Results 1 to 19 of 19
Hybrid View
    Established Member Two Rings Closer98's Avatar
    Feb 19 2012
    2012 Audi S4 & 2012 Mercedes Benz GL 550
    Roslyn, NY
    Rubbing in the rear need advice
    I'm running a 20mm rear spacer and 10mm front spacer with KW V3's and sways. Car still has stock 19's with 255/35 19 all around. Car has now been corner weighted and wheel aligned and still getting some rubbing in the rear over dips in the road and big bumps. I know 20mm in rear with this size tire is a bit aggressive. I don't want to go with a narrower tire width. Thinking of changing setup to 10mm in the rear and 5mm up front. Shop where it was corner weighted and aligned said that with the 20mm rear spacer we lose some camber. With 10mm rear we should be ok. Is this the right move if I don't want to change tires and wheels at the moment? Please help.
    2012 S4 DSG, Phantom Black/Black Silk Nappa, B & O, Sport Diff, 19 5 Segment, Nav, Back Up, Carbon Inlay, Advanced Key, Revo Stage 1 Flash, Miltek Resonated Exhaust, S Flow Intake, 20mm Rear Spacers, 10mm Front Spacers, KW V3's, Hotchkis Front and Rear Sway Bars, Supercharged Badges, Tints
    Veteran Member Three Rings Kem's Avatar
    Aug 30 2004
    Colfax, CA
    Depends how much you're rubbing, you can always go with a 15mm spacer if it's just a little rub.
    Quote Originally Posted by Closer98 View Post
    2005 6MT ur-Allroad
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    or trim the fender liner, thats what i did
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Senior Member Three Rings sirpickles's Avatar
    Jun 26 2012
    The Mid-West
    Does the rear have that fender clip to be removed?
    B8 S4 | 6spd | Brillant Black | Prestige | B&O | Carbon Inlays | Magma Silk Nappa | ADS/Rear Diff | Driver Assist
    Mods | 20% tint | AluFelgen SF-71 19x9.5 ET42 | H&R Sport Springs
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    Quote Originally Posted by sirpickles View Post
    only the fronts.
    my advice is keep wearing it away if it's just the liner or trim it down.. worked on my S5 :D i'm currently running a 10mm in the rear and rub on big dips, but it's just the liner, so i don't mind. i'm running -2 camber also.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Registered Member Four Rings Jimminez's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    ...that with the 20mm rear spacer we lose some camber.
    Huh? How exactly does a spacer affect camber? Unless they meant that you would need more negative camber to clear the tire under the fender as you've pushed it out, but I don't see how the camber would be different between having and not having a 20mm spacer.
    But like others have said, 20mm is aggresive and can either go smaller and/or cut out the fender liner if that is what you are rubbing on and not on steel.
    Feb 19 2012
    Roslyn, NY
    Quote Originally Posted by Jimminez View Post
    You hit it on the nose. It's pushed out too far to negative camber it.
    Feb 19 2012
    Roslyn, NY
    It definitely is fender rubbing. Aside from the rubbing the car is dialed in bigtime. I was just driving into city and hitting turns at about 120 MPH and the car was flat and planted. I wonder if going with 10mm in rear and 5mm upfront will make it handle better/worse or same. I hope same or better.
    Veteran Member Three Rings jfabes's Avatar
    Feb 05 2012
    H-town
    do you track the car? do you really think your driving skills are so pinpointed that you will actually notice the car handling same, better or worse with a 5 or 10mm spacer change? i'm continually surprised by people that run outrageous offsets and then either surprised/annoyed/disappointed that the tires rub. so your running et23 on a 8.5. I'm running 9.5 et 42 and I think they are perfect, any more would be poking, and your setup is 6mm more than mine. i think you should do 15mm spacers at most in the rear (or 10 rear, 5 front as you mention) and call it a day. If you insist on keeping the agressive spacers, what about having your rear fenders rolled?
    Established Member Two Rings evanstonjohn's Avatar
    Jul 14 2011
    Evanston, IL
    I tried 20, 15 and 10 spacers on stock suspension and they all rubbed. I cringed every time it happened, hearing a 60K car sound like a ghetto cruiser, so I took them off and sold them. My mod guy was going to roll the fenders but said it wouldn't help as there is not enough of a lip to roll so he told me not to do it.
    Quote Originally Posted by jfabes View Post
    2011 Prestige/Phantom Black/ Silk Napa Black Leather/6MT/ Sports Diff/ADS/32% tint/Miltek Non-Res Exhaust/Stasis Tune,version 2/ LED interior and license plate lights/ Titanium Grill/ Alu Kreuz Steering Brace/Stratmosphere Intake/Dipstick/All Standard Vag-Com Mods, JHM short throwshifter, RS4 pedals and dead pedal; P3 Vent Gauge.............. Have VagCom cable and willing to help with mods in the Chicago area, contact me.
    Feb 19 2012
    Roslyn, NY
    Quote Originally Posted by evanstonjohn View Post
    I'm cringing now. Changing spacers tomorrow.
    Feb 19 2012
    Roslyn, NY
    I track all my cars and am very in tune with what the car is doing. I agree I went to aggressive. Going to try the 10mm rear and 5mm front set up and see what happens. Haven't rolled fenders yet.
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    How does the GL 550 handle on the track
    Nov 05 2006
    Fair Lawn
    not possible to roll the rear... fronts you can. for the rear you can pull the fenders but i highly recommend against it
    Apr 04 2012
    MSP
    I was gonna bust out a joke about your title but decided to keep it clean
    Anyone else wanna take a "crack" at it!!!
    Feb 19 2012
    Roslyn, NY
    Quote Originally Posted by MrFunk View Post
    Bust it man. I looked at it again and laughed...
    Active Member Two Rings B-Town's Avatar
    Jul 01 2009
    Colorado
    I feel better now that I'm not the only one who found the title "Rubbing in the rear need advice " amusing
    was going to suggest webmd.
    Feb 19 2012
    Roslyn, NY
    Thx for all advice. I fixed the rubbing issue. Changed spacers to 10mm in rear and 5mm front and rubbing is gone. Going to autocross car tomorrow and will see how dialed in she really is.
