque I was craving. I could care less about peak HP, I WANT MORE TORQUE! lol
    Jun 22 2010
    Abingdon, VA
    Have you done a dyno since the GIAC tune and the EUROCODE HEADERS? I'm curious about the gains you've experienced since your original dyno.
    Senior Member Two Rings Massey's Avatar
    Apr 02 2012
    2007 Toyota Tacoma TRD sport 4WD
    Rancho Cucamonga CA
    Quote Originally Posted by s4pwndu View Post
    Me too I have the giac tune, awe full system, and really want the headers!!!
    '10 S4 B8 DSG Premium plus Brilliant black, Carbon trim, navi, w/ sports diff/ GIAC stage 2/ AWE pulley/ AWE exhaust w/res DP and oval diamond tips/ AWE S Flo/ AG m590 20x10 ET 35/ Hankook V12 255/30/20/ H&R SS/ Eurocode ÜSS F/R End Link/ Adjustable Stabilizer Bar Set/ Alu Kreuz/ R8 GT wheel/ Caractere bumper/ RHD Ecodes/ Xpel ultimated/ .....(whatever vag-com mods Alex from TAG did)
    Sep 19 2012
    dyno soon...
    Jun 22 2010
    Abingdon, VA
    Noob, stoopid question: Are "downpipes" the same as "headers"? If not, what's the difference?
    Stage 2 Banner Advertiser Four Rings Josh/AWE's Avatar
    Feb 08 2012
    Horsham, PA
    On these cars, the Downpipes are located after the headers and cats to provide additional sound tuning. No performance gains to be had, just a change in overall volume. Headers are where you would pick up additional power due to a restrictive factory system.
    Performance Specialist
    AWE-Tuning.com > 1.888.565.2257
    my email > facebook > twitter > instagram > youtube
    Sep 19 2012
    switched out from AWE to Roc-Euro
    Anybody want to buy my AWE?
    Sep 19 2012
    Had some time and made a video:
    Jun 22 2010
    Abingdon, VA
    I have a question about your OptiCoat,...
    Do you still wax your car or is OptiCoat supposed to replace regular waxing?
    Sep 19 2012
    Only polish
    Jun 22 2010
    Abingdon, VA
    Only polish
    What does polishing do? I assumed the Opti-Coat worked as a sealant and if you polished you were really just polishing the Opti-Coat.
    Does polishing give it a shine?
    Established Member Two Rings easytreez's Avatar
    Feb 28 2013
    Lake Tahoe
    Awesome build, love the car. So now with the e code headers and the milltek exhaust is this a fully cat less system?
    In the market for a B8 S4 | '08 Touareg V6 bone stock | '92 Gti VR6-T | 300+ whp at 12psi | T3/4 turbo | Wavetrac Diff | ACT sprung 6 puck | and a whole lot more...
    Sep 19 2012
    Yes
    Sep 19 2012
    UPDATED DYNO RUNS:
    2013 Audi S4
    DSG transmission
    92 Octane
    Eurocode Headers (eliminated all cats from exhaust system)
    Roc-Euro Intake
    Milltek Exhaust (Resonated)
    GIAC ECU Stage 1 Flash (91 Map)
    3rd Gear Gains (File: 3 & 17):
    HP: +77.54
    TQ: +62.67
    4th Gear Gains (Files: 1&11):
    HP: +77.40
    TQ: +52.47
    Right on par with my expectations.
    Interesting Note: The more runs I did, the higher my peak HP numbers (as I reset the ECU only a day before my appointment, which resets the adaptation).
    I probably would have thrown higher peak numbers, if I did one more cool down but my 1-hour appt. was up. Either way, I'm happy with the gains!
    Sep 19 2012
    FYI, I went from AWE intake to Roc-Euro, AWE exhaust (with resonated dps) to Milltek resonated.
    Sep 19 2012
    Video of the Dyno Pull:
    Oct 14 2012
    Empty...for now...
    SE PA
    Thanks for posting that video of you driving. Brightened my otherwise black cloud-covered day at work. Sounds crazy with the roc intake letting all sorts of SC whine out
    SOLD 2015 Daytona Gray S4
    Mar 06 2013
    MontCo
    This whole thread is Full of Win! Car is Awesome. Garage is Awesome. Love it.
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Thanks for the entertaining thread :)
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by EHesh14 View Post
    +1
    awesome ride, tastefully modded
    Sep 19 2012
    Mirror mount for the Escort
    And another pic of the whole car on my epic bucket list drive up PCH...
    People keep asking me how much I have put into the car, why didn't I just buy a corvette, or GTR, or Porsche or whatever. What they don't understand is I picked this car for two reasons:
    1) I always wanted an S4 when I was in high school. But alas my 93 Astro Van was all I could afford.
    2) I wanted a fast daily driver, handles well in the rain (Seattle), holds a couple car seats, and doesn't scream "Hey look at me, I want you to think I make a lot a lot of money!"
    The GTR (which I almost bought) would have been too flashy. The S4 slides in nicely in my realm of speed and refinement. And most people just think I drive an A4 with nice wheels. :)
    Veteran Member Three Rings motionneon's Avatar
    Feb 09 2011
    Honda Odyssey Turbo S
    St. Petersburg, Florida
    Love your car. Wheels look AWESOME with your exterior color. Which color is is?
    2011 S4 DSG
    Phantom Black, Black and Magma interior, RS4 Grill, 30% tint all around
    STASIS v1.0 ECU, Strat intake, Milltek non-res exhaust, Deval Rear Valence
    19" Peelers, Michelin Pilot Super Sport A/S
    May 08 2009
    Southern California
    2) I wanted a fast daily driver, handles well in the rain (Seattle), holds a couple car seats, and doesn't scream "Hey look at me, I want you to think I make a lot a lot of money!"[/B]
    Couldn't agree with you more. Coming from a modified RS4 I was ready to get into something that could be civil when I want it to be (e.g. driving with the family) but a great sports sedan when it doesn't need to be 'quiet' (e.g. during a beautiful SoCal sunny day and driving up Hwy 2 or PCH, etc, etc). I will definitely miss the RS as it was the best car I have owned thus far in my life but Im loving the S4 and am happy with my choice. Now its a matter of holding off on modifying it for a bit despite my desire to buy buy buy :) "Enjoy the car as it stands" I keep telling myself....we'll see how long that lasts!
    New - 2013 S4 Moonlight Blue Metallic
    Gone But Never Forgotten - 2007 RS4 Phantom Black Pearl - Stasis MS, Hotchkis F/R Sways, Clutchmasters FX300, GMG Exhaust, Piggy Pipes, VMR V710 19x9.5, K&N Drop-in
