Page 82 of 102 FirstFirst ... 3272808182838492 ... LastLast
Results 3,241 to 3,280 of 4063
  1. #3241
    Orange County, CA
    I hope chatterbox was from fat finger syndrome... this thread should have been in the Project & Build forum since post 1... fixed.
    B5 Parts For Sale
  2. #3242
    Sep 18 2012
    State College PA
    Quote Originally Posted by OverSpun View Post
    Cheers!
  3. #3243
    Sep 18 2012
    State College PA
    Well I'm back up in high boost mode - ~37psi.
    Got the 1700cc injectors installed and almost dialed in :-)
    Managed to hit a 1.88s FATS this morning on the way to work with no nitrous!
    The run also worked out to be:
    100-200kph: 4.9seconds
    60-130mph(2mph short :/): ~5.45s
  4. #3244
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Is 1.88 the highest anyone has on here?
    Where do you think the nitrous will put you?
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
  5. #3245
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by Austonwerner4 View Post
    Well peak torque is at ~5200rpm right now and the FATS starts at 4500.... so moving peak torque (via nitrous) another 500+rpm earlier should help a bunch... this is the turbo I should have bought first
    I can't wait to see what E85 does for my 6262....
  6. #3246
    Feb 23 2010
    Emmaus Pa
    on the side of the road with another blown up motor
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
  7. #3247
    Veteran Member Four Rings ratherb1's Avatar
    Jun 07 2010
    Rhode Island
    I have to agree with this .......but if lee isn't happy with 1.88 fats I guess that's the only thing left to do ....lol
    Or bigger turbo with a small helper turbo or supercharger ......would love to see this
  8. #3248
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Yea. The mains on the rs4 block are a little more beef, but they are still webbed.......
    Stronger. Yes. By how much? no one knows- it could be marginal.
    ITguy just cracked the mains in his car, lasted 4 months at 600whp/600wtq on e85 with SRM K24's. It was an early APB.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
  9. #3249
    Sep 18 2012
    State College PA
    Quote Originally Posted by rtl5009 View Post
    Yeah I'm afraid to runt he Nitrous to be honest... unless it's a very small shot like 30hp or 50hp.
    I might try that, otherwise I don't want to push the block to the limit :-)
    Or rather, I don't want to find where the limit is!
  10. #3250
  11. #3251
    Oct 27 2011
    TOYS
    Philly Suburbs
    Yeah, that block is worth a bit too much for R&D ;)
  12. #3252
    Feb 06 2012
    Lake Lanier, GA
    My SRM car is so beast it breaks at idle
  13. #3253
    Jul 28 2009
    Philadelphia PA
    My first Audi - 2001.5 S4 with Custom Single Turbo setup...
    Quote Originally Posted by aysix View Post
    Yea. Your shit cray......
    c8 a6 allroad
  14. #3254
    Oct 27 2011
    TOYS
    Philly Suburbs
    Speaking of idle, how are the 1700cc injectors?
  15. #3255
    Veteran Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    NYC auditioning.
    How much PSI?
  16. #3256
    Sep 18 2012
    State College PA
    Quote Originally Posted by TweetsS4Estate View Post
    How much PSI?
    Right now I'm at about 37psi
  17. #3257
    Sep 18 2012
    State College PA
    Just dandy :-)
  18. #3258
  19. #3259
    Oct 27 2011
    TOYS
    Philly Suburbs
    Just dandy :-)
    I wonder how it would idle on gasoline....
    Car must feel glorious at 5200 rpm
  20. #3260
    Sep 18 2012
    State College PA
    It feels like I'm about to go wheels up, close the flaps, and put away the landing gear :-)
    And if you're going for 700whp or less 1000cc should be fine...
    I'm hitting 57.5% IDC now on 1700s lol.
  21. #3261
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Even on e85?
  22. #3262
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by AudiForeman View Post
    Even on e85?
    Yes, rail pressure can be bumped making those 3 bar 1000's into 1200's np.
    c8 a6 allroad
  23. #3263
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Thank you. Great work Lee
  24. #3264
    Sep 18 2012
    State College PA
    Even on e85?
