Page 41 of 102 FirstFirst ... 3139404142435191 ... LastLast
Results 1,601 to 1,640 of 4063
  1. #1601
    May 16 2008
    WA
    glad to hear you are getting it sorted out. Any luck confirming the source of the coolant leak?
  2. #1602
    Sep 18 2012
    State College PA
    Quote Originally Posted by RickyCastro View Post
    You getting a new coolant tank or rocking that yellow one?
    lol it's really not as yellow as the lights make it look... but I'll probably get a new one at some point
  3. #1603
    Veteran Member Four Rings 1gcrazy's Avatar
    Sep 01 2011
    Colorado Springs
    So close...
    Just needs intercooler piping now for test drive
    This video is fake, I didn't hear you say "Right O"
  4. #1604
    Sep 18 2012
    State College PA
    2.9 FATS on break in tune.. not bad.
    Turbo is deff laggier than my last one... quite a lot so, but then it's a lot bigger.
    Can feel the difference up at high rpm though. no power drop off.
  5. #1605
    Oct 27 2011
    TOYS
    Philly Suburbs
    Can't wait to get a ride
  6. #1606
    Sep 18 2012
    State College PA
    Ahhhh there's nothing like Christmas on a Monday morning
    Additional spring for wastegate:
    Coil pack harness pieces to wire up the 2.0 coil conversion:
    Oh what's this...
    Mmmmmm goodies...
    Yepp... I have a busy busy week ahead of me for sure!
    Who wants to come help? haha
  7. #1607
    Sep 18 2012
    State College PA
    Quote Originally Posted by getslideways View Post
    On first fire up after reaching operating full temp there was a dripping from behind the engine...
    It hasn't dripped since but there is a whisp of what smells like coolant from back there...
    I think I might have cracked the one heater hose take off elbow I have in place... but it requires pulling the up pipe to properly fix it. So I was waiting for the extra wastegate spring to arrive to do that all at the same time...
    That came today so I should probably check it out tonight...
  8. #1608
    Jan 25 2006
    A4 2.0T
    MD
    Whats that metal line and fitting in your devils own box? Have they upgraded the package to include metal lines and fittings?
  9. #1609
    Sep 18 2012
    State College PA
    Quote Originally Posted by Don Supreme View Post
    They are optional upgrades you can get... I basically maxed everything lol.
    Turned a $400 system into a $600 and some change system.
  10. #1610
    Oct 27 2011
    TOYS
    Philly Suburbs
    Is that a 5 gallon w/m tank BT?
  11. #1611
    Sep 18 2012
    State College PA
    2.5 Gallon.
    Should be enough
    I have a brand new AEM 1 Gallon tank if you wanted it and then you could have 2 lol.
  12. #1612
    Feb 06 2012
    Lake Lanier, GA
    Any reason why you chose Devils own vs other options specifically aquamist?
  13. #1613
    Sep 18 2012
    State College PA
    Quote Originally Posted by aysix View Post
    Just seemed to be the best value for money as far as the features I wanted go.
    Start adding the options like metal line and bigger tank to the Aquamist once and see how expensive it gets lol.
  14. #1614
    Sep 18 2012
    State College PA
    Looks like the "tiny" turbo combined with 0.82 A/R exhaust side hits 20psi at about 4500rpm, and 25psi at abut 4750.
    Once she spools it comes on quick...
    Deff going to need the nitrous for low rpm boost lol.
  15. #1615
    Sep 18 2012
    State College PA
    I'll put up some logs later, but none of the cars I've tuned carry power up to red line like this one does... I really feel it's the head flow plus the exhaust side A/R. Mainly the exhaust side not choking the engine up high.
    Oh baby lol.
  16. #1616
    Jun 14 2007
    2000 S4
    Connecticut
    You know whats kinda funny... Sure you'll see a Devil's own/old VAST kit thread about fittings leaking here and there, but you see FAR more threads about Aquamist problems. Pumps, failsafes, this that and the other thing. My 3.5 year old meth kit still doesn't miss a beat, and with AN fittings like britishturbo got, it's a pretty damn good setup for the $.
  17. #1617
  18. #1618
    Jun 14 2007
    2000 S4
    Connecticut
    Yeah I took failure rates into consideration as well lol.
    I'm sure you did because it's you (compliment, lol), but did you measure the lines and all that jazz? The braided lines they send you don't like to be bent much at all, so mine is a little funky in my engine may but it turned out okay.
  19. #1619
    Feb 21 2011
    WA
    I had the same issue on my startup but it went away after reaching operating temp a couple times and hasn't come back. G12 is supposedly self sealing but I'm wondering if I possibly unseated an oring somewhere and, after a flush, the system just needed pressure and heat to seal back up. I have no idea though but it does bug me that the issue resolved itself.
