UDDATE: This worked out well. I mixed some epoxy that's made to be used with fiberglas, got it from Walmart in a big can that will last a while. It's a two-part mix, I use a tablespoon of resin in the bottom of an upside down beer can and two drops of hardener. I covered all the spring mounts on the back of the climate control buttons, and used to reattach some of the brass spring clips that stayed with the dash when they should come off on the trim pieces. Worked great. Looks good.
PRIOR POST:
Disassembly and cleaning worked well for me but the metal springs on the back which push the buttons out into the cockpit, in some places, broke off their tiny plastic mounts. So the buttons were getting stuck from dirt, but also not enough pressure pushing them back into place.
I am going to mix a tiny amount of fiberglas epoxy to try to hold them back on. I appears they were manufactured by passing the thin metal over the plastic mount and then melting the mount to deform the plastic enough to hold it in place. Same procedure with the brass clips that hold the trim pieces on. Anyone else try any kind of glue to hold these fragile dashboard pieces together?