    Correct,
    1000cc injectors running at 4 bar (not 5 because that's silly) are around 1160 to 1180 each, then add in the meth and you gain about 100cc per hole there too.
    My 1700cc guys are closer to 2000 with the fuel pressure and meth.
  25. #3265
    Sep 18 2012
    State College PA
    So here's the current plan for the 3.0 build - most parts are already in my hands or will arrive this week:
    JE Pistons - Custom 10:1 comp FSR w. coated skirts (Integrated Engineering)
    JE Tool Steel Wrist Pins (Integrated Engineering)
    Integrated Engineering Connecting Rods (Integrated Engineering)
    ARP L19 Rod Bolts
    ARP Main Studs (Integrated Engineering)
    ARP Head Studs (Integrated Engineering)
    CNC Ported 2.8 Heads
    +1mm Supertech Intake Valves
    +1mm Supertech Exhaust Valves
    Supertech springs & Retainers
    Supertech Solid Lifters (034)
    LOBA Mechanical Cams (Loba)
    3.0 Crank (obviously lol)
    Billet Block Reinforcement (Details to come - 2001.5 APB Block)
    Billet Aluminum Oil Pan (Details to come)
    Billet Aluminum Intake Manifold (If it's done in time, otherwise RS4 for now)
    Billet Aluminum Valve Covers (If time permits - just because they would be cool lol)
    I'm sure I'm missing parts but that's what I can think of for now...
  26. #3266
    Veteran Member Three Rings spd579's Avatar
    Jun 04 2012
    05 s2000, 2001 Mazda Miata with SR20deT(GT2871) swap, 1990 Mazda Miata(Tme attack(500whp))
    Charlotte, NC
    How'd you decide on the Loba cams? and please replicate everything billet for me please, I voluenteer to to help with R&D! ha
  27. #3267
    Jun 04 2012
    Charlotte, NC
    This makes me happy, with a slightly smaller turbo I hope to have the same (if not better)spooling charachteristics as this graph.....I'll only be going to around 30 psi though
  28. #3268
    May 16 2008
    WA
    When might we start seeing the intake take shape? I have been really curious as to what you have conjured up for this.
  29. #3269
    Sep 18 2012
    State College PA
    Quote Originally Posted by spd579 View Post
    I was going to get some custom grinds done, but the LOBA cams are made from new billets... so they will be stronger and last longer.
    Plus they have a lot of experience in the matter and I trust their testing lol.
    Plus not many people use LOBA stuff stateside so I thought it would be nice to do so ;-)
  30. #3270
    Sep 18 2012
    State College PA
    Well the 6466 is quite magical. It spools the same as the 6262...
  31. #3271
    Oct 27 2011
    TOYS
    Philly Suburbs
    Doesn't e85 affect spool?
  32. #3272
    Sep 18 2012
    State College PA
    They say E85 makes it spool quicker, I saw zero difference.
    I think it's a result of the higher timing you run with E85 ;-)
  33. #3273
    Oct 27 2011
    TOYS
    Philly Suburbs
    What exhaust housing are you running with the 6466?
  34. #3274
    Sep 18 2012
    State College PA
    A 0.63
    With no power drop even at 8000rpm compared to the AGP 0.82 housing.
  35. #3275
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    oh my god! that is just ludicrously fast man. well done.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
  36. #3276
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    Quote Originally Posted by sherbet View Post
    As in Ludicrous Speed?
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
  37. #3277
  38. #3278
    May 16 2008
    WA
    /\ /\ Says "This Video Is Private" for me
  39. #3279
    Sep 18 2012
    State College PA
    Quote Originally Posted by getslideways View Post
    Whoops. Fixed.
    Sorry about that.
  40. #3280
    Veteran Member Three Rings cjk's Avatar
    Jul 15 2004
    2001 WB S4 Avant
    Seattle, Wa
    What did those run you?
    REALTOR specializing in residential real estate throughout the greater PNW!
    https://kinzeleidsonteam.com//
    Constantly on my WB S4 Avant i