    Black: not slow
    Blue: gutted and static
  20. #1620
    Sep 18 2012
    State College PA
    Quote Originally Posted by waB5S4 View Post
    I put some extra force on the connector as well lol.
    I'm going to keep an eye on it and see if I want to pull it or not.
    I'll probably drive the car to work tomorrow so the 35 mile ride will tell me if I'm losing any or not.
  21. #1621
    Sep 18 2012
    State College PA
    Had a crazy night working on the S4.
    Changing the injectors turned into removing the intake manifold... don't ask.
    While I was there I changed the wastegate spring.
    In dialing in the new injectors I hit some 2.7 fats times lol. Shit sure is crazy.
  22. #1622
    Sep 18 2012
    State College PA
    Fixed some big boost leaks...
    Car is batshit crazy...
    Still on straight 93... no meth yet, running super rich... did a 2.64 Fats lol, followed by a 2.75 with throttle cut...
    This thing is going to fly.
  23. #1623
    Jun 14 2007
    2000 S4
    Connecticut
    Nice! You still have some ways to go, to catch up to the K04 record
    http://www.audizine.com/forum/showth...ond-FATS-pulls
    How much boost are you running now?
  24. #1624
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    Quote Originally Posted by AudiSportB5S4 View Post
    Funny thing is, that car would have been significantly faster with a real tune.
  25. #1625
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by phila_dot View Post
    Lmao!
  26. #1626
    Sep 18 2012
    State College PA
    lol give me time ;-)
    Not sure. Was too scary to look at gauge haha. Like 28psi I think.
    I'll look at the logs. I had to get to work lol.
  27. #1627
    Jun 14 2007
    2000 S4
    Connecticut
    Agreed.. Those logs are crying for help.
    I wish he was still in the game, because throw a set of more potent small frame turbos on it like even a F21, or silly wabbits whatever you want to do, and the trap would be pretty damn high!
  28. #1628
    Jan 25 2006
    A4 2.0T
    MD
    Stay tuned.... Your wish is closer to reality than you realize.
  29. #1629
    Veteran Member Three Rings mightemouce's Avatar
    Mar 12 2007
    01 S4
    The cars still in the game he's not though !
    I'm anxious to see it get out to the track this year !!
    Back on topic though
    I ordered the same harness for 2.0t swap was the best bang for the buck in my eye
    07 - RS4
    05.5 - 2.7t B7 -Sold
    Insta-Ste3v3_0
  30. #1630
    Sep 18 2012
    State College PA
    According to the logs... 30psi lmao
    But it isn't hitting that until 5500rpm... Doh!
  31. #1631
    Jun 14 2007
    2000 S4
    Connecticut
    I knew the car was still stomping around, I meant more or less with HIM behind the wheel ;). He has QUITE a bit of track experience. I bet whoever is going to motor it down won't pass his record right away..
    But yeah anyway..
    Lol awesome. Get us some footage!
  32. #1632
    Sep 18 2012
    State College PA
    But yeah anyway..
    I did take a video, it might not be the best though... I'll trim it and upload it lol.
    I need a go pro!
  33. #1633
    Oct 27 2011
    TOYS
    Philly Suburbs
    Your running at 2.6 fats with your power coming on at 5k plus!
    I'll race you if you start in 3rd gear at 40 mph again lol
  34. #1634
    Sep 18 2012
    State College PA
    LMAO and I'll call you Jesse
    Check it out:
  35. #1635
    Jun 14 2007
    2000 S4
    Connecticut
    Can you run through the gears without falling out of boost there? Seems like that's a pretty steep curve and if you shift at 7k you'll be building boost again..
  36. #1636
    Sep 18 2012
    State College PA
    Haven't tried it through the gears yet, I will tonight
    And right now I'm revving to 7800, I'm going to raise limiter to 8500.
    For some reason that graph wouldn't plot with the rpms going to redline and I had to trim it haha.
    It does not slow down at 7500 at all, wants to keep pulling, I hit the limiter a few times before shifting lol.
    I might actually have a 3-4 shift I'll look.
  37. #1637
    Sep 18 2012
    State College PA
    So I really don't know how accurate this is... but this is the Virtual Dyno plot for the fats data above...
  38. #1638
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Check it out:
    Your boost curve is very similar to mine.
    Looking good. Get it on a real dyno though!
  39. #1639
    Sep 18 2012
    State College PA
    Quote Originally Posted by Evilevo View Post
    Well that was going to be this weekend but now I have to work
    So soon...
  40. #1640
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Are you still doing your FATS in the same place on 45? ...in Mexico of course
